Can't run SWT [message #53509] |
Mon, 18 April 2005 08:27  |
Originally posted by: jaschulz.wiseware.com
I have the problem everybody complains about:
Exception in thread "main" java.lang.UnsatisfiedLinkError: no
swt-win32-3064 in java.library.path
I have:
-Djava.library.path=C:\eclipse\plugins\org.eclipse.swt.win32 _3.0.2\os\win32\x86\
in the VM Argument
I have tried copying both:
swt-awt-win32-0364.dll
and
swt-win32-0364.dll
to WINDOWS/SYSTEM32
I have even tried setting the default path to include:
C:\eclipse\plugins\org.eclipse.swt.win32_3.0.2\os\win32\x86\
All to no avail!
What am I supposed to do now?
JAS
Re: Can't run SWT [message #54080 is a reply to message #53509] |
Mon, 18 April 2005 19:09   |
Try this.... -yuchen
Thanks!! It works now, I copied the dlls to the system32 dir. -yu
"Eric Clayberg" <clayberg@instantiations.com> wrote in message
news:d39jsl$1oj$1@news.eclipse.org...
> "Yu Chen" <yuchen@bea.com> wrote in message
> news:d375ds$d8k$1@news.eclipse.org...
>>I saw people had similar problem, and I also unjar the following jar file
>>from the plugins\. But I still got the same error, I can see the 3128.dll
>>file is in the java.library.path, but it just can not be found from the
>>simple swt program, what's wrong, any ideas??
>>> I had a similar problem with 3.1M6 where it couldn't find the swt dll to
>>> run my SWT application. The dll is in the swt jar. I copied the dll
>>> out of the jar into a directory on the library path so it could be found
>>> and then the application would run.
> Under M6, you need to extract the three DLLs from the new
> org.eclipse.swt.win32_3.1.0.jar file and copy them to your
> windows/system32 directory (or somewhere else on yoru path).
> You should then be able to use "Run As > Java Application" to run them.
> Don't use "Run As > SWT Application" as that is broken in M6.
> -Eric Clayberg
> Sr. Vice President of Product Development
> Instantiations, Inc.
> http://www.instantiations.com
> http://www.swt-designer.com
> Author: "Eclipse: Building Commercial Quality Plug-ins"
> http://www.awprofessional.com/title/0321228472
"James A. Schulz" <jaschulz@wiseware.com> wrote in message
news:d409hm$a6b$1@news.eclipse.org...
> I have:
> in the VM Argument
> and
> swt-win32-0364.dll
> to WINDOWS/SYSTEM32
> All to no avail!
> JAS
Re: Can't run SWT [message #54215 is a reply to message #54080] |
Mon, 18 April 2005 21:25   |
I had read Eric's message and tried his suggestion, but it didn't work.
James
>>-Eric Clayberg
>>I have:
>>in the VM Argument
>>and
>>swt-win32-0364.dll
>>to WINDOWS/SYSTEM32
>>All to no avail!
>>Thanks,
>>JAS
Re: Can't run SWT [message #67896 is a reply to message #59931] |
Mon, 23 May 2005 19:15  |
Originally posted by: johnjunk.servicemachines.com
I re-did the whole thing from scratch. Then made a change suggested here to
change the VM Arguments to:
-Djava.library.path=C:\eclipse/plugins/org.eclipse.swt.win32 _3.0.2/os/win32/x86
and it finally ran.
JOhn
news:d4u846$dc1$1@news.eclipse.org...
> I've been away for a week, but I am still struggling with this problem.
> I am trying to use Eclipse 3.0.2 and so the proper dll's are 3064. I just
> can't imagine that I am the only one who has this problem Doesn't anybody
> know how to make 3.0.2 work with SWT?
> James
> James Leotta wrote:
>> James A. Schulz wrote:
>>> James,
>>> There are only two dll's in my x86 folder:
>>> swt-awt-win32-3064.dll
>> Should be 3123.dll not 3064 you have older verion. Download from the
>> bottom of the M6 download page.
>>> and
>>> swt-win32-3064.dll
>>> Where to I find the third dll to which you refer?
>>> James
>>> James Leotta wrote:
>>>> There are three dll's that go into the system32 directory. If you are
>>>> in eclipse you need to recheck the items you have in the run tab and
>>>> make sure they are not running as a swtapp but a java app. This became
>>>> broken in the new release and will be repaired in the next.
>>>>> Hasan:
>>>>> Could it be that I have this problem because I am using jkk1.5.0_02?
>>>>> James
>>>>> Hasan wrote:
>>>>>> I really don't know. I have spent 3 #@$!@# days to make it work.
>>>>>> This is what I did:
>>>>>> *Install eclipse 3.0.2 instead of 3.1M6. You can uninstall easily by
>>>>>> removing the eclipse folder from your computer. No registry values
>>>>>> are changed.
>>>>>> *Install eclipse directly to my harddisk: C:\eclipse\..........
>>>>>> *For the standalone SWT App in the tutorial fill in:
>>>>>> Make sure your java settings are correct:
>>>>>> I've installed j2sdk1.4.2_08 on my C disk.
>>>>>> Then I've set the PATH (configuration screen > system > advanced TAB
>>>>>> > environment variables) to C:\j2sdk1.4.2_08\bin
>>>>>> (There can be more than one item separated by ";")
>>>>>> For the CLASSPATH I've filled in a "." (dot).
>>>>>> And know it works. I know that what i've wrote is basic but this is
>>>>>> all I have done. Good luck.
FUDForum. Page generated in 0.10690 seconds
