Home » Archived » XML Schema Definition (XSD) » XSDSchema.resolveTypeDefinition on redefined schema
XSDSchema.resolveTypeDefinition on redefined schema [message #53285] Fri, 24 September 2004 21:55 Go to next message
Originally posted by: jtaylor.nextance.com
If SchemaA defines TypeA and SchemaB redefines TypeA, should calling
SchemaB.resolveTypeDefinition(TypeA.getName()) return the new redefined
type? It appears to return the old original definition. Same thing for
other named components. Is this correct? Is there something else I can
call to get the redefined type? I notice that if I iterator over all
global types, the redefined type is there.
Also, if I programmatically add a type to be redefined (with
incrementalUpdate set to true), there does not seem to be any effect until
after I call XSDSchema.update(). Is this expected?
James
Re: XSDSchema.resolveTypeDefinition on redefined schema [message #53394 is a reply to message #53285] Mon, 27 September 2004 07:58 Go to previous messageGo to next message
James,
Resolve should work correctly for redefines, otherwise we could not
build the instance correctly.
Once a name has resolved, it won't reresolve, even if you add a
redefinition that it should resolve to, unless you force an update.
>Thanks,
> James
Re: XSDSchema.resolveTypeDefinition on redefined schema [message #53472 is a reply to message #53394] Mon, 27 September 2004 14:09 Go to previous messageGo to next message
Ed,
In my scenario, I'm programmatically creating a schema, adding a redefine
schema directive, and adding a complex type to the redefine content with a
new element declaration. I then do an update on the new schema. However,
even after this, the resolveTypeDefinition call returns the original type
instead of the redefined type. Both types are present in the list of
global types, though. Perhaps if the entire set of schemas was re-parsed
the resolution would be correct. Would you like me to open a bug and
attach a test case?
Also, regarding the manual update, which schema(s) should I perform this
on? Only the newly created schema, or do I need to do it recursively on
all included schemas too? Thanks,
James
Ed Merks wrote:
> James,
> >Thanks,
> > James
Re: XSDSchema.resolveTypeDefinition on redefined schema [message #53525 is a reply to message #53472] Mon, 27 September 2004 15:39 Go to previous messageGo to next message
--------------020608090609000507080204
James,
Yes, a test case would help. Even if it's not a bug, at least I'll
know what's going on and can suggest another approach. It sounds like
something that won't work well because once an include/redefine has been
processed, if you change it and want it to be processed again, there's
really nothing in place to remove/undo the effect of the previous
include/redefine. For example, if you've processed a redefine but now
you've added another thing to be redefined, nothing will remove the
original definition to replace it with its redefinition.
Doing the update() directly on the schema that's changed and possibly on
any downstream schemas that depend on it should do the trick.
James Taylor wrote:
>Ed,
>attach a test case?
> James
>Ed Merks wrote:
>>James,
>>>Thanks,
>>> James
<html>
<head>
http-equiv="Content-Type">
<title></title>
</head>
James,<br>
<br>
Re: XSDSchema.resolveTypeDefinition on redefined schema [message #53578 is a reply to message #53525] Mon, 27 September 2004 23:52 Go to previous message
I filed bug #75139 and attached my test case. Thanks,
James
Ed Merks wrote:
> James,
> James Taylor wrote:
> >Ed,
> >attach a test case?
> > James
> >Ed Merks wrote:
> >>James,
> >>>Thanks,
> >>> James
Re: XSDSchema.resolveTypeDefinition on redefined schema [message #591758 is a reply to message #53285] Mon, 27 September 2004 07:58 Go to previous message
James,
>Thanks,
> James
Re: XSDSchema.resolveTypeDefinition on redefined schema [message #591807 is a reply to message #53394] Mon, 27 September 2004 14:09 Go to previous message
Ed,
attach a test case?
James
Ed Merks wrote:
> James,
> >Thanks,
> > James
Re: XSDSchema.resolveTypeDefinition on redefined schema [message #591842 is a reply to message #53472] Mon, 27 September 2004 15:39 Go to previous message
James,
James Taylor wrote:
>Ed,
>attach a test case?
> James
>Ed Merks wrote:
>>James,
>>>Thanks,
>>> James
<html>
<head>
<title></title>
</head>
James,<br>
<br>
Re: XSDSchema.resolveTypeDefinition on redefined schema [message #591869 is a reply to message #53525] Mon, 27 September 2004 23:52 Go to previous message
James
Ed Merks wrote:
> James,
> James Taylor wrote:
> >Ed,
> >attach a test case?
> > James
> >Ed Merks wrote:
> >>James,
> >>>Thanks,
> >>> James
Previous Topic:Delete an Element
Next Topic:How to get resolvedModelGroupDefinition()?
Current Time: Sun Jul 27 01:21:14 EDT 2025
Powered by FUDForum. Page generated in 0.26256 seconds
