Home » Modeling » GMF (Graphical Modeling Framework) » is it possible for multiple plugins to contribute to the same editor?
is it possible for multiple plugins to contribute to the same editor? [message #53212] Thu, 21 September 2006 13:31 Go to next message
Originally posted by: liam.morley.baesystems.com
I've been reading in the help section that multiple plugins can contribute
to the palette. However, I've been looking at the Logic example, and it
seems to have everything you can add at the top level from the
EditPartProvider. Is it possible to add shapes to a diagram from different
plugins? Where should I be looking for this kind of thing?
Liam Morley
Re: is it possible for multiple plugins to contribute to the same editor? [message #53263 is a reply to message #53212] Thu, 21 September 2006 16:52 Go to previous message
Liam,
You can add geoshapes to a logic diagram example. The geoshapes palette
items, editparts, views, etc. are all contributed by the
org.eclipse.gmf.runtime.diagram.ui.geoshapes plugin.
Cherie
> Liam Morley
Previous Topic:How impl "xsd:choice" model constraint ?
Next Topic:How to remove Zoom palette entry ?
Current Time: Fri Nov 21 00:23:11 EST 2025
Powered by FUDForum. Page generated in 0.06010 seconds
