Home » Archived » Visual Editor (VE) » Need ve Help
| Need ve Help [message #53727] |
Mon, 02 August 2004 18:00  |
Need Help
I had errors trying to create a swing JDesktop so I figured I would test all
of the visual classes.
I am running the following on XP sp1:
Eclpse 3.0.0
ve 1.0M2
emf 2.0.0
gef 3.0.0
When I try to create a new visual class some are created others do not. Some
give me an error but still are created.
SWING Visual Classes
JFrame - ok
JApplet - ok
JInternalFrame - ok
JDialog - ok
JWindow - ok
JPanel - error "Creation of element failed" / see log ~ See no errors
JScrollPanel - error "Creation of element failed" / see log ~ See no errors
JSplitPanel - error "Creation of element failed" / see log ~ See no errors
JTabbedPanel - error "Creation of element failed" / see log ~ See no errors
JDesktopPane - error "Creation of element failed" /
org.eclipse.ve.internal.java.cogen.jjet.wizards.contributors .componentset
swtApplication - Creates object but on open has errors on SWT API
refferences:
org.eclipse.swt.widgets.Display
org.eclipse.swt.widgets.Shell
org.eclipse.swt.graphics.Point
AWT Visual Classes
Window - ok
ScrollPane - error "Creation of element failed" / see log ~ See no errors
Applet - error "Creation of element failed" / see log ~ See no errors
Dialog - error "Creation of element failed" / see log ~ See no errors
Frame - error "Creation of element failed" /
Thanks in Advance...
IchBin
_____________________________________________
'Black holes are where God divided by zero.'
-Steven Wright, comedian (1955- )
| Re: Need ve Help [message #54344 is a reply to message #54282] |
Wed, 04 August 2004 00:21   |
I created another Eclipse directory and load the following, in that order:
ECLIPSE_PLATFORM_SDK_3.0_WIN32
EMF_SDO_RUNTIME_2.0.0
GEF_RUNTIME_3.0
GEF_SDK_3.0
GEF_EXAMPLES_3.0
VE_RUNTIME_1.0M2
VE_SDK_1.0M2
VE_EXAMPLES_1.0M2
Started Eclipse -clear for each package above and enabled it, as I installed
it. All installed nd enabled with no problem
I basically ran the same test with the same results. This time I have one
exception and who caused it. That is, when I set the name for a new visual
class and tried to save it. Did not matter if running on 1.5 or 1.4 JDK.
Internal Error, STACK 0, java.lang.reflect.InvocationTargetException
Caused by: java.lang.AbstractMethodError:
org.eclipse.ve.internal.java.codegen.jjet.wizards.contributo rs.ComponentSetS
izeGenerator.generateSource
(Ljava/lang/String;Ljava/lang/String;Ljava/util/HashMap;)Lja va/lang/String;
Root exception:
izeGenerator.generateSource(Ljava/lang/String;Ljava/lang/Str ing;Ljava/util/H
ashMap;)Ljava/lang/String;
Below is the log file:
!SESSION Aug 03, 2004
23:32:34.534 ---------------------------------------------
eclipse.buildId=I200406251208
java.version=1.5.0-beta2
Command-line arguments: -clear
!ENTRY org.eclipse.core.resources 2 1 Aug 03, 2004 23:32:34.544
!MESSAGE Skipping builder
com.atlassw.tools.eclipse.checkstyle.CheckstyleBuilder for project
rwhois-client-1.6.1. Either the builder is missing from the install, or it
belongs to a project nature that is missing or disabled.
!ENTRY org.eclipse.core.resources 2 1 Aug 03, 2004 23:32:34.734
!MESSAGE Skipping builder org.eclipse.cdt.make.core.makeBuilder for project
!MESSAGE Skipping builder org.eclipse.cdt.make.core.ScannerConfigBuilder for
project rwhois-client-1.6.1. Either the builder is missing from the install,
or it belongs to a project nature that is missing or disabled.
