Trac connector for Trac 0.11 [message #52960] |
Thu, 17 July 2008 10:27  |
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi All,
I am wondering if there is anything on a Trac Connector (Alpha/Beta or
otherwise) for Ganymede connecting to Trac 0.11 ? I've just upgraded
only to discover that the connector provided with Mylyn 3 does not
support 0.11 yet.
If there is no development as of yet - is the place to suggest it the
Eclipse Bugzilla?
Many thanks,
Dave
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
Comment: Using GnuPG with Fedora - http://enigmail.mozdev.org
iEYEARECAAYFAkh/VtYACgkQSFFrHq0F7m98IgCeIhTrZGQYHuthihxqccU5 Bt89
f/AAnRe4fFstSbUFZn+ugFUzufGdui8s
=mV9U
-----END PGP SIGNATURE-----
Re: Trac connector for Trac 0.11 [message #54861 is a reply to message #54777] |
Wed, 30 July 2008 17:14  |
Little testing has been done on Web mode access for Trac 0.11. Please report
any problems that you encounter on the corresponding bug report:
175211: Support Trac 0.11
https://bugs.eclipse.org/bugs/show_bug.cgi?id=175211
Steffen
Antoni Mylka wrote:
> Does this mean that Trac 0.11 installations without XML-RPC
> (login/xmlrpc doesn't work) are not supported at all?
> Antoni Mylka
> antoni_mylka@poczta.onet.pl
> David Thorne pisze:
>> Hash: SHA1
>> Hi Steffen,
>> Bizarre but on starting Apache today with machine bootup all appeared
>> well - I suspect it was a case of the problem being me forgetting to
>> restart after the Trac plugin was installed.
>> Thanks for the advice about /login/xmlrpc though :) I can now more
>> easily test everything is working through firefox.
>> Dave
>> Steffen Pingel wrote:
>> |> I think this is more my Apache setup than Mylyn BUT the authentication
>> |> doesn't seem to work with the settings I provide (They are definitely
>> |> right) When I start tracd with the necessary details the xmlrpc
>> |> plugin works... (tracd --env-parent-dir /path/to/my/trac/parent-env
>> |> --port 8000 ) could this be related to the problem indicated at
http://tjulo.blogspot.com/2007/03/problems-with-md5-and-modp ython.html?
>> |> (php4-mhash and libmhash2) I couldn't see any problems with this in
>> |> the Bugzilla but wasn't sure if it had already been reported and
>> |> didn't wish to duplicate bug reports! (I know how tedious they are)
>> | The XML-RPC plug-in relies on the webserver for authentication. You can
>> | verify that in a web browser if you go to
>> | http://my.trac.repository/login/xmlrpc .
>> | I am not aware that problems with this setup have been reported before.
>> | Please file a new bug report and provide details about the
>> | configuration.
>> | Steffen
Re: Trac connector for Trac 0.11 [message #591323 is a reply to message #52960] |
Thu, 17 July 2008 14:11  |
Trac 0.11 is mostly supported with the exception of custom workflows. Take a
look at this bug report for more details about the current status:
Steffen
> Hash: SHA1
> Hi All,
> support 0.11 yet.
> Eclipse Bugzilla?
> Many thanks,
> Dave
> =mV9U
Re: Trac connector for Trac 0.11 [message #591375 is a reply to message #53064] |
Thu, 17 July 2008 17:18  |
Hash: SHA1
Steffen,
Many thanks for this information - I suspect I am being thick but do I
need to check out the CVS code to use Eclipse with Trac 0.11 at present?
~ From reading Bugzilla it looks like I take the patch you attached (
https://bugs.eclipse.org/bugs/attachment.cgi?id=60245 ) and then patch
the relevant files? Or have I just been totally thick and shown my
complete naivety of developing for Eclipse? (I am wanting to use/test
rather than develop at this time)
If it helps I am using Ganymede with Mylyn 3.0.1v20080716-220-e3x
Dave
Take a
| Steffen
| David Thorne wrote:
| Hi All,
| support 0.11 yet.
| Eclipse Bugzilla?
| Many thanks,
| Dave
iEYEARECAAYFAkh/tw4ACgkQSFFrHq0F7m93YgCcD/m/hIaFCXXrLrwVxxis Tt8F
PNUAnAhbBxGN3DhhfONL7kp258rQ2GOA
=Eeun
Re: Trac connector for Trac 0.11 [message #591393 is a reply to message #53191] |
Thu, 17 July 2008 17:49  |
You can use the 3.0.1 release from the main update site. Please comment on
the bug if you find any other problems than missing/incorrect workflow
actions.
The patch is only intended for anyone interested in hacking on the code to
support custom workflows. It is not complete, it will show custom workflow
actions but does not yet allow to advance the workflow.
I hope that someone adds the missing pieces soon and then we'll need your
support for testing the bits :).
Steffen
Re: Trac connector for Trac 0.11 [message #591542 is a reply to message #53243] |
Sun, 20 July 2008 10:38  |
Hash: SHA1
| actions.
| Steffen
right) When I start tracd with the necessary details the xmlrpc plugin
works... (tracd --env-parent-dir /path/to/my/trac/parent-env --port 8000
the Bugzilla but wasn't sure if it had already been reported and didn't
Dave
iEYEARECAAYFAkiDTeMACgkQSFFrHq0F7m+6zACfVxQ53wC8Qzsm0FRTmH9A Yxmj
ykoAn3psTsCQRqI6/+YyLop1aGMWdF5f
=VP4l
Re: Trac connector for Trac 0.11 [message #591688 is a reply to message #53634] |
Mon, 21 July 2008 13:24  |
Please file a new bug report and provide details about the configuration.
Steffen
Re: Trac connector for Trac 0.11 [message #591694 is a reply to message #53946] |
Mon, 21 July 2008 14:27  |
Hash: SHA1
Hi Steffen,
Dave
| Steffen
iEYEARECAAYFAkiE1RgACgkQSFFrHq0F7m/gpgCeMb0oThj2CJ+xognl0IyK ZqSs
XgYAniIEU8sPLLq94o8SY1vTw5FGKOdb
=DpHG
Re: Trac connector for Trac 0.11 [message #591992 is a reply to message #53954] |
Wed, 30 July 2008 13:46  |
Antoni Mylka
David Thorne pisze:
> Hash: SHA1
> Hi Steffen,
> Dave
> | Steffen
Re: Trac connector for Trac 0.11 [message #592012 is a reply to message #54777] |
Steffen
> Antoni Mylka
> David Thorne pisze:
>> Hash: SHA1
>> Hi Steffen,
>> Dave
>> | configuration.
>> | Steffen
FUDForum. Page generated in 0.09348 seconds
