| Generating FOP-compatible .fo files? [message #53261] |
Sat, 02 July 2005 20:48  |
Does Birt support the ability to generate FOP-compatible .fo files?
I have configured the Birt RunAndRenderTask to use FORenderOption
options with the TailoredForFOP option set to true. Using the generated
..fo file (15.fo in the example below), I try to convert it to a PDF
using FOP v0.20.5 from command line. The errors below occur.
I then hand-modified the .fo file to remove the "text-transform",
"word-spacing", and "letter spacing" tags from the file, which removed
the first 6 errors. The ClassCastException remains.
Help?
D:\FOP\fop-0.20.5>fop.bat -fo 15.fo -print -d
[DEBUG] Input mode:
[DEBUG] FO
[DEBUG] fo input file: 15.fo
[DEBUG] Output mode:
[DEBUG] print directly
[DEBUG] OPTIONS
[DEBUG] no user configuration file is used [default]
[DEBUG] debug mode on
[DEBUG] dump configuration
[DEBUG] quiet mode on
[INFO] Using org.apache.xerces.parsers.SAXParser as SAX2 Parser
[INFO] base directory: file:/D:/FOP/fop-0.20.5/
[INFO] FOP 0.20.5
[INFO] building formatting object tree
[INFO] setting up fonts
[ERROR] property - "text-transform" is not implemented yet.
[ERROR] Error in letter-spacing property value 'normal':
org.apache.fop.fo.expr.PropertyException: No conversion defined
[ERROR] property - "word-spacing" is not implemented yet.
[INFO] [1]
[ERROR] null
org.apache.fop.apps.FOPException
at org.apache.fop.apps.PrintStarter.run(PrintStarter.java:125)
at org.apache.fop.apps.Fop.main(Fop.java:62)
java.lang.ClassCastException
org.apache.fop.fo.flow.BlockContainer.layout(BlockContainer. java:157)
at org.apache.fop.fo.flow.Block.layout(Block.java:257)
org.apache.fop.fo.flow.AbstractFlow.layout(AbstractFlow.java :154)
org.apache.fop.fo.flow.AbstractFlow.layout(AbstractFlow.java :110)
org.apache.fop.fo.pagination.PageSequence.makePage(PageSeque nce.java:400)
org.apache.fop.fo.pagination.PageSequence.format(PageSequenc e.java:338)
org.apache.fop.apps.StreamRenderer.render(StreamRenderer.jav a:262)
org.apache.fop.fo.FOTreeBuilder.endElement(FOTreeBuilder.jav a:223)
org.apache.xerces.parsers.AbstractSAXParser.endElement(Unkno wn Source)
org.apache.xerces.impl.XMLNSDocumentScannerImpl.scanEndEleme nt(Unknown
Source)
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$Fragme ntContentDispatcher.dispatch(Unknown
Source)
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDo cument(Unknown
Source)
at org.apache.xerces.parsers.DTDConfiguration.parse(Unknown Source)
at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown
Source)
at org.apache.fop.apps.Driver.render(Driver.java:498)
at org.apache.fop.apps.PrintStarter.run(PrintStarter.java:120)
Source)
Source)
Source)
Source)
| Re: Generating FOP-compatible .fo files? [message #54991 is a reply to message #53566] |
Thu, 07 July 2005 19:49  |
Sorry about the delay. Please see bug #103106 for example report
design, generated .fo file, and test case.
Stanley Wang wrote:
> Please submit a bug including your report, and necessary data to
> reproduce the problem. Thanks.
> Stanley Wang
> BIRT Engine
>> generated .fo file (15.fo in the example below), I try to convert it
>> to a PDF using FOP v0.20.5 from command line. The errors below occur.
>> Help?
>> [DEBUG] Input mode:
>> [DEBUG] FO
>> [DEBUG] OPTIONS
>> [INFO] FOP 0.20.5
>> [INFO] [1]
>> [ERROR] null
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> Source)
>> Source)
>> Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> Source)
>> Source)
>> Source)
FUDForum. Page generated in 0.03416 seconds
