Home » Eclipse Projects » Equinox » Equinox Goals - Abstracting Libraries for External Use
| Equinox Goals - Abstracting Libraries for External Use [message #4699] |
Fri, 28 February 2003 00:59  |
Originally posted by: joetoth.comcast.net
Equinox caught my eye because recently I needed a source code generation
library and I remembered eclipse has a great library for AST, compiling,
etc. So, I decided to rip out one of the libs that included this
functionality. This lib wanted another, then another.
Then when I wanted to create a CompilationUnit, it complained about
wanting IPlugin something. So unfortunately I couldn't use this.
(I was able to use IDOMCompilationUnit, but this had very limited
functionality - Next I need to support minor scripting, eclipse libs for
syntax highlighting autocompletion, etc would be great!)
My point being, eclipse, an open source project has many great apis. If
equinox can expand the scope of these APIs beyond the IDE environment,
these APIs will be used in alot more applications and inherintly via the
open source model they'll become more versatile, stable and faster.
It would be good if each plugin had 2 level.
1 being core functionality
2 using that functionality to interoperate between each plugin
Or maybe something like apache's commons project where they create
libraries separate from the projects that use them.
To play with eclipse, I wrote a sql plugin
http://easysql.sourceforge.net/ a while back.
I remember SWT was written so that it can be used how I'm describing.
Will a goal of Equinox be abstracting out libraries for external use?
Example being the source code generation and compilation.
Joseph Toth
| Re: Equinox Goals - Abstracting Libraries for External Use [message #4768 is a reply to message #4699] |
Fri, 28 February 2003 10:49   |
Originally posted by: jeff_mcaffer_REMOVE.ca.ibm.com
Joseph,
This is not a stated goal of Equinox. Can you outline what you think could
be done in Equinox to solve the problem?
Jeff
"Joseph Toth" <joetoth@comcast.net> wrote in message
news:b3ms3q$mjo$1@rogue.oti.com...
> Joseph Toth
| Re: Equinox Goals - Abstracting Libraries for External Use [message #4974 is a reply to message #4768] |
Fri, 28 February 2003 15:13   |
Jeff McAffer wrote:
> Joseph,
> Jeff
>>Thanks,
>>Joseph Toth
Off the top of my head, here are 2 things that can be done in Equinox:
1. Plugin doesn't have to depend on any static variables,
eg. Plugin doesn't take Workbench as a parameter but, it would take only
the components required to interface with.
2. Plugin would need documentation on how to use outside of eclipse.
a. What interfaces need to be implemented for the other libraries
you are using. - eg. How CompilationUnit will interact with Swing.
Taking an approach like this would give the most flexibility to "broaden
the range of Eclipse platform runtime configurations", plus incorporate
my goal of using eclipse libraries externally. But of course, this
means more intelligent abstracting and more coding.
I'm just throwing this out there since this is an early stage in the
Equinox project. Even though external libraries are out of the scope,
the work that will be done here seems like external libraries can become
an inherent benefit of Equinox, if the approach is correct.
Joseph Toth
| Re: Equinox Goals - Abstracting Libraries for External Use [message #5315 is a reply to message #4974] |
Sun, 02 March 2003 15:53   |
I was chatting about this with some folks around here and other than best
practices or raising awareness, there does not seem to be much one could do
to the architecture/implementation of Eclipse platform to resolve this
issue.
Basically you are trying to use a library in a scenario for which it was not
designed. Separating out the parts of Eclipse that don't really need
Eclipse is a good idea but it is work and the plugin authors need to see a
reason to do it. Some will, some won't.
Jeff
p.s., the part about broadening the scope of Eclipse means broadening the
places where the *eclipse platform* is run/used. Your scenario seeks to use
random parts of Eclipse and explicitly not run the platform. That is
somewhat at odds with Equinox and Eclipse in general. Note also that SWT is
a special case. It has (and always has had) a life outside of Eclipse. The
Eclipse IU is based on SWT. SWT has never been based on Eclipse.
news:3E5FC2FA.8000504@comcast.net...
