Home » Eclipse Projects » Mylyn » Trac connector for Trac 0.11
Trac connector for Trac 0.11 [message #52960] Thu, 17 July 2008 10:27 Go to next message
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi All,
I am wondering if there is anything on a Trac Connector (Alpha/Beta or
otherwise) for Ganymede connecting to Trac 0.11 ? I've just upgraded
only to discover that the connector provided with Mylyn 3 does not
support 0.11 yet.
If there is no development as of yet - is the place to suggest it the
Eclipse Bugzilla?
Many thanks,
Dave
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
Comment: Using GnuPG with Fedora - http://enigmail.mozdev.org
iEYEARECAAYFAkh/VtYACgkQSFFrHq0F7m98IgCeIhTrZGQYHuthihxqccU5 Bt89
f/AAnRe4fFstSbUFZn+ugFUzufGdui8s
=mV9U
-----END PGP SIGNATURE-----
Re: Trac connector for Trac 0.11 [message #53064 is a reply to message #52960] Thu, 17 July 2008 14:11 Go to previous messageGo to next message
Trac 0.11 is mostly supported with the exception of custom workflows. Take a
look at this bug report for more details about the current status:
175211: Support Trac 0.11
https://bugs.eclipse.org/bugs/show_bug.cgi?id=175211
Steffen
> Hash: SHA1
> Hi All,
> support 0.11 yet.
> Eclipse Bugzilla?
> Many thanks,
> Dave
> =mV9U
Re: Trac connector for Trac 0.11 [message #53191 is a reply to message #53064] Thu, 17 July 2008 17:18 Go to previous messageGo to next message
Hash: SHA1
Steffen,
Many thanks for this information - I suspect I am being thick but do I
need to check out the CVS code to use Eclipse with Trac 0.11 at present?
~ From reading Bugzilla it looks like I take the patch you attached (
https://bugs.eclipse.org/bugs/attachment.cgi?id=60245 ) and then patch
the relevant files? Or have I just been totally thick and shown my
complete naivety of developing for Eclipse? (I am wanting to use/test
rather than develop at this time)
If it helps I am using Ganymede with Mylyn 3.0.1v20080716-220-e3x
Dave
Take a
| Steffen
| David Thorne wrote:
| Hi All,
| support 0.11 yet.
| Eclipse Bugzilla?
| Many thanks,
| Dave
iEYEARECAAYFAkh/tw4ACgkQSFFrHq0F7m93YgCcD/m/hIaFCXXrLrwVxxis Tt8F
PNUAnAhbBxGN3DhhfONL7kp258rQ2GOA
=Eeun
Re: Trac connector for Trac 0.11 [message #53243 is a reply to message #53191] Thu, 17 July 2008 17:49 Go to previous messageGo to next message
You can use the 3.0.1 release from the main update site. Please comment on
the bug if you find any other problems than missing/incorrect workflow
actions.
The patch is only intended for anyone interested in hacking on the code to
support custom workflows. It is not complete, it will show custom workflow
actions but does not yet allow to advance the workflow.
I hope that someone adds the missing pieces soon and then we'll need your
support for testing the bits :).
Steffen
Re: Trac connector for Trac 0.11 [message #53634 is a reply to message #53243] Sun, 20 July 2008 10:38 Go to previous messageGo to next message
Hash: SHA1
| actions.
| Steffen
I think this is more my Apache setup than Mylyn BUT the authentication
doesn't seem to work with the settings I provide (They are definitely
right) When I start tracd with the necessary details the xmlrpc plugin
works... (tracd --env-parent-dir /path/to/my/trac/parent-env --port 8000
) could this be related to the problem indicated at
http://tjulo.blogspot.com/2007/03/problems-with-md5-and-modp ython.html?
(php4-mhash and libmhash2) I couldn't see any problems with this in
the Bugzilla but wasn't sure if it had already been reported and didn't
wish to duplicate bug reports! (I know how tedious they are)
Dave
iEYEARECAAYFAkiDTeMACgkQSFFrHq0F7m+6zACfVxQ53wC8Qzsm0FRTmH9A Yxmj
ykoAn3psTsCQRqI6/+YyLop1aGMWdF5f
=VP4l
Re: Trac connector for Trac 0.11 [message #53946 is a reply to message #53634] Mon, 21 July 2008 13:24 Go to previous messageGo to next message
The XML-RPC plug-in relies on the webserver for authentication. You can
verify that in a web browser if you go to
http://my.trac.repository/login/xmlrpc .
