Creating OCL Expressions [message #53573] |
Sun, 06 April 2008 12:06  |
Originally posted by: sebstation.freenet.de
Hallo all!
I have a simple problem (I think). I have build an editor, using the GMF
Framework. The editor is used for building other diagrams.
He really works fine and so on... Now my problem is, i want to use
integrate OCL in the following way.
I want to define constraints via Ocl expressions. That means:
With my editor i make a diagram. Then i want to use OCL Expressions to
make constraints on that diagram.
I realize it with a field, where you can write in the Ocl Expression.
Now to the problem:
What i get from the field is a String.
1. How can i convert this string to an OCL Expression?
2. How can i validate this Expression after i convert him?
I know, it sounds not so complicated and i donŽt know, why i donŽt get it,
but iŽll hope you can help me.
Ciao,
Hank
Re: Creating OCL Expressions [message #53600 is a reply to message #53573] |
Mon, 07 April 2008 09:12  |
Hi, Hank,
The two most important pieces of the OCL parsing puzzle are the OCL text,
itself (which it sounds like you already have) and the *context* in which
to parse that expression.
The context is one of:
- for invariant constraints, a classifier
- in the Ecore metamodel, some kind of EClassifier
- in the UML metamodel, some kind of Classifier
- for operation pre/post/body conditions, an operation
- Ecore EOperation or UML Operation
- for attribute initial-value or derivation expressions, a property
- Ecore EStructuralFeature or UML Property
Then, just use the org.eclipse.ocl.OCL/org.eclipse.ocl.helper.OCLHelper API
to parse your constraint expression in the appropriate context, using the
EnvironmentFactory implementation for your metamodel. See the Tutorial and
other documentation in the OCL SDK's on-line help for details of how to get
started with the parsing API.
I don't know whether the metamodel for your GMF editor is Ecore, UML, or
some DSL of your own. If the latter, then you will have to implement a
metamodel binding for your metamodel to teach the OCL parser how to
introspect your metamodel to find the UML/EMOF concepts that OCL
understands. The "Advanced Topics" in the SDK docs discuss this, and of
course the existing org.eclipse.ocl.{ecore,uml} plug-ins provide examples
of metamodel bindings.
HTH,
Christian
Hank Thomas wrote:
> Hallo all!
> Now to the problem:
> Ciao,
> Hank
FUDForum. Page generated in 0.02928 seconds