!ENTRY org.eclipse.jdt.ui 4 10001 Aug 03, 2004 23:34:34.636
!MESSAGE Internal Error
!STACK 0
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:284)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 752)
org.eclipse.jdt.internal.ui.wizards.NewElementWizard.perform Finish(NewElemen
tWizard.java:115)
org.eclipse.ve.internal.java.codegen.wizards.NewVisualClassC reationWizard.pe
rformFinish(NewVisualClassCreationWizard.java:359)
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:609)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:305)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:506)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:796)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2772)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2431)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:668 )
at org.eclipse.jface.window.Window.open(Window.java:648)
org.eclipse.ui.internal.ide.NewWizardShortcutAction.run(NewW izardShortcutAct
ion.java:96)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:881 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(Action
ContributionItem.java:915)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionI
tem.java:866)
org.eclipse.jface.action.ActionContributionItem$7.handleEven t(ActionContribu
tionItem.java:785)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.
java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl
..java:25)
at java.lang.reflect.Method.invoke(Method.java:582)
at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
at org.eclipse.core.launcher.Main.run(Main.java:644)
at org.eclipse.core.launcher.Main.main(Main.java:628)
org.eclipse.ve.internal.java.codegen.wizards.NewVisualClassC reationWizard.ap
plyContributor(NewVisualClassCreationWizard.java:280)
org.eclipse.ve.internal.java.codegen.wizards.NewVisualClassC reationWizard.fi
nishPage(NewVisualClassCreationWizard.java:304)
org.eclipse.jdt.internal.ui.wizards.NewElementWizard$2.run(N ewElementWizard.
java:108)
org.eclipse.jdt.internal.core.BatchOperation.executeOperatio n(BatchOperation
..java:34)
org.eclipse.jdt.internal.core.JavaModelOperation.run(JavaMod elOperation.java
:700)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1673)
at org.eclipse.jdt.core.JavaCore.run(JavaCore.java:3246)
org.eclipse.jdt.internal.ui.actions.WorkbenchRunnableAdapter .run(WorkbenchRu
nnableAdapter.java:65)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext
..java:101)
Root exception:
java:108)
..java:34)
:700)
..java:101)
IchBin
| Re: Need ve Help [message #54649 is a reply to message #54623] |
Wed, 04 August 2004 19:15   |
Well at least that took the problem out of the ui modules.. It let me
create, add compomonents, save and reload. Different errors on loading new
saved class that was created (nJDialogPanel). Questions on how Eclipse
refreashes the user workspaces when new Eclipse modules are
download/installed.
An internal error occurred during: "Create Remote VM for Visual Editor for
Java".
org.eclipse.jdt.launching.sourcelookup.containers.JavaSource LookupParticipan
t.sourceContainersChanged(JavaSourceLookupParticipant.java:1 46)
org.eclipse.debug.core.sourcelookup.AbstractSourceLookupDire ctor.addParticip
ants(AbstractSourceLookupDirector.java:642)
org.eclipse.jdt.internal.launching.JavaSourceLookupDirector. initializePartic
ipants(JavaSourceLookupDirector.java:43)
org.eclipse.debug.core.sourcelookup.AbstractSourceLookupDire ctor.initializeD
efaults(AbstractSourceLookupDirector.java:518)
org.eclipse.debug.internal.core.LaunchConfiguration.initiali zeSourceLocator(
LaunchConfiguration.java:169)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfigurati
on.java:568)
on.java:150)
org.eclipse.jem.internal.proxy.core.ProxyLaunchSupport.start Implementation(P
roxyLaunchSupport.java:480)
roxyLaunchSupport.java:291)
roxyLaunchSupport.java:223)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup$C
reateRegistry.run(JavaVisualEditorPart.java:1330)
org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
Here's the Log Fle (unfortunetliy cleared the above log when createatng buy
below is when loading new class)
!ENTRY org.eclipse.core.runtime 4 2 Aug 04, 2004 18:44:37.699
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.core.runtime".
