Home » Archived » Test and Performance Tools Platform (TPTP) » Problems with UML2 diagrams
Problems with UML2 diagrams [message #53059] Tue, 07 February 2006 08:53 Go to next message
Originally posted by: marcelogilman.yahoo.com.ar
I canŽt get the UML2 diagrams. I installed the requiered plugins and Agent
Controller. Any suggestion is welcome.
Thanks.
Re: Problems with UML2 diagrams [message #53084 is a reply to message #53059] Tue, 07 February 2006 10:27 Go to previous message
Originally posted by: nmehrega.ca.ibm.com
You probably didn't set your profiling set properly:
In your profile launch configuration, Click on the profiling tab -> Click
on add to add a new profiling set -> Click on next -> Check Execution Time
Analysis under Time Analysis -> Select Execution Time Analysis -> Select
the 'Show execution flow graphical details' radio button -> Next -> Make
sure your filters are set properly -> Finish -> Select your newly created
profiling set -> Profile.
Right click on execution time analysis under your agent -> Open with one
of the sequence diagrams.
Navid Mehregani
Previous Topic:Classpath problem while profiling plug-in
Next Topic:Re: Agent Controller and Java 1.5/5.0
Current Time: Fri Jul 18 06:59:35 EDT 2025
Powered by FUDForum. Page generated in 0.07757 seconds
