ConnectionLayer in GEF [message #54004] |
Sun, 12 January 2003 14:15  |
Can someone please tell me how to use ConnectionLayer in GEF? Is there an
example somewhere? From the javadoc, it is a layer for connection and
primary layer is for figures. If I want all figures on top of all
Connections, do I need to have 1 connection layer and 1 primary layer? if
yes, where should I create and add those layers to? to the main editor?
thanks for any help.
Re: ConnectionLayer in GEF [message #54038 is a reply to message #54019] |
Sun, 12 January 2003 16:07  |
Could you please what is the best approach to make Connections behind
figures and invisible when they overlap? And both connections and figures
are visible when they are not overlap?
"Eric Bordeau" <ebordeau@us.ibm.com> wrote in message
news:avsfnf$vi7$2@rogue.oti.com...
> The layers are created in
FreeformGraphicalRootEditPart.createLayers(LayeredPane). The layers are
> stacked on top of each other based on the order they were added to the
LayeredPane. You'll notice
> the connection layer is added after the primary layer, so connections get
drawn on top of the
> figures. Switching the order in which these layers get added would put
the connection layer behind
> the primary layer, but there's a problem with this approach. The content
of the primary layer is
> the figure for the LogicDiagramEditPart, which is opaque and covers the
entire layer. This means
> the connections won't be visible since the diagram figure will be painted
on top of the connections.
> The same holds true for CircuitFigures. Any connections inside a
circuit wouldn't be visible.
> Eric
> yinglcs wrote:
> > Hi,
an
if
FUDForum. Page generated in 0.03720 seconds
