Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » <jav:merge> EMF rules
<jav:merge> EMF rules [message #53266] |
Tue, 26 September 2006 12:27  |
<java:merge> tag uses the emf rules URL . I dont have any idea of whats
an EMF rule is all about . Can one one tell me whats that and how to do
that ( any ref documentation will be good) . Is this covered as part of
EMF book ( i hav ordered one :-) )
Re: <jav:merge> EMF rules [message #53344 is a reply to message #53266] |
Tue, 26 September 2006 12:40   |
Since you mention the EMF book, the JMerge rules are summarized pretty well
in section 9.9 Customizing Generated Classes, pp 210-212.
Basically, if you have used the EMF code generator, you are familiar with
the JMerge rules:
1) the generator emitts classes, methods and fields with a Java doc comment
including @generated
2) to modify the element (and not have it obliterated next time you code
generate), you remove or deface the @generated tag.
By default, <java:merge> uses the same rules as the EMF code generator. To
use it effectively, you should insert @generated tags in the Java doc of all
classes, methods and fields you generate in .java files that you expect
users to modify. You don't need @generated tags on methods you one-time
generate, nor in Java files that are not for user editing (you shouldn't use
java:merge in this case - you always want to overwrite).
Writing custom JMerge rules is a more complex task. IBM Developerworks as a
starter article on the subject:
http://www-128.ibm.com/developerworks/library/os-ecemf3/
"Kamesh Sampath" <kamesh_sampath@msn.com> wrote in message
news:efbkdl$ol5$2@utils.eclipse.org...
> <java:merge> tag uses the emf rules URL . I dont have any idea of whats an
> EMF rule is all about . Can one one tell me whats that and how to do that
> ( any ref documentation will be good) . Is this covered as part of EMF
Re: <jav:merge> EMF rules [message #53398 is a reply to message #53344] |
Tue, 26 September 2006 12:49  |
thanks paul .
> the JMerge rules:
Re: <jav:merge> EMF rules [message #592218 is a reply to message #53266] |
Tue, 26 September 2006 12:37  |
Kamesh,
And no, the book does not cover this in detail, however it describes the
code generation patterns and describes how merging works in order to
update the results after you regenerate. It's all really quite simple,
especially if you follow the patterns used by EMF, in which case you can
just reuse the emf-merge.xml in org.eclipse.emf.codegen.ecore/templates.
> whats an EMF rule is all about . Can one one tell me whats that and
> how to do that ( any ref documentation will be good) . Is this covered
> as part of EMF book ( i hav ordered one :-) )
Re: <jav:merge> EMF rules [message #592224 is a reply to message #53266] |
the JMerge rules:
Re: <jav:merge> EMF rules [message #592242 is a reply to message #53344] |
thanks paul .
> the JMerge rules:
Current Time: Sat Jul 26 14:03:21 EDT 2025
Powered by FUDForum. Page generated in 0.26667 seconds
