Home » Eclipse Projects » Mylyn » How to update bugzilla with changeset revision information?
| How to update bugzilla with changeset revision information? [message #52935] |
Thu, 17 July 2008 10:09  |
Originally posted by: dave.146.gmail.com
Hi All,
I began using Mylin this week with Eclipse Ganymede (CDT), Bugzilla 3.04,
and subclipse/subversion (and yes, I'm amazed). I have successfully made
code changes within the context of a Bugzilla task and committed those
changes as a change set, with Mylin supplying the commit comment from the
task. My question is, is there a way to automatically update the task with
the change set revision information. I can manually add the revision
information to the task as a comment, but since Mylin can send task
information to svn, I'm wondering if it can also send svn information back
to the task.
Dave
| Re: How to update bugzilla with changeset revision information? [message #53018 is a reply to message #52935] |
Thu, 17 July 2008 12:12   |
Originally posted by: mauro.molinari.cardinis.com
Dave Belliveau ha scritto:
> Hi All,
> 3.04, and subclipse/subversion (and yes, I'm amazed). I have
> successfully made code changes within the context of a Bugzilla task and
> committed those changes as a change set, with Mylin supplying the commit
> comment from the task. My question is, is there a way to automatically
> update the task with the change set revision information. I can manually
> add the revision information to the task as a comment, but since Mylin
> can send task information to svn, I'm wondering if it can also send svn
> information back to the task.
> Dave
If I understood it correctly, you should be interested in the following
enhancement requests:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=198004
https://bugs.eclipse.org/bugs/show_bug.cgi?id=197924
If this is the case, please vote on them! I'm also so much interested! :-P
Mauro.
| Re: How to update bugzilla with changeset revision information? [message #53090 is a reply to message #52935] |
Thu, 17 July 2008 15:03   |
> and committed those changes as a change set, with Mylin supplying the
> commit comment from the task. My question is, is there a way to
> automatically update the task with the change set revision information.
> I can manually add the revision information to the task as a comment,
> but since Mylin can send task information to svn, I'm wondering if it
> can also send svn information back to the task.
The right way to do this is with a Subversion server repository hook.
There is no reason for a solution to depend on using Eclipse and Mylyn.
A lot of issue tracker provide these hook scripts, and I am sure there
are some for Bugzilla floating around.
There is also a project called SCMBUG that basically provides these
hook scripts and a framework for supporting multiple issue trackers.
I'd look at it first.
http://freshmeat.net/projects/scmbug/
Here is a recent blog post I found:
http://blog.loftninjas.org/?p=174
There are a lot of hits in Google too.
Mark
| Re: How to update bugzilla with changeset revision information? [message #591307 is a reply to message #52935] |
> Hi All,
> Dave
Mauro.
| Re: How to update bugzilla with changeset revision information? [message #591329 is a reply to message #52935] |
Mark
Current Time: Tue Nov 04 13:42:00 EST 2025
Powered by FUDForum. Page generated in 0.04293 seconds