!STACK 0
org.eclipse.gef.ui.parts.TreeViewer$EventDispatcher.focusGai ned(TreeViewer.j
ava:76)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:104)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:820)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:801)
at org.eclipse.swt.widgets.Control.sendFocusEvent(Control.java: 1756)
at org.eclipse.swt.widgets.Control.WM_SETFOCUS(Control.java:413 9)
at org.eclipse.swt.widgets.Tree.WM_SETFOCUS(Tree.java:1935)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3032 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3338 )
at org.eclipse.swt.internal.win32.OS.SetFocus(Native Method)
at org.eclipse.swt.widgets.Control.forceFocus(Control.java:607)
at org.eclipse.swt.widgets.Control.setFocus(Control.java:2054)
at org.eclipse.swt.widgets.Composite.setFocus(Composite.java:44 7)
at org.eclipse.swt.widgets.Composite.setFocus(Composite.java:44 5)
at org.eclipse.ui.part.PageBookView.setFocus(PageBookView.java: 700)
at org.eclipse.ui.internal.WorkbenchPage$2.run(WorkbenchPage.ja va:471)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java
:615)
at org.eclipse.core.runtime.Platform.run(Platform.java:747)
org.eclipse.ui.internal.WorkbenchPage.activatePart(Workbench Page.java:468)
org.eclipse.ui.internal.WorkbenchPage.setActivePart(Workbenc hPage.java:2679)
at org.eclipse.ui.internal.WorkbenchPage.activate(WorkbenchPage .java:457)
org.eclipse.ui.internal.WorkbenchPage.busyShowView(Workbench Page.java:799)
org.eclipse.ui.internal.WorkbenchPage.busyShowView(Workbench Page.java:769)
at org.eclipse.ui.internal.WorkbenchPage.access$9(WorkbenchPage .java:754)
at org.eclipse.ui.internal.WorkbenchPage$13.run(WorkbenchPage.j ava:3008)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage .java:3005)
at org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage .java:2985)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.openVCE
ViewersIfRequired(JavaVisualEditorPart.java:413)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$22.run(
JavaVisualEditorPart.java:450)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:106)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:2749)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2434)
java:335)
..java:25)
!ENTRY org.eclipse.ui 4 4 Aug 04, 2004 18:44:37.799
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 Aug 04, 2004 18:44:37.819
!MESSAGE Failed to execute runnable (java.lang.NullPointerException)
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable
at org.eclipse.swt.SWT.error(SWT.java:2691)
at org.eclipse.swt.SWT.error(SWT.java:2616)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:109)
java:335)
..java:25)
!ENTRY org.eclipse.ui 4 4 Aug 04, 2004 18:44:37.829
!MESSAGE *** SWT nested exception
!ENTRY org.eclipse.ui 4 0 Aug 04, 2004 18:44:37.849
!MESSAGE java.lang.NullPointerException
!STACK 0
org.eclipse.gef.ui.parts.TreeViewer$EventDispatcher.focusLos t(TreeViewer.jav
a:79)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:108)
at org.eclipse.swt.widgets.Control.WM_KILLFOCUS(Control.java:36 14)
at org.eclipse.swt.widgets.Tree.WM_KILLFOCUS(Tree.java:1637)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:2999 )
at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:1462 )
at org.eclipse.swt.widgets.Shell.callWindowProc(Shell.java:398)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3050 )
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.j ava:1391)
at org.eclipse.swt.internal.win32.OS.BringWindowToTop(Native Method)
at org.eclipse.swt.widgets.Decorations.bringToTop(Decorations.j ava:180)
at org.eclipse.swt.widgets.Shell.open(Shell.java:757)
at org.eclipse.jface.window.Window.open(Window.java:644)
org.eclipse.jface.dialogs.MessageDialog.openError(MessageDia log.java:295)
org.eclipse.jface.util.SafeRunnable.handleException(SafeRunn able.java:52)
org.eclipse.core.internal.runtime.InternalPlatform.handleExc eption(InternalP
latform.java:349)
:617)
java:335)
..java:25)
!ENTRY org.eclipse.ui 4 4 Aug 04, 2004 18:44:48.224
!ENTRY org.eclipse.ui 4 0 Aug 04, 2004 18:44:48.244
!STACK 0
java:335)
..java:25)
!ENTRY org.eclipse.ui 4 4 Aug 04, 2004 18:44:48.254
!ENTRY org.eclipse.ui 4 0 Aug 04, 2004 18:44:48.274
!STACK 0
ava:76)
at org.eclipse.swt.widgets.Control.setSavedFocus(Control.java:2 279)
at org.eclipse.swt.widgets.Decorations.restoreFocus(Decorations .java:695)
at org.eclipse.swt.widgets.Decorations.WM_ACTIVATE(Decorations. java:1419)
at org.eclipse.swt.widgets.Shell.WM_ACTIVATE(Shell.java:1336)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:2969 )
at org.eclipse.swt.internal.win32.OS.SetForegroundWindow(Native Method)
at org.eclipse.swt.widgets.Shell.forceActive(Shell.java:564)
org.eclipse.ve.internal.jfc.core.FreeFormComponentsHostAdapt er$1.run(FreeFor
mComponentsHostAdapter.java:65)
java:335)
..java:25)
!ENTRY org.eclipse.core.runtime 4 2 Aug 04, 2004 18:44:52.660
!STACK 0
a:79)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.setFocu
s(JavaVisualEditorPart.java:2113)
:615)
org.eclipse.ui.internal.WorkbenchPage.requestActivation(Work benchPage.java:2
372)
at org.eclipse.ui.internal.PartPane.requestActivation(PartPane. java:304)
org.eclipse.ui.internal.EditorPane.requestActivation(EditorP ane.java:127)
at org.eclipse.ui.internal.PartPane.handleEvent(PartPane.java:2 84)
at org.eclipse.swt.widgets.Shell.setActiveControl(Shell.java:93 5)
at org.eclipse.swt.widgets.Shell.WM_MOUSEACTIVATE(Shell.java:14 61)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3009 )
at org.eclipse.swt.widgets.Scrollable.callWindowProc(Scrollable .java:77)
at org.eclipse.swt.internal.win32.OS.PeekMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.PeekMessage(OS.java:1881)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2426)
java:335)
..java:25)
IchBin
"Rich Kulp" <richkulp@NO.SPAM.us.ibm.com> wrote in message
news:cercp8$qoh$1@eclipse.org...
