Home » Archived » XML Schema Definition (XSD) » Incremental update of the facet's list
Incremental update of the facet's list [message #53814] Wed, 29 September 2004 07:26 Go to next message
I have a problem with updating the list of facets after adding a new facet
to the facet contents. Here is the corresponding code snippet:
// load a schema
XSDSchema schema = load("test.xsd");
// Incrementally update the schema after each edit change
schema.setIncrementalUpdate(true);
// Build a new simple type and add it to the loaded schema
XSDSimpleTypeDefinition baseType = (XSDSimpleTypeDefinition)
schema.getTypeDefinitions().get(0);
XSDSimpleTypeDefinition simpleType = XSDFactory.eINSTANCE
.createXSDSimpleTypeDefinition();
simpleType.setBaseTypeDefinition(baseType);
schema.getContents().add(simpleType);
// Create a new facet and add it to the type
XSDMinLengthFacet minLength =
XSDFactory.eINSTANCE.createXSDMinLengthFacet();
minLength.setValue(10);
simpleType.getFacetContents().add(minLength);
// Print the facets of the type: MinLength isn't contained in the list
System.out.println(simpleType.getFacets());
// Enforce an update. Shouldn't be necessary because of the incremental
update
schema.update();
// Print the facets: Now MinLength is contained
Shouldn't the manual update be unnecessary because the incremental update
is set to true? Or did I miss something in the JavaDoc or in my code?
Cheers
Klaas
Re: Incremental update of the facet's list [message #53841 is a reply to message #53814] Wed, 29 September 2004 08:49 Go to previous messageGo to next message
--------------000401000803020308050008
Klaas,
It's a bug. Please open a bugzilla. The following change is needed:
Index: XSDSimpleTypeDefinitionImpl.java
RCS file:
/home/technology/org.eclipse.xsd/plugins/org.eclipse.xsd/src /org/eclipse/xsd/impl/XSDSimpleTypeDefinitionImpl.java,v
retrieving revision 1.3
diff -u -r1.3 XSDSimpleTypeDefinitionImpl.java
--- XSDSimpleTypeDefinitionImpl.java 13 Jun 2004 11:52:17
-0000 1.3
+++ XSDSimpleTypeDefinitionImpl.java 29 Sep 2004 12:47:13 -0000
@@ -2059,7 +2059,8 @@
protected void adoptContent(EReference eReference,
XSDConcreteComponent xsdConcreteComponent)
super.adoptContent(eReference, xsdConcreteComponent);
- if (eReference ==
XSDPackage.eINSTANCE.getXSDSimpleTypeDefinition_Contents())
+ if (eReference ==
XSDPackage.eINSTANCE.getXSDSimpleTypeDefinition_Contents() ||
+ eReference ==
XSDPackage.eINSTANCE.getXSDSimpleTypeDefinition_FacetContent s())
traverseToRootForPatching();
@@ -2076,7 +2077,8 @@
protected void orphanContent(EReference eReference,
super.orphanContent(eReference, xsdConcreteComponent);
- if (eReference ==
+ if (eReference ==
+ eReference ==
Klaas Dellschaft wrote:
>Hi,
>// load a schema
>update
>schema.update();
>Cheers
>Klaas
<html>
<head>
http-equiv="Content-Type">
<title></title>
</head>
Klaas,<br>
<br>
It's a bug.
Re: Incremental update of the facet's list [message #54097 is a reply to message #53841] Thu, 14 October 2004 09:52 Go to previous messageGo to next message
is this fix available in any of the binary distributions of XSD or is it
only commited to CVS at the moment? It seems to me that the current build
of XSD is from 2004/09/17.
Cheers
Klaas
Re: Incremental update of the facet's list [message #54122 is a reply to message #54097] Thu, 14 October 2004 10:25 Go to previous message
Klaas,
Not yet. But there should be a driver later today. (We had build
problems last week.) When we make a driver available we change the
bugzilla state to fixed and add a comment indicating which driver the
fix is in.
>Hi,
>Cheers
>Klaas
Re: Incremental update of the facet's list [message #591991 is a reply to message #53814] Wed, 29 September 2004 08:49 Go to previous message
Klaas,
RCS file:
-0000 1.3
- if (eReference ==
+ if (eReference ==
+ eReference ==
- if (eReference ==
+ if (eReference ==
+ eReference ==
>Hi,
>// load a schema
>update
>schema.update();
>Cheers
>Klaas
<html>
<head>
<title></title>
</head>
Klaas,<br>
<br>
It's a bug.
Re: Incremental update of the facet's list [message #592127 is a reply to message #53841] Thu, 14 October 2004 09:52 Go to previous message
Cheers
Klaas
Re: Incremental update of the facet's list [message #592138 is a reply to message #54097] Thu, 14 October 2004 10:25 Go to previous message
Klaas,
fix is in.
>Hi,
>Cheers
>Klaas
Previous Topic:How to load Include/Redefine/Import Namespaces?
Next Topic:XSD and WTP relationships
Current Time: Sun Aug 31 05:14:02 EDT 2025
Powered by FUDForum. Page generated in 0.04357 seconds
