Designtime : Swing Components do not show up [message #52947] |
Sun, 01 August 2004 08:06  |
Originally posted by: wolfganglechnerPLEASE.NOSPAMgmx.at
First of all, thanks to the eclipse and ve community
for this great software.
But I experience a problem in designing visual components
derived from javax.swing.*
I'm able to create a VisualClass file but no frame does show
up in the designwindow. The source is ok; if I add visual
compnents the source changes and is correct.
Using awt instead the designwindow does update only
when changing the sourcecode. Dropping components onto
the frame does not.
Did I miss something? (class-paths or other properties to
set?) Anybody experienced something similar?
Setup :
WindowsXP
Eclipse 3.0 200406251208
VE M2
thanks in advance
wolf
Re: Designtime : Swing Components do not show up [message #53100 is a reply to message #53024] |
Mon, 02 August 2004 05:03  |
Ok, I completly reinstalled eclipse, gef, emf and ve,
works (I believe I did not download GEF before)
thanks
wolf
"Rich Kulp" <richkulp@NO.SPAM.us.ibm.com> wrote in message
news:cejdch$vvt$1@eclipse.org...
> What version of EMF are you using (should be 2.0.0 final release)?
> Are you doing anything special with EMF, changing the resource factories
> in any way?
> Are there other non-standard Eclipse projects installed beside GEF, EMF,
> and VE?
> The class cast error on the given line should not occur if vanilla EMF
> is installed. It is saying our resource that we use to model the class
> is not an XMIResource, and that can't happen normally.
> Thanks, Rich Kulp
Re: Designtime : Swing Components do not show up [message #596272 is a reply to message #52973] |
Sun, 01 August 2004 13:38  |
hi
I created a new workspace (directory) then New->Project->JavaProject
and New->VisualClass-> derived from Swing Frame
The .log says that :
!SESSION Aug 01, 2004
19:34:33.670 ---------------------------------------------
eclipse.buildId=I200406251208
java.version=1.4.2_01
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
!ENTRY org.eclipse.ve.java.core 4 0 Aug 01, 2004 19:34:33.670
!MESSAGE Exception thrown.
!STACK 0
java.lang.ClassCastException
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.createJavaIns
tances(JavaSourceTranslator.java:704)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.buildComposit
ionModel(JavaSourceTranslator.java:773)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.decodeDocumen
t(JavaSourceTranslator.java:880)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.loadModel(Jav
aSourceTranslator.java:655)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.r
un(JavaVisualEditorPart.java:1413)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
Thanks in advance
wolf
news:cej5ms$oie$1@eclipse.org...
> We've never seen something like that. Could you please attach you .log
> portions that refer to jem and ve? There may be errors that would
> explain this.
> Thanks, Rich Kulp
Re: Designtime : Swing Components do not show up [message #596280 is a reply to message #52998] |
Sun, 01 August 2004 14:41  |
in any way?
and VE?
Thanks, Rich Kulp
Re: Designtime : Swing Components do not show up [message #596314 is a reply to message #53024] |
thanks
wolf
> in any way?
> and VE?
> Thanks, Rich Kulp
FUDForum. Page generated in 0.04814 seconds
