Specifying the default schema for code completion [message #53983] |
Wed, 01 April 2009 14:27  |
I am using the datatools project to connect to an Oracle database by I am
having some usability issues.
By default code-completion in the SQL Editor/Scrapbook only shows you
options from tables in the schema which corresponds to the username used
to login. In my case most of the tables I work with are in another schema
which I have access to, so I would like to tell the editor to use a
specific schema is the default...is there a way to do this? If not is
there a bug for this (I couldn't find one).
It seems like the SQL Query Builder respects the Schema Filter preferences
when showing the list of available tables to choose from and it even has a
preference omitting the default schema name and specifying what that
default should be. Shouldn't both tools be using the same option?
Marc
FUDForum. Page generated in 0.04116 seconds
