| [ATL] model modification possible? [message #53621] | Thu, 19 July 2007 15:01  |  |
| Eclipse User  |  |  |  |  | Hi,
 after reading some parts of the user manual and searching in the
 newsgroup I could not find out if it is possible or practical to modify
 (refactoring in my case) a model directly without creating a new one.
 Did I miss something? If I understand the refining execution mode
 correctly it still creates a new model copying the elements that have
 not been touched.
 In my case I can have a huge model where duplicating it is not an option.
 What do you think?
 Bye,
 Sandro
| Re: [ATL] model modification possible? [message #54061 is a reply to message #54016] | Fri, 20 July 2007 12:18  |  |
| Eclipse User  |  |  |  |  | Hello Hugo,
 Hugo Bruneliere schrieb:
 > Sandro Böhme a écrit :
 > Hi Sandro,
 >> modify (refactoring in my case) a model directly without creating a
 >> new one. Did I miss something?
 > ATL always creates an new output model (or several) from a given input
 > model (or several). There are no ways to directly modify the input model.
 that's too bad, because I would be glad to work with ATL. E.g. stepping
 through a transformation and seeing the actual values using a debugger
 is a nice feature.
 Anyway, thanks for your feedback. It's good to know that.
 >> If I understand the refining execution mode correctly it still creates
 >> a new model copying the elements that have not been touched.
 >> What do you think?
 > Using the "refining" mode seems to be a good idea in your case since you
 > will only have to specify the rules concerning the elements to modify.
 > Note that this "refining" mode is only supported, for the time being, by
 > the ATL 2004 compiler (and not by the ATL 2006 one).
 In my case I would like to modify a model backed by a JCR
 ( http://en.wikipedia.org/wiki/Content_repository_API_for_Java) for JCR
 Management (http://www.eclipse.org/emft/projects/jcrm/). Such a
 repository could be too big to get duplicated.
 Sandro
FUDForum. Page generated in 0.30445 seconds
