Home » Eclipse Projects » Plugin Development Environment (PDE) » Strange dependency cycle error
Strange dependency cycle error [message #53662] Mon, 06 April 2009 10:28 Go to next message
When trying to export our RCP, we're getting a dependency cycle error,
saying PluginD > PluginU > PluginD.
The odd thing is, we can't find any dependency from PluginU to PluginD.
I've got the plugin dependency visualizer and it doesn't find any such
path; I've examined each of PluginU's dependencies and can't find any
that depend on PluginD.
I can not reference any of PluginD's classes from code in PluginU.
If I open the Plug-in Dependencies view, root it at PluginD, and set it
to show dependent plugins, it does list PluginU, but there is definitely
no reference to PluginD in PluginU's manifest.
Any hints on how to track down the source of this seemingly phantom
dependency cycle?
TIA,
Eric
Re: Strange dependency cycle error [message #53688 is a reply to message #53662] Mon, 06 April 2009 10:29 Go to previous messageGo to next message
Maybe PluginD is a fragment for PluginC? Just a wild guess...
Stefan.
> dependency cycle?
> TIA,
> Eric
Re: Strange dependency cycle error [message #53713 is a reply to message #53662] Mon, 06 April 2009 10:46 Go to previous messageGo to next message
> dependency cycle?
Another data point: Using the "Look for cycles in the dependency graph"
link on the Dependencies tab does not find any (tried for both plugins).
Eric
Re: Strange dependency cycle error [message #53736 is a reply to message #53688] Mon, 06 April 2009 10:47 Go to previous messageGo to next message
Thanks, but neither of these is a fragment or hosts any fragments.
>> PluginD. I've got the plugin dependency visualizer and it doesn't find
>> any such path; I've examined each of PluginU's dependencies and can't
>> find any that depend on PluginD.
>> it to show dependent plugins, it does list PluginU, but there is
>> definitely no reference to PluginD in PluginU's manifest.
>> dependency cycle?
>> TIA,
>> Eric
Re: Strange dependency cycle error [message #53790 is a reply to message #53736] Mon, 06 April 2009 11:04 Go to previous messageGo to next message
I had that once, too and it also drove me nuts for hours. In the end it helped to close and reopen the projects... Give it a try!
Michael
PS.: Sometimes the caching of data should be really forbidden!
Re: Strange dependency cycle error [message #53818 is a reply to message #53713] Mon, 06 April 2009 11:36 Go to previous messageGo to next message
Does perhaps PluginU depend on some other PluginZ which is re-exporting
packages from PluginD. (And PluginU also imports the packages it exports).
If you are brave and really stuck, you can try running the export under
a debugger to see how build reached the cycle.
1) In a different workspace, import org.eclipse.pde.build
2) Set a breakpoint in ClasspathComputer3_0.getClasspath when the
BundleDescription#getSymbolicName is PluginU
3) Launch a self-hosted debug instance, you can point the workspace at
your normal workspace
4) Export the product, step through the classpath resolution
Cycles are detected in addPrerequisites, you'll be interested in the
recursive loop between addPrerequisites and addPluginAndPrerequisites.
The call to PDEState.getDependentBundles is how we get the dependencies.
-Andrew
>> dependency cycle?
> Eric
Re: Strange dependency cycle error [message #53891 is a reply to message #53736] Mon, 06 April 2009 14:26 Go to previous messageGo to next message
I spoke too soon; I had forgotten that our unit tests are located in
fragments (and since they don't have a fragment.xml, only a manifest.mf,
I didn't find them when I looked).
Turns out that one of the unit test fragments is hosted by PluginU, and
a new test had recently been added that depends on PluginD. Hence the cycle.
Looks like this is a bug or gap in functionality in the Dependency
Visualization, which I'll report. But does anyone else think that PDE
should do something to alert you to this problem before an export is
attempted and in a more useful way?
Eric
>>> dependency cycle?
>>> TIA,
>>> Eric
Re: Strange dependency cycle error [message #54048 is a reply to message #53891] Tue, 07 April 2009 03:35 Go to previous messageGo to next message
Eric,
that's why, fragments where my first thought. Actually, I fixed a bug in
Dependency Visualizer concerning fragments some days ago - however, if
it still persists with current CVS head, please reopen 270864.
Stefan.
> cycle.
> Eric
Re: Strange dependency cycle error [message #54098 is a reply to message #54048] Tue, 07 April 2009 12:03 Go to previous messageGo to next message
On 4/7/2009 3:35 AM, Stefan Roeck wrote:
> Eric,
I'm using version 0.1.0.20071004 that I installed from
http://download.eclipse.org/eclipse/pde/incubator/visualizat ion/site
So I won't be seeing any recent changes. Since we're on the topic, is
there any plan to do a new build of the visualizer and make it available
on the update site?
>> manifest.mf, I didn't find them when I looked).
>> and a new test had recently been added that depends on PluginD. Hence
>> the cycle.
>> Eric
Re: Strange dependency cycle error [message #54125 is a reply to message #54098] Wed, 08 April 2009 00:28 Go to previous message
> on the update site?
We're working on a new build and the plan is to make it available on the
"update site" :)
Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465
http://twitter.com/eclipsesource | http://twitter.com/caniszczyk
Re: Strange dependency cycle error [message #594660 is a reply to message #53662] Mon, 06 April 2009 10:29 Go to previous message
Stefan.
> dependency cycle?
> TIA,
> Eric
Re: Strange dependency cycle error [message #594675 is a reply to message #53662] Mon, 06 April 2009 10:46 Go to previous message
> dependency cycle?
Eric
Re: Strange dependency cycle error [message #594684 is a reply to message #53688] Mon, 06 April 2009 10:47 Go to previous message
>> dependency cycle?
>> TIA,
>> Eric
Re: Strange dependency cycle error [message #594701 is a reply to message #53736] Mon, 06 April 2009 11:04 Go to previous message
Michael
Re: Strange dependency cycle error [message #594706 is a reply to message #53713] Mon, 06 April 2009 11:36 Go to previous message
-Andrew
>> dependency cycle?
> Eric
Re: Strange dependency cycle error [message #594728 is a reply to message #53736] Mon, 06 April 2009 14:26 Go to previous message
Eric
>>> dependency cycle?
>>> TIA,
>>> Eric
Re: Strange dependency cycle error [message #594764 is a reply to message #53891] Tue, 07 April 2009 03:35 Go to previous message
Eric,
Stefan.
> cycle.
> Eric
Re: Strange dependency cycle error [message #594780 is a reply to message #54048] Tue, 07 April 2009 12:03 Go to previous message
> Eric,
on the update site?
>> the cycle.
>> Eric
Re: Strange dependency cycle error [message #594789 is a reply to message #54098] Wed, 08 April 2009 00:28 Go to previous message
> on the update site?
"update site" :)
Previous Topic:How is eclipse tested and built periodically?
Next Topic:Project & editor creation
Current Time: Sat Nov 08 23:06:54 EST 2025
Powered by FUDForum. Page generated in 0.08067 seconds