> Try this please:
> 1) Do you have plenty of diskspace? You aren't running tight are you?
> 2) Go to the \.metadata\.plugins\org.eclipse.ve.java.core\JetObjects
> directory under your workspace and clear out everything under the
> JetObjects directory. Then run it again and see if it works now.
> If it still fails, please send to me the file
\.metadata\.plugins\org.eclipse.ve.java.core\JetObjects\org\ eclipse\ve\inter
nal\java\codegen\jjet\wizards\contributors\ComponentSetS
> izeGenerator.class
> Send it my address as specified on this append but remove the .NO.SPAM.
> Thanks, Rich Kulp
| Re: Need ve Help [message #54853 is a reply to message #54772] |
Thu, 05 August 2004 14:03   |
Yes, I still get the error. Because of the nature I what I am testing. I
have the -clear option on the shortcut for right now. Yes, I was scratching
my head also at that. Reason: I did this the other day when I was testing.
I, once and only once, dropped a JTree into a visual object. Cold it be one
of the possible reasons?
I have a main workspace. Also have imported other workspaces that have other
projects. Not sure how to combine them other than import. I did not want to
spend time to dick-around with it. I really want like to physically combine
them. Initial, I thought that the import actually takes a copy, of the other
projects, and writes them to the target working workspace. It does not, and
I can understand that now. So maybe some transient stuff is being loaded? It
has to be. The JTree test object is long gone. The fact that you had me
drop that ui package, from underneath my .metadata subdirectory and
automatically made it reload all of the new updated code?
I did notice that I had my SET ECLIPSE_HOME to to my last Eclipse version
while I had the new one loaded and running. I have changed to the correct
dir. Also deleted my last Eclipse Dir.
May be I need to clean-up my .metadata sub.? If so., help me out on this,
create the same version stuff again but some how physically move my other
project to my working workspace??
IchBin
news:cetk99$5u4$1@eclipse.org...
> I can't figure out how those errors occurred. They were all centered
> around the Tree (BeansList) but that error should be impossible.
> However, if you closed the entire workbench and came back up again do
> you still get the error?
> Thanks, Rich Kulp
| Re: Need ve Help [message #55011 is a reply to message #54985] |
Thu, 05 August 2004 16:54   |
Well I rebuilt Eclipse with:
GEF_RUNTIME_3.0
GEF_SDK_3.0
GEF_EXAMPLES_3.0
VE_RUNTIME_1.0M2
VE_SDK_1.0M2
VE_EXAMPLES_1.0M2
Working in a new and clean workspace the vi worked, no problem. The only
two problems I saw was after creating:
1 -
- Created AWT Frame
- added some menu's. changed colors
- added a setvisible for the frame
- tried to run it.
- did not display, did not see it running in the the task manger.
- closed the class
- reopened into editor
- the running object display popped up real fast and disappeared.
- this is reproducible.
- closed down Eclipse
2-
- load Eclipse and the run of the running class popped up real fast( I had
the new coded loaded, in the editor, when I started up. I have it set that
way.
problem, I see two javaw tasks running and the visual object in the tabbed
processing bar, stuck. Could not open it nor close it with right click.
toolbar tip did not display either when hovering over it.
- if I close the editor the other pruning task closed.
- When I closed eclipse that attached running task closed also.
I then figured I would import one of my other workspace. I did and all
behavior was as if a new workspace.
IchBin
IchBin
"Ichbin" <weconsultants@epix.net> wrote in message
news:cetvhb$peq$1@eclipse.org...
> SORRY, DID not try with a new work space..... Will try. I was using my
old
> ones
> IchBin
> news:cett85$le1$1@eclipse.org...
> > Do you have problems with a brand new workspace and a clean Eclipse 3.0,
> > GEF, EMF, and VE only installation? I need to strip out any other
> > influences which could cause problems. I need to find out if it is your
> > system itself, or some other plugins you may have installed, or if it is
> > something left over in your workspace.
