Home » Eclipse Projects » Equinox » How does the extension registry handle multiple versions of the same plugin?
How does the extension registry handle multiple versions of the same plugin? [message #53552] Fri, 25 November 2005 09:51 Go to next message
Hi All,
I'm trying to figure out how the extension registry handles multiple versions of the same plugin?
That is, suppose an Eclipse-based application currently has two different versions of the same plugin installed and the same
extension is registered by both plugins. The two extensions are configured differently by the two plugins.
Does Eclipse simply use the extension and configuration from the plugin with the highest version number?
TIA,
ted stockwell
Re: How does the extension registry handle multiple versions of the same plugin? [message #53605 is a reply to message #53552] Sun, 27 November 2005 10:14 Go to previous message
Originally posted by: pascal.ibm.canada
Only bundles that are marked as singleton can contribute to the
extension registry. Therefore this problem does not occur.
ted stockwell wrote:
> Hi All,
> different versions of the same plugin installed and the same extension
> TIA,
> ted stockwell
Previous Topic:launch my eclipse RCP-APP just using Equinox not the EclipseStater
Next Topic:relative library paths to jars outside of plugins
Current Time: Sun Aug 31 01:53:08 EDT 2025
Powered by FUDForum. Page generated in 0.08379 seconds
