Home » Modeling » TMF (Xtext) » Recursive Definitions in xtext
Recursive Definitions in xtext [message #52950] Thu, 25 June 2009 15:14 Go to next message
I'm getting into trouble when I use recursive definitions in xtext.
The following simple grammar produces Stack-Overflow-Exceptions when it is
generated:
Model:
(assignment+=RightAssignment)*;
RightAssignment:
AdditiveOperation;
AdditiveOperation:
MultiplikativeOperation (("+" | "-") MultiplikativeOperation)* ;
MultiplikativeOperation:
UnaryExpression (("*" | "/") UnaryExpression)* ;
UnaryExpression:
Literal | "(" AdditiveOperation ")";
Literal:
ID | INT;
The reason of the Stack-Overflow seems to be the -"(" AdditiveOperation
")"- construct in the UnaryExpression rule.
What's wrong with this recursive approach?
Thanks for your help!
Re: Recursive Definitions in xtext [message #52975 is a reply to message #52950] Thu, 25 June 2009 16:14 Go to previous messageGo to next message
Hi Gunnar,
altough it may not be highlighted as an error (I guess due to the
StackOverflowError - would you please be so kind and file a bugzilla?),
the rule AdditiveOperation is invalid because it consists of two
unassigned RuleCalls (MultiplicativeOperation), which is only allows in
an Alternative.
Please have a look into the concept of assigned Actions and the explicit
definition of return Types[1] to implement your Expression grammar.
You may even want to study the SimpleExpressions sample language[2].
Hope that helps,
Sebastian
[1] http://www.eclipse.org/Xtext/documentation/0_7_0/xtext.html
[2]
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.tmf/org .eclipse.xtext/tests/org.eclipse.xtext.generator.tests/src/o rg/eclipse/xtext/testlanguages/SimpleExpressionsTestLanguage .xtext?root=Modeling_Project&view=markup
Am 25.06.2009 21:14 Uhr, schrieb Gunnar Reimann:
> is generated:
> Model:
> RightAssignment:
> AdditiveOperation;
> AdditiveOperation:
> UnaryExpression:
> Literal:
> ID | INT;
Re: Recursive Definitions in xtext [message #53000 is a reply to message #52950] Thu, 25 June 2009 16:34 Go to previous messageGo to next message
Just a remark:
This one works:
Model:
RightAssignment:
AdditiveOperation;
AdditiveOperation:
UnaryExpression:
Literal;
Literal:
ID | INT;
So the problem seems to be the recursive call of "AdditiveOperation".
Gunnar Reimann wrote:
> generated:
> Model:
> RightAssignment:
> AdditiveOperation;
> AdditiveOperation:
> UnaryExpression:
> Literal:
> ID | INT;
Re: Recursive Definitions in xtext [message #53026 is a reply to message #53000] Thu, 25 June 2009 16:37 Go to previous messageGo to next message
Hi Gunnar,
it actually does not work, as every rule except Model will be infered as
a data type rule, which is probably not what you expect.
Sebastian
Am 25.06.2009 22:34 Uhr, schrieb Gunnar Reimann:
> Just a remark:
> This one works:
> Model:
> RightAssignment:
> AdditiveOperation;
> AdditiveOperation:
> UnaryExpression:
> Literal;
> Literal:
> ID | INT;
>> it is generated:
>> Model:
>> RightAssignment:
>> AdditiveOperation;
>> AdditiveOperation:
>> UnaryExpression:
>> Literal:
>> ID | INT;
>> AdditiveOperation ")"- construct in the UnaryExpression rule.
Re: Recursive Definitions in xtext [message #53178 is a reply to message #53026] Fri, 26 June 2009 05:27 Go to previous messageGo to next message
Hi Sebastian,
thank you for your help! But as we are not working with xtext 0.7, this
one does, what we want:
Model:
(right+=RightAssignment)*;
RightAssignment:
(AdditiveOperation);
AdditiveOperation:
expr+=MultiplikativeOperation (("+" | "-") expr+=MultiplikativeOperation)*
expr+=UnaryExpression (("*" | "/") expr+=UnaryExpression)* ;
UnaryExpression:
literal=Literal | "(" expr+=AdditiveOperation ")";
NumLiteral:
INT;
SymLiteral:
ID;
Literal:
NumLiteral | SymLiteral;
Greetings,
Gunnar
Re: Recursive Definitions in xtext [message #53204 is a reply to message #53178] Fri, 26 June 2009 05:44 Go to previous message
Hi Gunnar,
currently you'll get more helpful answers to questions regarding oAW
Xtext at http://www.openarchitectureware.org/forum/?menu=Forum.
Sebastian
Am 26.06.2009 11:27 Uhr, schrieb Gunnar Reimann:
> Hi Sebastian,
> Model:
> RightAssignment:
> AdditiveOperation:
> expr+=MultiplikativeOperation)* ;
> UnaryExpression:
> NumLiteral:
> INT;
> SymLiteral:
> ID;
> Literal:
> Greetings,
> Gunnar
Previous Topic:[Announce] TMF XTEXT 0.7.0 is available
Next Topic:DSL project creation - extention points?
Current Time: Sun Nov 30 16:06:37 EST 2025
Powered by FUDForum. Page generated in 0.05488 seconds
