Home » Eclipse Projects » Technology Project and PMC » Java code reformatting question
Java code reformatting question [message #53459] Wed, 30 April 2003 11:43 Go to next message
Originally posted by: no.email.please.com
[Is eclipse.technology the right newsgroup for this kind of question?
How come there is no "eclipse.jdt" newsgroup?]
When I format (Ctrl-Shift-f) my code, the following:
new Foo("abc", "def", "ghi")
is turned into
new Foo(
"abc",
"def",
"ghi"
.... which I don't like very much. I'd rather have something a little bit
more space efficient.
I looked at the Code formatter options but I didn't see where this is
defined. Can Eclipse do that or do I need to install a plug-in? (does
Jalopy support this kind of customization?)
Cedric
http://beust.com/weblog
Re: Java code reformatting question [message #53486 is a reply to message #53459] Wed, 30 April 2003 11:47 Go to previous messageGo to next message
Cedric, I would repost to eclipse.tools.jdt
Darins
"Cedric Beust" <no.email@please.com> wrote in message
news:Xns936D58EA977A0noemailpleasecom@204.138.98.10...
> is turned into
> new Foo(
> "abc",
> "def",
> "ghi"
> Cedric
Re: Java code reformatting question [message #53513 is a reply to message #53459] Wed, 30 April 2003 12:08 Go to previous messageGo to next message
Originally posted by: faust.acm.org
This newsgroup is deprecated.
See eclipse.tools.jdt
> is turned into
> new Foo(
> "abc",
> "def",
> "ghi"
Not yet. I think Jalopy does support this.
Randy
Re: Java code reformatting question [message #53539 is a reply to message #53459] Wed, 30 April 2003 12:31 Go to previous messageGo to next message
Originally posted by: Olivier_Thomann.ca.ibm.comNOSPAM
On Wed, 30 Apr 2003 15:43:43 +0000 (UTC), Cedric Beust
Hi Cedric,
eclipse.jdt is more appropriate for java code formatter question. This
kind of settings is in the works for the new formatter. We plan to
completely change the actual formatter. There are simply too many
problems and the one you have is just one of them :-(.
The solution for now is to use another formatter like Jalopy.
Olivier
Re: Java code reformatting question [message #53564 is a reply to message #53459] Thu, 01 May 2003 09:55 Go to previous message
> is turned into
> new Foo(
> "abc",
> "def",
> "ghi"
That only happens when the line is longer than the max line length.
You can increase this value in Window-> Preferences,
Java->Code formatter: tab Line splitting.
> Cedric
Re: Java code reformatting question [message #593391 is a reply to message #53459] Wed, 30 April 2003 11:47 Go to previous message
Darins
> is turned into
> new Foo(
> "abc",
> "def",
> "ghi"
> Cedric
Re: Java code reformatting question [message #593411 is a reply to message #53459] Wed, 30 April 2003 12:08 Go to previous message
> is turned into
> new Foo(
> "abc",
> "def",
> "ghi"
Randy
Re: Java code reformatting question [message #593428 is a reply to message #53459] Wed, 30 April 2003 12:31 Go to previous message
Hi Cedric,
Olivier
Re: Java code reformatting question [message #593441 is a reply to message #53459] Thu, 01 May 2003 09:55 Go to previous message
> is turned into
> new Foo(
> "abc",
> "def",
> "ghi"
> Cedric
Previous Topic:Java code reformatting question
Next Topic:minimal workbench?
Current Time: Sun Aug 31 07:54:04 EDT 2025
Powered by FUDForum. Page generated in 0.04343 seconds
