Mylyn 3.0.1 cannot view taskList [message #53761] |
Mon, 21 July 2008 05:08  |
Originally posted by: ekkehard.gentz-software.de
after update (P2 automatically detects the new versions) from 3.0 to
3.0.1 I got some errors
and cannot open the taskList View
Eclipse 3.4, OSX 10.5.4, JVM 1.5
of course I tried to start with -clean
ekke
--------error--------
!ENTRY org.eclipse.ui 4 4 2008-07-21 08:13:04.666
!MESSAGE Unhandled Exception
!ENTRY org.eclipse.mylyn.tasks.ui 4 0 2008-07-21 08:13:04.667
!MESSAGE Unable to execute early startup code for an extension
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in
org.eclipse.mylyn.tasks.ui was unable to load class
org.eclipse.mylyn.internal.tasks.ui.TasksUiPlugin$TasksUiSta rtup.
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .throwException(RegistryStrategyOSGI.java:180)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:162)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:867)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:267)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:52)
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:263)
org.eclipse.ui.internal.EarlyStartupRunnable.getExecutableEx tension(EarlyStartupRunnable.java:117)
org.eclipse.ui.internal.EarlyStartupRunnable.run(EarlyStartu pRunnable.java:66)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.ui.internal.Workbench$54.run(Workbench.java:2169 )
....more...
--------error------------
!STACK 1
Caused by:
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter $TerminatingClassNotFoundException:
An error occurred while automatically activating bundle
org.eclipse.mylyn.tasks.ui (730).
......more.....
---------third error-----------
Re: Mylyn 3.0.1 cannot view taskList [message #54240 is a reply to message #54161] |
Tue, 22 July 2008 03:46  |
....added the update sites
now it works perfect for me
thanks for fixing this bug in some hours :-)
ekke
Steffen Pingel schrieb:
> Thanks for filing the bug concerning the problems with 3.0.1 on Max OS X. I
> was able to reproduce it and have published a fixed version to the weekly
> update site (3.0.1.v20080721-2000):
> http://download.eclipse.org/tools/mylyn/update/weekly/e3.4
> http://download.eclipse.org/tools/mylyn/update/weekly/extras
> http://download.eclipse.org/tools/mylyn/update/weekly/incuba tor
> Ekke, John, it would be great if you could try this fix and respond on this
> bug report if it now works for you:
> 241524: tasks list view fails after 3.0.1 update
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=241524
> Thanks.
> Steffen
> ekke wrote:
>> thanks to P2 :-)
>> ... with a single click I reverted to the prev. configuration using
>> Mylyn 3.0.0,
>> because all my 3.0.1 fail and are not able to show the task List View
>> ekke
>> ekke schrieb:
>>> opened bugzilla https://bugs.eclipse.org/bugs/show_bug.cgi?id=241524
>>> ekke
>>> John Hawksley schrieb:
>>>> I'm also seeing this behaviour; it also causes the "task search"
>>>> search contribution to fail, I guess because the bundle is not loaded.
>>>> My config is identical:
>>>> Uname: Darwin Myrtle.local 9.4.0 Darwin Kernel Version 9.4.0: Mon Jun
>>>> 9 19:30:53 PDT 2008; root:xnu-1228.5.20~1/RELEASE_I386 i386
>>>> -John
>>>>> ekke
>>>>> !STACK 1
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
>>>>> ...more...
>>>>> !STACK 1
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> Caused by:
>>>>> .....more.....
Re: Mylyn 3.0.1 cannot view taskList [message #591598 is a reply to message #53761] |
Mon, 21 July 2008 05:28  |
I'm also seeing this behaviour; it also causes the "task search" search
Uname: Darwin Myrtle.local 9.4.0 Darwin Kernel Version 9.4.0: Mon Jun 9
-John
> ekke
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ...more...
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Caused by:
> .....more.....
Re: Mylyn 3.0.1 cannot view taskList [message #591623 is a reply to message #53789] |
Mon, 21 July 2008 08:49  |
ekke
> -John
>> ekke
>> !STACK 1
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ...more...
>> !STACK 1
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Caused by:
>> .....more.....
Re: Mylyn 3.0.1 cannot view taskList [message #591683 is a reply to message #53845] |
Mon, 21 July 2008 13:16  |
thanks to P2 :-)
.... with a single click I reverted to the prev. configuration using
Mylyn 3.0.0,
ekke
> ekke
>> -John
>>> ekke
>>> !STACK 1
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ...more...
>>> !STACK 1
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Caused by:
>>> .....more.....
Re: Mylyn 3.0.1 cannot view taskList [message #591739 is a reply to message #53934] |
Mon, 21 July 2008 18:12  |
Thanks.
Steffen
ekke wrote:
> thanks to P2 :-)
> Mylyn 3.0.0,
> ekke
>> ekke
>>> -John
>>>> ekke
>>>> !STACK 1
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ...more...
>>>> !STACK 1
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Caused by:
>>>> .....more.....
Re: Mylyn 3.0.1 cannot view taskList [message #591776 is a reply to message #54161] |
ekke
> Thanks.
> Steffen
> ekke wrote:
>> thanks to P2 :-)
>> Mylyn 3.0.0,
>> ekke
>>> ekke
>>>> -John
>>>>> ekke
>>>>> !STACK 1
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> ...more...
>>>>> !STACK 1
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> Caused by:
>>>>> .....more.....
FUDForum. Page generated in 0.04325 seconds