> > Thanks, Rich Kulp
| Re: Need ve Help [message #55084 is a reply to message #55011] |
Fri, 06 August 2004 10:43  |
> GEF_RUNTIME_3.0
> GEF_SDK_3.0
> GEF_EXAMPLES_3.0
> VE_RUNTIME_1.0M2
> VE_SDK_1.0M2
> VE_EXAMPLES_1.0M2
> 1 -
> - Created AWT Frame
> - tried to run it.
Did you use Launch Java Application or Launch Java Bean, if you used
Launch Application you need to add your own main that displays the
frame. If you used Launch Java Bean, is your class a subclass of AWT
Frame, or is it a subclass of Object that happens to have an AWT Frame
in it. If it is a subclass of AWT Frame, it should of worked. If it is a
subclass of Object, then you need code in a main to display the frame.
> - closed the class
What is a running object display? We do create the frame as a real
object, but it is at 10,000 x 10,000. It is way off screen. It is not
meant for users to interact with. That is why it is way off screen.
There should be a screen snapshot of it in the editor. That is what
users work with.
> 2-
> way.
It is normal to have other javaw's running for the VE. We have one
running per project, and another one running per editor. The one per
project is so that we can do bean introspection to find the properties.
The one per editor is where we instantiate all of the beans that are
displayed in the editor. We need to use separate VM's because we can't
run them in the VM of the IDE.
Thanks, Rich Kulp
| Re: Need ve Help [message #596521 is a reply to message #53727] |
Mon, 02 August 2004 18:43  |
There has to be something in the .log. Could you please append it?
Thanks, Rich Kulp
| Re: Need ve Help [message #596561 is a reply to message #53780] |
Tue, 03 August 2004 10:20  |
There is nothing in the log which relates to the VE. However all of the
errors except for the last one (which was because you tried to do an
update configuration and that failed) have to do with some weird
configuration problem. It was trying to add a plugin to the registry, I
think, and was getting errors. Do you have any other plugins installed
other then the default ones required by VE?
I have no idea why it doesn't come up. There should of been more errors
than that.
Thanks, Rich Kulp
| Re: Need ve Help [message #596609 is a reply to message #54069] |
Tue, 03 August 2004 14:14  |
Rich, the truncated lib name
" org.eclipse.ve.internal.java.cogen.jjet.wizards.contributors .componentset "
error is of no consequence. After the error I did find the new source
created but no gui displayed at the top of panel in the source edit panel.
The only thing that might be a problem is that I have WindowBuilder Pro
installed but does not come up in /Manage Features/Product Features window.
If I /New/Other/New Wizards/ I do see a "Designer Folder" for the
"WindowBuilder Pro - SWT and Swing Development" plugin? Plus I have Jigloo
SWT/Swing GUI Builder installed. The second one should not be a problem and
it works. Sorry, I am looking for a nice GUI builder and this is why I have
them. Just test'im them out. I like the one in Netbeans and JDeveloper.
I this point I guess I could do either of two things:
1 - Rebuild a new Eclipse base and leave the GUI builders out and test.
2. Disable the other GUI builders and test. This option seems to be a
problem because the WindowBuilder Pro seems to be out of wrack. I was up on
Eclipse 3.0.1 but had to many problems so I started new with the 3.0.0.
base. While at 3.0.1 I did see WindowBuilder Pro as a registered feature
plugin but not now.
I guess I should back down off of Java 1.5.0 beta 2 to the lastest 1.4 SDK.
I noticed some othere error's with 1.5.0, arddress execptions in one of
dated.log files in the features subdirectory. Just want to have Eclipse to
run as stable as Netbeans and JDeveloper.
Rich, do you think this is the right approach? If I rebuild.. is there a
sequece to instal all of the components I currently have now. Especially
Eclipse. I notice I had to reinstal the Eclipse windows rutime twice because
of error when I loaded Eclpse. Even with the -clean option.
These are the other plugins I have in Installed product configuration.
Clay Database Modeling Core edition 1.0.5
Eclipse C/C++ Development Tooling SDK 2.0.0
Jigloo SWT/Swing GUI Builder
net.java.sqlexplorer 2.2.2
I figured I would show you all of the modules an the features and plugin
directories.
