Home » Language IDEs » AspectJ » How to determine the aspectj-rt version?
How to determine the aspectj-rt version? [message #53914] Mon, 27 June 2005 15:36 Go to next message
Andrew sent me a script that upgrades ajdt with the latest aspectj compiler (I'm testing some compiler fixes). It would be helpful if I could determine the version aspectj version included in the ajdt dev releases so I know if I have to run the script. Is this information available anywhere?
thanks
Re: How to determine the aspectj-rt version? [message #54005 is a reply to message #53914] Mon, 27 June 2005 16:33 Go to previous messageGo to next message
> available anywhere?
Hi Barry,
I don't think that information makes it into the AJDT build itself, but
the latest ajdt dev build will contain the latest version of the ajde
plugin, so you can look up when this was last updated in CVS, i.e.:
http://dev.eclipse.org/viewcvs/indextech.cgi/org.eclipse.ajd t/AJDT_src/org.aspectj.ajde/ajde.jar
which shows ajde.jar was updated on Mon Jun 20.
Matt.
Re: How to determine the aspectj-rt version? [message #54014 is a reply to message #54005] Mon, 27 June 2005 17:20 Go to previous messageGo to next message
Are we talking about the same thing? I'm looking for the aspectj-runtime/compiler version.
-barry
>>available anywhere?
> Hi Barry,
> Matt.
Re: How to determine the aspectj-rt version? [message #54020 is a reply to message #54014] Tue, 28 June 2005 04:09 Go to previous messageGo to next message
> -barry
I think so. The AspectJ compiler gets packaged up into the
org.aspectj.ajde plugin for use with AJDT. This is currently a manual
process - Andy takes an AspectJ build, creates the ajde.jar etc files
which make up the org.aspectj.ajde plugin, and checks that into AJDT. This
is why there isn't really a precise version number associated with the
level of AspectJ in AJDT, other than the version numbers in CVS. So as
long as you're using the latest AJDT dev build, you can find the CVS
version of AspectJ / ajde that it contains using the link in my previous
post. Then from the date of this you should be able to see whether you
need to run the script.
Hope that helps,
Matt.
Re: How to determine the aspectj-rt version? [message #54033 is a reply to message #54020] Tue, 28 June 2005 11:06 Go to previous message
Oh, I see now. I didn't notice that adje was org.aspectj.adje. I saw that plugin and always read ajdt. Thanks.
-barry
>>-barry
> Hope that helps,
> Matt.
Re: How to determine the aspectj-rt version? [message #588974 is a reply to message #53914] Mon, 27 June 2005 16:33 Go to previous message
> available anywhere?
Hi Barry,
Matt.
Re: How to determine the aspectj-rt version? [message #588981 is a reply to message #54005] Mon, 27 June 2005 17:20 Go to previous message
-barry
>>available anywhere?
> Hi Barry,
> Matt.
Re: How to determine the aspectj-rt version? [message #588996 is a reply to message #54014] Tue, 28 June 2005 04:09 Go to previous message
> -barry
Hope that helps,
Matt.
Re: How to determine the aspectj-rt version? [message #589016 is a reply to message #54020] Tue, 28 June 2005 11:06 Go to previous message
-barry
>>-barry
> Hope that helps,
> Matt.
Previous Topic:AJDT and Tomcat
Next Topic:New AJDT functionality, please try it out!
Current Time: Mon Jul 21 20:03:11 EDT 2025
Powered by FUDForum. Page generated in 0.03673 seconds
