Home » Language IDEs » AspectJ » changing method instance variables.
changing method instance variables. [message #53738] Sun, 19 June 2005 22:33 Go to next message
Originally posted by: ozkologlu.nowhere.com
Hi all,
I would like to change the instance variable of 'b' at the point indicated
'HERE' to be "new b string" _after_ returning.
If you are in Sydney CBD (in AU) a couple of free beers supplied for a
solution!
Oz
public class A {
String getString(B b) {
System.out.println( b.getString() ); // outputs "b string"
String s = C.getSomething( b ); // HERE: this is where i'd like
to change instance b after returning
System.out.println( b.getString() ); // should output "new b string"
return s;
// Main method
public static void main( String[] args ) {
A a = new A():
B b = new B("b string"));
System.out.println( a.getString( b )); //outputs "b string and c
string"
public class B {
String string;
public B( String string ) { this.string = string; }
public String getString() { return this.string; }
public class C {
public static String getSomething( B b ) { return b.getString() + " and
c string"; }
The aound(?) advice needs to do something like:
String around(B b) : execution ( * C.getSomething( B ) ) && target( b ){
String s = proceed( b );
if ( s.equals( "b string and c string" )) {
b = new B("new b string"); //this does not work since it only chages
the local reference
return s;
Re: changing method instance variables. [message #53769 is a reply to message #53738] Sun, 19 June 2005 23:42 Go to previous message
Sorry, should've posted this in aspectj instead
Oz
"Oz Kologlu" <ozkologlu@nowhere.com> wrote in message
news:d959ta$vb7$1@news.eclipse.org...
> Hi all,
> solution!
> Oz
> public class A {
> string"
> return s;
> // Main method
> A a = new A():
> string"
> public class B {
> String string;
> public class C {
> c string"; }
> chages the local reference
> return s;
Re: changing method instance variables. [message #588895 is a reply to message #53738] Sun, 19 June 2005 23:42 Go to previous message
Oz
> Hi all,
> solution!
> Oz
> public class A {
> string"
> return s;
> // Main method
> A a = new A():
> string"
> public class B {
> String string;
> public class C {
> c string"; }
> return s;
Previous Topic:changing method instance variables.
Next Topic:AJDT development build with updated AspectJ
Current Time: Mon Jul 21 22:11:48 EDT 2025
Powered by FUDForum. Page generated in 0.04121 seconds
