Home » Eclipse Projects » Technology Project and PMC » Is Eclipse 2.1.1 a "real" release or not?
Is Eclipse 2.1.1 a "real" release or not? [message #53824] Mon, 12 May 2003 14:50 Go to next message
Eclipse 2.1.1 is listed as a "maintenance build". However, this term is not
defined on the page "Eclipse Project Build Types". It is not listed under
"Latest Releases" nor can it be retrieved using the "Install/Update
Perspective". Should I consider this build equivalent to a "release build"
or a "stable build" or something else?
Re: Is Eclipse 2.1.1 a "real" release or not? [message #54207 is a reply to message #53824] Fri, 16 May 2003 16:04 Go to previous message
"Per Velschow" <per@velschow.com> wrote in message
news:b9oqbd$b31$1@rogue.oti.com...
not
I think I can answer my own question now after seeing the many versions of
this maintenance build and the many test failures. So I conclude that 2.1.1
is *not* a stable build at all.
Re: Is Eclipse 2.1.1 a "real" release or not? [message #593766 is a reply to message #53824] Fri, 16 May 2003 16:04 Go to previous message
not
Previous Topic:JAXB
Next Topic:SWT_AWT Swing Dialog Problem
Current Time: Thu Jul 17 21:44:29 EDT 2025
Powered by FUDForum. Page generated in 0.04442 seconds