I am not aware that problems with this setup have been reported before.
Please file a new bug report and provide details about the configuration.
Steffen
Re: Trac connector for Trac 0.11 [message #53954 is a reply to message #53946] Mon, 21 July 2008 14:27 Go to previous messageGo to next message
Hash: SHA1
Hi Steffen,
Bizarre but on starting Apache today with machine bootup all appeared
well - I suspect it was a case of the problem being me forgetting to
restart after the Trac plugin was installed.
Thanks for the advice about /login/xmlrpc though :) I can now more
easily test everything is working through firefox.
Dave
| Steffen
iEYEARECAAYFAkiE1RgACgkQSFFrHq0F7m/gpgCeMb0oThj2CJ+xognl0IyK ZqSs
XgYAniIEU8sPLLq94o8SY1vTw5FGKOdb
=DpHG
Re: Trac connector for Trac 0.11 [message #54777 is a reply to message #53954] Wed, 30 July 2008 13:46 Go to previous messageGo to next message
Originally posted by: antoni_mylka.poczta.onet.pl
Does this mean that Trac 0.11 installations without XML-RPC
(login/xmlrpc doesn't work) are not supported at all?
Antoni Mylka
antoni_mylka@poczta.onet.pl
David Thorne pisze:
> Hash: SHA1
> Hi Steffen,
> Dave
> | Steffen
Re: Trac connector for Trac 0.11 [message #54861 is a reply to message #54777] Wed, 30 July 2008 17:14 Go to previous message
Little testing has been done on Web mode access for Trac 0.11. Please report
any problems that you encounter on the corresponding bug report:
Steffen
> Antoni Mylka
> David Thorne pisze:
>> Hash: SHA1
>> Hi Steffen,
>> Dave
>> |> plugin works... (tracd --env-parent-dir /path/to/my/trac/parent-env
>> |> --port 8000 ) could this be related to the problem indicated at
>> |> didn't wish to duplicate bug reports! (I know how tedious they are)
>> | configuration.
>> | Steffen
Re: Trac connector for Trac 0.11 [message #591323 is a reply to message #52960] Thu, 17 July 2008 14:11 Go to previous message
Steffen
> Hash: SHA1
> Hi All,
> support 0.11 yet.
> Eclipse Bugzilla?
> Many thanks,
> Dave
> =mV9U
Re: Trac connector for Trac 0.11 [message #591375 is a reply to message #53064] Thu, 17 July 2008 17:18 Go to previous message
Hash: SHA1
Steffen,
Dave
Take a
| Steffen
| David Thorne wrote:
| Hi All,
| support 0.11 yet.
| Eclipse Bugzilla?
| Many thanks,
| Dave
=Eeun
Re: Trac connector for Trac 0.11 [message #591393 is a reply to message #53191] Thu, 17 July 2008 17:49 Go to previous message
actions.
Steffen
Re: Trac connector for Trac 0.11 [message #591542 is a reply to message #53243] Sun, 20 July 2008 10:38 Go to previous message
Hash: SHA1
| actions.
| Steffen
Dave
=VP4l
Re: Trac connector for Trac 0.11 [message #591688 is a reply to message #53634] Mon, 21 July 2008 13:24 Go to previous message
Steffen
Re: Trac connector for Trac 0.11 [message #591694 is a reply to message #53946] Mon, 21 July 2008 14:27 Go to previous message
Hash: SHA1
Hi Steffen,
Dave
| Steffen
=DpHG
Re: Trac connector for Trac 0.11 [message #591992 is a reply to message #53954] Wed, 30 July 2008 13:46 Go to previous message
Antoni Mylka
David Thorne pisze:
> Hash: SHA1
> Hi Steffen,
> Dave
> | Steffen
Re: Trac connector for Trac 0.11 [message #592012 is a reply to message #54777] Wed, 30 July 2008 17:14 Go to previous message
Steffen
> Antoni Mylka
> David Thorne pisze:
>> Hash: SHA1
>> Hi Steffen,
>> Dave
>> | configuration.
>> | Steffen
Previous Topic:How to update bugzilla with changeset revision information?
Next Topic:Problem with 3.0.1 update
Current Time: Sun Aug 31 08:31:24 EDT 2025
Powered by FUDForum. Page generated in 0.06427 seconds
