Home » Archived » BIRT » Modify style in Javascript
Modify style in Javascript [message #53057] Fri, 01 July 2005 12:03 Go to next message
I am trying to modify the style of a data item in a report. I have set
the onCreate method of the Data item to the following, each in a
separate run:
this.color="red";
itemDesign.color="red";
this.setColor("red");
itemDesign.setColor("red");
etc.
There appears to be no effect when the report is previewed. I have
debugged it far enough to see the script being executed, but the
DataItem Java object never appears to be changed by the script.
Does anyone have examples that use the JavaScript methods on report
elements? Is the syntax above correct?
I reported a bug (#102496) that the onRender method of a Data element is
never called. I was able to determine through debugging that onRender is
never called but onCreate is called for a Data item.
Re: Modify style in Javascript [message #53107 is a reply to message #53057] Fri, 01 July 2005 13:33 Go to previous message
Currently, changing various properties at runtime is only supported for
data-related features.
Stanley Wang
BIRT Engine
> separate run:
> this.color="red";
> etc.
Previous Topic:Examples of creating a new Data Access Service
Next Topic:Bugzilla reports using BIRT
Current Time: Wed Nov 05 05:35:44 EST 2025
Powered by FUDForum. Page generated in 0.03887 seconds
