| NullPointerException at JavaCore.getOptions(JavaCore.java:1248) [message #54015] |
Tue, 10 June 2003 21:05  |
Originally posted by: dbexternal.comcast.net
Just started playing with the JDT Core, writing a real simple program to
parse an AST, and I'm getting a NullPointerException at
JavaCore.getOptions(JavaCore.java:1248).
I must be doing something wrong. Any help would be greatly appreciated....
My code goes down on the AST.parseCompilationUnit() operation:
if (args.length < 1) {
System.out.println("Usage: TestAST <JavaFile.java>");
System.exit(1);
String contents;
if ((contents = getSource(args[0])) == null)
System.exit(1);
CompilationUnit cu = AST.parseCompilationUnit(
contents.toCharArray() );
Thanks, Dennis
| Re: NullPointerException at JavaCore.getOptions(JavaCore.java:1248) [message #54512 is a reply to message #54274] |
Wed, 11 June 2003 09:20  |
Just to clarify: a plugin cannot be invoked from a main(String[]) method.
You need to use the Platform launcher to launch the Eclipse Platform (see
org.eclipse.core.launcher.Main in startup.jar).
For further questions about plugin and the Eclipse Platform, you should ask
on the eclipse.platform newsgroup.
Jerome
"Dennis" <dbexternal@comcast.net> wrote in message
news:bc6rh8$8mb$1@rogue.oti.com...
> Thanks Jerome, I heading down that path now. Having read the PlugIn
> JavaDoc, I'm assuming I just need to extend PlugIn, but I wasn't sure how
> to gain access to the plugin from a main(String[]) method?
> Thanks, Dennis
> Jerome Lanneluc wrote:
> > Dennis,
> > Functionalities in JDT/Core can work only if the Platform is running.
You
> > cannot invoke JDT/Core from a main(String[]) method. You will need to
write
> > a plugin that requires org.eclipse.jdt.core.
> > Jerome
> > news:bc5v9h$l6u$1@rogue.oti.com...
to
> > appreciated....
> > > public static void main(String[] args) {
> > > System.exit(1);
> > > String contents;
> > > System.exit(1);
> > > Thanks, Dennis
FUDForum. Page generated in 0.03214 seconds
