Home » Archived » M2M (model-to-model transformation) » [ATL] In-place transformation/refine/copy whole model?
[ATL] In-place transformation/refine/copy whole model? [message #53724] Fri, 20 July 2007 01:51 Go to next message
Hi All,
I need to create a transformation that repeats (copies) modelA, with some
exceptions to few elements.
Preferably, I'd like it to be an in-place transformation.
Is that possible with ATL? How?
Thanks in Advance,
- Leila
Re: [ATL] In-place transformation/refine/copy whole model? [message #53808 is a reply to message #53724] Fri, 20 July 2007 05:54 Go to previous messageGo to next message
Originally posted by: Hugo.Bruneliere.univ-nantes.fr
Leila a écrit :
> Hi All,
Hi Leila,
> some exceptions to few elements.
In ATL 2004 (i.e. the previous major version of ATL), there is a
"refining" mode which allows defining refinement transformations by only
specifying rules concerning the elements to modify. See the appropriate
section 3.1.2.2 in the user manual:
http://www.eclipse.org/m2m/atl/doc/ATL_User_Manual%5Bv0.7%5D .pdf
I think this is what you want to do.
However, ATL 2006 (i.e. the current version of ATL) does not yet support
this "refining" mode. So you will have to precise in your transformation
that you want to use the ATL 2004 compiler (see
http://wiki.eclipse.org/ATL_2006).
> Thanks in Advance,
> - Leila
Hugo
Hugo Bruneliere - R&D Engineer
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssiniere
44322 Nantes Cedex 3 - France
office +33 2 51 12 58 10 /\ cell.+33 6 07 42 45 30
EMail: Hugo.Bruneliere@univ-nantes.fr
http://www.sciences.univ-nantes.fr/lina/atl/
Re: [ATL] In-place transformation/refine/copy whole model? [message #54112 is a reply to message #53808] Fri, 20 July 2007 13:10 Go to previous messageGo to next message
Hi Hugo,
Thanks for the quick response. Is there a particular ATL/Eclipse versions
I should be using to be able to change the compilers?
I'm trying to put that comment : -- @atlcompiler atl2004 and still get
error : 'unexpected token : refines'.
I could try to use an older version, but which one u suggest? :)
Thanks again,
- Leila
Re: [ATL] In-place transformation/refine/copy whole model? [message #54244 is a reply to message #54112] Mon, 23 July 2007 03:46 Go to previous message
Originally posted by: quentin.glineur.obeo.fr
--------------020101080904080409040003
The correct word for the refining mode is "refining" and not "refines"
(documentation bug that will be soon corrected)
Quentin GLINEUR
Leila a
Previous Topic:[ATL] problem with UML2 metamodel
Next Topic:[M2M - QVT] Where is the Borland Initial Code contribution
Current Time: Sat Jul 12 19:12:54 EDT 2025
Powered by FUDForum. Page generated in 0.03955 seconds