FEATURES.....
com.cloudgarden.jigloo_2.7.2
com.ibm.wtp.common.utilities_1.0.0
com.ibm.wtp.emf.integration.core_1.0.0
jp.azzurri.clay.core_1.0.5
net.java.sqlexplorer_2.2.2
org.eclipse.cdt_2.0.0
org.eclipse.cdt.sdk_2.0.0
org.eclipse.cdt.source_2.0.0
org.eclipse.emf_2.0.0
org.eclipse.emf.ecore.sdo_2.0.0
org.eclipse.gef_3.0.0
org.eclipse.gef.examples_3.0.0
org.eclipse.gef.sdk_3.0.0
org.eclipse.gef.source_3.0.0
org.eclipse.jdt_3.0.0
org.eclipse.jdt.source_3.0.0
org.eclipse.jem_1.0.0
org.eclipse.jem.sdk_1.0.0
org.eclipse.jem.source_1.0.0
org.eclipse.pde_3.0.0
org.eclipse.pde.source_3.0.0
org.eclipse.platform_3.0.0
org.eclipse.platform.source_3.0.0
org.eclipse.sdk_3.0.0
org.eclipse.sdk.examples_3.0.0
org.eclipse.team.extras_3.0.0
org.eclipse.ve_1.0.0
org.eclipse.ve.examples_1.0.0
org.eclipse.ve.sdk_1.0.0
org.eclipse.ve.source_1.0.0
PLUGINS........
com.atlassw.tools.eclipse.checkstyle_3.4.1
com.ibm.etools.emf.event_3.0.0.1
com.ibm.wtp.common.util_1.0.0
com.ibm.wtp.emf.workbench_1.0.0
com.swtdesigner_2.0.1
com.swtdesigner.fragment.jdt.core_2.0.1
com.swtdesigner.help_2.0.1
jp.azzurri.clay.ui_1.0.5
jp.azzurri.clay.ui.jdbc_1.0.5
org.apache.ant_1.6.1
org.apache.lucene_1.3.0
org.eclipse.ant.core_3.0.0
org.eclipse.ant.ui_3.0.0
org.eclipse.cdt.core_2.0.0
org.eclipse.cdt.core.win32_2.0.0
org.eclipse.cdt.debug.core_2.0.0
org.eclipse.cdt.debug.mi.core_2.0.0
org.eclipse.cdt.debug.mi.ui_2.0.0
org.eclipse.cdt.debug.ui_2.0.0
org.eclipse.cdt.doc.user_2.0.0
org.eclipse.cdt.launch_2.0.0
org.eclipse.cdt.make.core_2.0.0
org.eclipse.cdt.make.ui_2.0.0
org.eclipse.cdt.managedbuilder.core_2.0.0
org.eclipse.cdt.managedbuilder.ui_2.0.0
org.eclipse.cdt.source.win32.win32.x86_2.0.0
org.eclipse.cdt.ui_2.0.0
org.eclipse.compare_3.0.0
org.eclipse.compare.examples_3.0.0
org.eclipse.compare.examples.xml_3.0.0
org.eclipse.core.boot_3.0.0
org.eclipse.core.expressions_3.0.0
org.eclipse.core.filebuffers_3.0.0
org.eclipse.core.resources_3.0.0
org.eclipse.core.resources.win32_3.0.0
org.eclipse.core.runtime_3.0.0
org.eclipse.core.runtime.compatibility_3.0.0
org.eclipse.core.variables_3.0.0
org.eclipse.debug.core_3.0.0
org.eclipse.debug.ui_3.0.0
org.eclipse.draw2d_3.0.0
org.eclipse.draw2d.doc.isv_3.0.0
org.eclipse.emf.codegen_2.0.0
org.eclipse.emf.codegen.ecore_2.0.0
org.eclipse.emf.codegen.ecore.ui_2.0.0
org.eclipse.emf.codegen.ui_2.0.0
org.eclipse.emf.common_2.0.0
org.eclipse.emf.common.ui_2.0.0
org.eclipse.emf.commonj.sdo_2.0.0
org.eclipse.emf.ecore_2.0.0
org.eclipse.emf.ecore.change_2.0.0
org.eclipse.emf.ecore.change.edit_2.0.0
org.eclipse.emf.ecore.edit_2.0.0
org.eclipse.emf.ecore.editor_2.0.0
org.eclipse.emf.ecore.sdo.edit_2.0.0
org.eclipse.emf.ecore.sdo.editor_2.0.0
org.eclipse.emf.ecore.xmi_2.0.0
org.eclipse.emf.edit_2.0.0
org.eclipse.emf.edit.ui_2.0.0
org.eclipse.emf.mapping_2.0.0
org.eclipse.emf.mapping.ecore2ecore_2.0.0
org.eclipse.emf.mapping.ecore2ecore.editor_2.0.0
org.eclipse.emf.mapping.ui_2.0.0
org.eclipse.gef.doc.isv_3.0.0
org.eclipse.gef.examples.flow_3.0.0
org.eclipse.gef.examples.logic_3.0.0
