Home » Archived » XML Schema Definition (XSD) » Parsing Question
Parsing Question [message #53733] Tue, 28 September 2004 16:17 Go to next message
Originally posted by: jai.kejriwal.air2web.com
I need to do the following.
While the user edits some code in a workflow document (in XML) and is in the
process of adding a certain XML tag that corresponds to a variable defined
in a data definition file, I need my plugin to pop up a dialog box if it
cannot find that variable defined in the data definition file.
My guess is that I will need to have some kind of parser active while the
user is editing the workflow document that will search the list of variables
in the data defn. file once the user has finished typing the tag. I don't
know how to go about doing this.
Your help is highly appreciated.
Thanks.
Re: Parsing Question [message #53787 is a reply to message #53733] Wed, 29 September 2004 06:51 Go to previous message
Jai,
This question is completely unrelated to the XSD model, as far as I can
tell. I'm not sure why you are asking it here?
>Thanks.
Re: Parsing Question [message #591972 is a reply to message #53733] Wed, 29 September 2004 06:51 Go to previous message
Jai,
>Thanks.
Previous Topic:removing global elements from XSDSchema
Next Topic:Incremental update of the facet's list
Current Time: Sun Aug 31 07:50:01 EDT 2025
Powered by FUDForum. Page generated in 0.04126 seconds
