Problem with Schema details [message #4771] |
Wed, 02 November 2005 23:36  |
Originally posted by: subhash.bhushan.gmail.com
Hi all,
I am currently using the latest eclipse.datatools plugin, with Oracle 10g.
I
am able to connect to the database successfully, and the tree structure
displays all the schemas in the database connected to. But I am not able
to view any objects in the schemas.
Is this a bug, or am is any configuration wrong?
I am using Eclipse 3.1 (JBoss IDE), with JRE 1.5.
Thanks in advance,
Subhash Bhushan.
Re: Problem with Schema details - Plugin list [message #4980 is a reply to message #4910] |
Thu, 03 November 2005 11:53   |
"John Graham" <jograham@sybase.com> wrote in message
news:e68cd8b0c45abca4c53cef3964a0e067$1@www.eclipse.org...
> Subhash Bhushan wrote:
> > Here is the list of plugins that I have...
> > org.eclipse.datatools.connectivity.db.generic_0.0.2
> > org.eclipse.datatools.connectivity.ui_0.0.2
> > org.eclipse.datatools.connectivity_0.0.2
> > org.eclipse.datatools.modelbase.dbdefinition_0.7.0
> > org.eclipse.datatools.modelbase.edit_0.7.0
> > org.eclipse.datatools.modelbase.sql_0.7.0
> > Thanks and Regards,
> > Subhash Bhushan.
> Subhash,
> The generic JDBC connection profile is not yet integrated with the SQL
> model, so this is the expected outcome at this time (please refer to
> http://www.eclipse.org/newsportal/article.php?id=142&gro up=eclipse.dtp#142
> for details). Once the integration is complete (watch for an iteration
> build announcement about this), then you will be able to see the expected
> contents.
> John Graham
> Eclipse Data Tools Platform PMC
John,
Thank you very much for the input.
Though I have enough and more enthusiasm to join you in your endeavor, I do
not have the time to dedicate for the task. But I promise to play the
Devil's Advocate by supplying you with ample reports of bugs.
Wishing you guys all the best in your race against time,
Hope to join you sometime in the near future,
Thanks and Regards,
Subhash Bhushan.
Re: Problem with Schema details - Plugin list [message #5047 is a reply to message #4980] |
Thu, 03 November 2005 17:21  |
> John,
> Thanks and Regards,
> Subhash Bhushan.
Subhash,
We welcome Devil's Advocates, to whatever extent of time they can
contribute to DTP! :-)
Looking forward to working with you to insure that DTP meets the feature
and quality expectations of the community.
John Graham
Problem with Schema details - Plugin list [message #568045 is a reply to message #4771] |
Wed, 02 November 2005 23:39  |
Thanks and Regards,
Subhash Bhushan.
Re: Problem with Schema details - Plugin list [message #568092 is a reply to message #4841] |
Thu, 03 November 2005 10:19  |
> Thanks and Regards,
> Subhash Bhushan.
Subhash,
contents.
John Graham
Re: Problem with Schema details - Plugin list [message #568125 is a reply to message #4910] |
> > Thanks and Regards,
> > Subhash Bhushan.
> Subhash,
> contents.
> John Graham
John,
Thanks and Regards,
Subhash Bhushan.
Re: Problem with Schema details - Plugin list [message #568152 is a reply to message #4980] |
> John,
> Thanks and Regards,
> Subhash Bhushan.
Subhash,
John Graham
FUDForum. Page generated in 0.26878 seconds
