| [MTL] Status? [message #53938] |
Mon, 15 December 2008 10:59  |
Hi there,
I would like to use MTL for specifying some transformations as part of the
Eclipse project Java Workflow Tooling (JWT).
In ATL I have the problem that I didn't find a possibility to navigate
through some package structures and create as a target a workflow file
that contains the packages from the source file in the same structuring.
Since MTL is now a standard by the OMG, I thought I might better switch to
MTL in order to create my transformations and solve this problem.
Since the wiki pages are not really up to date and there is not much
documentation available (besides the ESE08 presentation which I attended
in Ludwigsburg), I would like to ask:
-what is the current status of the project (stable, all aspects of the OMG
standard covered)?
-whether the described package navigation is possible in MTL?
Thanks in advance for your assistance and best regards,
Florian
-JWT project co-lead-
| Re: [MTL] Status? [message #54180 is a reply to message #54154] |
Tue, 16 December 2008 08:12  |
--------------030504090107000207060905
Hi Florian,
I'm not sure what you're trying to achieve. You do know MTL is a model
to text technology as opposed to ATL that is a model to model? Was
wondering because of your mention of ATl and a "target model".
Nevertheless, if what you're trying to do is generating text from your
model, you can indeed take into account the package hierarchy when
generating your files. The only available documentation is the OMG MTL
specification though.
Laurent Goubet
Obeo
Florian Lautenbacher a
FUDForum. Page generated in 0.09699 seconds