org.eclipse.gef.examples.source_3.0.0
org.eclipse.help_3.0.0
org.eclipse.help.appserver_3.0.0
org.eclipse.help.base_3.0.0
org.eclipse.help.examples.ex1_3.0.0
org.eclipse.help.ide_3.0.0
org.eclipse.help.ui_3.0.0
org.eclipse.help.webapp_3.0.0
org.eclipse.jdt.core_3.0.0
org.eclipse.jdt.debug_3.0.0
org.eclipse.jdt.debug.ui_3.0.0
org.eclipse.jdt.doc.isv_3.0.0
org.eclipse.jdt.doc.user_3.0.0
org.eclipse.jdt.junit_3.0.0
org.eclipse.jdt.junit.runtime_3.0.0
org.eclipse.jdt.launching_3.0.0
org.eclipse.jdt.ui_3.0.0
org.eclipse.jdt.ui.examples.projects_3.0.0
org.eclipse.jem.beaninfo_1.0.0
org.eclipse.jem.proxy_1.0.0
org.eclipse.jem.ui_1.0.0
org.eclipse.jem.workbench_1.0.0
org.eclipse.jface_3.0.0
org.eclipse.jface.text_3.0.0
org.eclipse.ltk.core.refactoring_3.0.0
org.eclipse.ltk.ui.refactoring_3.0.0
org.eclipse.osgi_3.0.0
org.eclipse.osgi.services_3.0.0
org.eclipse.osgi.util_3.0.0
org.eclipse.pde.build_3.0.0
org.eclipse.pde.core_3.0.0
org.eclipse.pde.doc.user_3.0.0
org.eclipse.pde.junit.runtime_3.0.0
org.eclipse.pde.runtime_3.0.0
org.eclipse.pde.ui_3.0.0
org.eclipse.platform.doc.isv_3.0.0
org.eclipse.platform.doc.user_3.0.0
org.eclipse.platform.source.win32.win32.x86_3.0.0
org.eclipse.sdk.examples.source_3.0.0
org.eclipse.sdk.examples.source.win32.win32.x86_3.0.0
org.eclipse.search_3.0.0
org.eclipse.swt_3.0.0
org.eclipse.swt.examples_3.0.0
org.eclipse.swt.examples.browser_3.0.0
org.eclipse.swt.examples.controls_3.0.0
org.eclipse.swt.examples.launcher_3.0.0
org.eclipse.swt.examples.layouts_3.0.0
org.eclipse.swt.examples.ole.win32_3.0.0
org.eclipse.swt.examples.paint_3.0.0
org.eclipse.swt.win32_3.0.0
org.eclipse.team.core_3.0.0
org.eclipse.team.cvs.core_3.0.0
org.eclipse.team.cvs.ssh_3.0.0
org.eclipse.team.cvs.ssh2_3.0.0
org.eclipse.team.cvs.ui_3.0.0
org.eclipse.team.examples.filesystem_3.0.0
org.eclipse.team.extras.source_3.0.0
org.eclipse.team.ftp_3.0.0
org.eclipse.team.ui_3.0.0
org.eclipse.team.webdav_3.0.0
org.eclipse.text_3.0.0
org.eclipse.tomcat_4.1.30
org.eclipse.ui_3.0.0
org.eclipse.ui.cheatsheets_3.0.0
org.eclipse.ui.console_3.0.0
org.eclipse.ui.editors_3.0.0
org.eclipse.ui.examples.javaeditor_3.0.0
org.eclipse.ui.examples.multipageeditor_2.1.0
org.eclipse.ui.examples.propertysheet_2.1.0
org.eclipse.ui.examples.readmetool_2.1.0
org.eclipse.ui.externaltools_3.0.0
org.eclipse.ui.forms_3.0.0
org.eclipse.ui.ide_3.0.0
org.eclipse.ui.intro_3.0.0
org.eclipse.ui.presentations.r21_3.0.0
org.eclipse.ui.views_3.0.0
org.eclipse.ui.win32_3.0.0
org.eclipse.ui.workbench_3.0.0
org.eclipse.ui.workbench.compatibility_3.0.0
org.eclipse.ui.workbench.texteditor_3.0.0
org.eclipse.update.configurator_3.0.0
org.eclipse.update.core_3.0.0
org.eclipse.update.core.win32_3.0.0
org.eclipse.update.scheduler_3.0.0
org.eclipse.update.ui_3.0.0
org.eclipse.ve.cde_1.0.0
org.eclipse.ve.doc_1.0.0
org.eclipse.ve.examples.source_1.0.0
org.eclipse.ve.java.core_1.0.0
org.eclipse.ve.jfc_1.0.0
org.eclipse.ve.propertysheet_1.0.0
org.eclipse.ve.swt_1.0.0
org.eclipse.webdav_3.0.0
org.junit_3.8.1
IchBin
news:ceo6ql$mo9$1@eclipse.org...