> Joseph Toth
| Re: Equinox Goals - Abstracting Libraries for External Use [message #6045 is a reply to message #5315] |
Mon, 03 March 2003 11:12   |
Originally posted by: ogruber.us.ibm.com
True that the desire does not match what Eclipse was designed for...
but it demonstrates a deceptively strong limitation of the current Eclipse
architecture and design. While Eclipse seems to promote modularity
through plug-ins, I would argue that its modularity is very much limited
in terms of alternate grouping of functionality or alternate
implementations.
I would argue that this is due to three original design mistakes:
1) Everything is a plug-in, even libraries which know nothing about
extensions
2) Dependencies are on plug-ins, not APIs
3) APIs are packaged with their implementation
Point (1) results in Eclipse being a bit monolithic. The platform considers
everything
a plug-in, even what is really just a library. So this does not promote the
idea
that some library could be developed, deployed, and used as Java library
independently of Eclipse, at least workspace and worbench.
Point (2) and (3) make things worse by making plug-ins dependent on
plug-ins,
and combining APIs and implementation. This does not help controlling
dependencies and the overall feeling that the entire download from
eclipse.org is necessary to run. Many plug-ins do a great job at defining a
clean API, but the implementation drags in dependencies... so because
I require the entire plug-in, I am requiring the transitive closure...
For instance, someone may want to promote its on Java compiler, but
reuse all the interfaces of Eclipse JDT compiler. Or someone may want
to propose an alternate workbench, maybe for smaller devices, leveraging
not only different layout options but also allowing different widget
toolkits...
but this is impossible although the workbench UI does a great job at
defining interfaces for its extension points (such as interfaces in
org.eclipse.ui).
So you are technically right about best practices... and the limitations of
a
platform to enforce modularity... but the current approach for dependencies
and packaging, as well as the monolithic platform for libraries and
plug-ins,
is just neither promoting nor helping modular design as Joseph is talking
about.
Olivier Gruber, Ph.D.
Persistent & Distributed Object Platforms and Frameworks
IBM TJ Watson Research Center
"Jeff McAffer" <jeff_mcaffer_REMOVE@ca.ibm.com> wrote in message
news:b3trak$ql3$1@rogue.oti.com...
do
> issue.
not
> Jeff
use
is
> > Thanks,
> > Joseph Toth
| Re: Equinox Goals - Abstracting Libraries for External Use [message #15298 is a reply to message #4974] |
Mon, 24 March 2003 08:27  |
Just to say that I would echo what Joseph says below.
I also recently thought it would be useful to use some of the JDT
functionality, e.g. code completion, in another context outside of Eclipse.
In doing it, I too found that it pulled in the Resources plugin, I had to
have the Eclipse platform running etc.
In order to try to make use of it, I had to muck about with how I loaded the
plugins (can't remember exactly how now).
The basic problem I encountered was that you needed the Eclipse Core
platform to be running in order to load any plugins. Then in order to use a
loaded plugin you had to define your own code in a plugin too. So, in order
to use functionality from a plugin, you had to operate within the bounds of
the Eclipse application. This made it pretty difficult to use any
functionality from your own (non-Eclipse) program.
My basic thing is, that there seems to be loads of useful functionality
defined within Eclipse, but you can't actually use it anywhere other than
within Eclipse itself - which seems a bit of a shame...
Of course, I do recognise that getting to this point would be rather
difficult, involving a lot of refactoring of plugins, and in particular the
interface between them.
Calum
> Jeff McAffer wrote:
> > Joseph,
could
> > Jeff
> >>Thanks,
> >>Joseph Toth
> Joseph Toth
Current Time: Wed Nov 05 14:06:43 EST 2025
Powered by FUDForum. Page generated in 0.04190 seconds
