Home » Language IDEs » Java Development Tools (JDT) » Multiple ClasspathContainers, Settings
Multiple ClasspathContainers, Settings [message #53679] Tue, 10 June 2003 04:17 Go to next message
Originally posted by: j.verschoor.nefli.nl
I've created a LibraryFolderClasspathContainer, but now I've stumbled into a
problem:
Sometimes, you maybe would like to specify more than 1 folder.
Right now I've solved this problem by getting the contents of both folders.
Maybe someone has a better solution for this.
Also, I was wondering where to store the info of the classpath.
Right now I'm doing javaProject.setOption(), and before that a call to
JavaModelManager.OptionNames.add() with my own preference id.
This works, but I don't like it.
Any help would be appreciated. Btw, where can I submit my code for eclipse?
Joris Verschoor
Re: Multiple ClasspathContainers, Settings [message #55274 is a reply to message #53679] Thu, 12 June 2003 09:08 Go to previous messageGo to next message
any one?
"Joris Verschoor" <j.verschoor@nefli.nl> wrote in message
news:bc43vm$smn$1@rogue.oti.com...
> Hello,
a
> problem:
folders.
eclipse?
> Joris Verschoor
Re: Multiple ClasspathContainers, Settings [message #56736 is a reply to message #55274] Fri, 13 June 2003 13:58 Go to previous messageGo to next message
To quickly answer the question about how to submit code:
Create a bug report and add your code as an attachment.
File it to JDT-UI and I'll have a look at it; we are interested to add
folder containers to JDT!
Martin
Joris Verschoor wrote:
> any one?
>>Hello,
> a
>>problem:
> folders.
> eclipse?
>>Joris Verschoor
Re: Multiple ClasspathContainers, Settings [message #58329 is a reply to message #56736] Mon, 16 June 2003 05:28 Go to previous messageGo to next message
Ok, I'll file a bug report + attachement later this day. I don't have the
code near me.
"Martin Aeschlimann" <martin_aeschlimann@ch.ibm.com> wrote in message
news:3EEA10E0.7030202@ch.ibm.com...
> Thanks
> Martin
> > any one?
> >>Hello,
into
> > a
> >>problem:
> > folders.
> > eclipse?
> >>Joris Verschoor
Re: Multiple ClasspathContainers, Settings [message #61479 is a reply to message #58329] Thu, 19 June 2003 03:31 Go to previous messageGo to next message
Well, my internet connection at home (Chello) is down for a couple of days.
Hopefully I'll get online again this weekend. If so, I'll also create a
seperate plugin here. Does anybody have any preference of the classname? the
JREClasspathContainer is in org.eclipse.jdt.launching or something..
news:bck2du$ntr$1@rogue.oti.com...
> code near me.
> > Thanks
> > Martin
> > > any one?
> > >>Hello,
> into
> > > a
> > >>problem:
> > > folders.
> > > eclipse?
> > >>Joris Verschoor
Re: Multiple ClasspathContainers, Settings [message #63863 is a reply to message #53679] Sat, 21 June 2003 08:27 Go to previous messageGo to next message
Here's a version for all of you to check out, just unpack in your eclpise
folder.
I've created a bug 39198 and submitted the code.
There are a few things left to do:
-short cut for browse
-refactor to another package
-the container only supports folders from the current project, I don't know
if others would like to be able to choose folders from other projects, but I
didn't.. But if anybody wants that, let me know.
Re: Multiple ClasspathContainers, Settings [message #68747 is a reply to message #63863] Fri, 27 June 2003 09:11 Go to previous message
Awesome -- I think the best use of this would be to be able to create a
reusable library folder of external stuff that any project could include.
(For example, all of the gazillion jars needed to work with weblogic portal
Thanks!
-- Scott
"Joris Verschoor" <j.verschoor@insomniq.com> wrote in message
news:bd1iv4$78p$1@rogue.oti.com...
> folder.
know
I
Previous Topic:How to use plug ins
Next Topic:Accessing Eclipse Classpath Variables in Ant Scripts
Current Time: Fri Jul 18 01:38:14 EDT 2025
Powered by FUDForum. Page generated in 0.51394 seconds