> than that.
> Thanks, Rich Kulp
| Re: Need ve Help [message #596632 is a reply to message #54232] |
Tue, 03 August 2004 20:01  |
Just to make sure that it is the other plugins causing the problem I
recommend a straight Eclipse SDK, GEF, EMF, and VE with no other
plugins. That will tell you if there is something wrong with your system
other than the other plugins. If this works, then add the other plugins
in one at a time (doing a -clean option each time to clear the plugin
registry cache) and see which one breaks it.
Also, go back to 1.4. JDT doesn't support 1.5 completely yet, and we
have never tested the VE under 1.5.
Thanks, Rich Kulp
| Re: Need ve Help [message #596661 is a reply to message #54282] |
GEF_RUNTIME_3.0
GEF_SDK_3.0
GEF_EXAMPLES_3.0
VE_RUNTIME_1.0M2
VE_SDK_1.0M2
VE_EXAMPLES_1.0M2
Root exception:
!STACK 0
tWizard.java:115)
ion.java:96)
tem.java:866)
tionItem.java:785)
java:335)
..java:25)
java:108)
..java:34)
:700)
..java:101)
Root exception:
java:108)
..java:34)
:700)
..java:101)
IchBin
| Re: Need ve Help [message #596752 is a reply to message #54344] |
Wed, 04 August 2004 15:20  |
Try this please:
\.metadata\.plugins\org.eclipse.ve.java.core\JetObjects\org\ eclipse\ve\internal\java\codegen\jjet\wizards\contributors\C omponentSetS
izeGenerator.class
Thanks, Rich Kulp
| Re: Need ve Help [message #596760 is a reply to message #54623] |
download/installed.
Java".
on.java:568)
on.java:150)
!STACK 0
ava:76)
:615)
java:335)
..java:25)
!STACK 0
java:335)
..java:25)
!STACK 0
a:79)
latform.java:349)
:617)
java:335)
..java:25)
!STACK 0
java:335)
..java:25)
!STACK 0
ava:76)
java:335)
..java:25)
!STACK 0
a:79)
:615)
372)
java:335)
..java:25)
IchBin
> Try this please:
> izeGenerator.class
> Thanks, Rich Kulp
| Re: Need ve Help [message #596793 is a reply to message #54649] |
Thu, 05 August 2004 11:40  |
Thanks, Rich Kulp
| Re: Need ve Help [message #596825 is a reply to message #54772] |
IchBin
> Thanks, Rich Kulp
| Re: Need ve Help [message #596843 is a reply to message #54853] |
Thu, 05 August 2004 14:13  |
Thanks, Rich Kulp
| Re: Need ve Help [message #596863 is a reply to message #54880] |
Thu, 05 August 2004 14:24  |
I am 98% sure that was the enviroment I was testing... Could try again. I
did have the problem posted in post: Re: Designtime: Components don't show
up. This was when I had the EMF examles installed before now but works now.
IchBin
> Thanks, Rich Kulp
| Re: Need ve Help [message #596874 is a reply to message #54880] |
Thu, 05 August 2004 14:52  |
SORRY, DID not try with a new work space..... Will try. I was using my old
ones
IchBin
> Thanks, Rich Kulp
| Re: Need ve Help [message #596881 is a reply to message #54985] |
GEF_RUNTIME_3.0
GEF_SDK_3.0
GEF_EXAMPLES_3.0
VE_RUNTIME_1.0M2
VE_SDK_1.0M2
VE_EXAMPLES_1.0M2
1 -
- Created AWT Frame
- tried to run it.
- closed the class
2-
way.
IchBin
IchBin
old
> ones
> IchBin
> > Thanks, Rich Kulp
| Re: Need ve Help [message #596927 is a reply to message #55011] |
> GEF_RUNTIME_3.0
> GEF_SDK_3.0
> GEF_EXAMPLES_3.0
> VE_RUNTIME_1.0M2
> VE_SDK_1.0M2
> VE_EXAMPLES_1.0M2
> 1 -
> - Created AWT Frame
> - tried to run it.
> - closed the class
users work with.
> 2-
> way.
Thanks, Rich Kulp
Current Time: Tue Nov 04 19:08:38 EST 2025
Powered by FUDForum. Page generated in 0.08464 seconds
