Home » Language IDEs » ServerTools (WTP) » Opening files with a non standard XML extension fails
Opening files with a non standard XML extension fails [message #53036] Wed, 10 November 2004 03:15 Go to next message
Hi all,
First off it could be because I'm running on M3 (same problem occured on
M2)
I've got a small problem with opening xml files that don't have a usual
xml extension like .xml/.xslt/.xsd.
If I open a normal xml file like test.xml everything works. If I now
rename this file to test.xmap and open it with the same editor I get the
messsage:
"editor could not be initialized"
Nothing can be found in any of the log files.
Any ideas...
Jos
Re: Opening files with a non standard XML extension fails [message #53061 is a reply to message #53036] Wed, 10 November 2004 10:59 Go to previous message
Originally posted by: amywu.us.DELETETHISPART.ibm.com
I believe it has something to do with the xml editor requiring an xml
content type. You can associate the xml content type to your special
extension by adding the following to any plugin.xml file:
<extension
point="org.eclipse.core.runtime.contentTypes">
<file-association
content-type="org.eclipse.core.runtime.xml"
file-extensions="aaa"/>
</extension>
This does sound like a bug though. I'd open a bug on web tools if there
isn't one already.
-amy
Jos Dirksen wrote:
> Hi all,
> M2)
> messsage:
> Any ideas...
> Jos
Previous Topic:XML editor encoding support
Next Topic:WebServices Create client fails
Current Time: Thu Nov 20 22:19:03 EST 2025
Powered by FUDForum. Page generated in 0.04681 seconds
