Home » Eclipse Projects » Mylyn » How to update bugzilla with changeset revision information?
How to update bugzilla with changeset revision information? [message #52935] Thu, 17 July 2008 10:09 Go to next message
Originally posted by: dave.146.gmail.com
Hi All,
I began using Mylin this week with Eclipse Ganymede (CDT), Bugzilla 3.04,
and subclipse/subversion (and yes, I'm amazed). I have successfully made
code changes within the context of a Bugzilla task and committed those
changes as a change set, with Mylin supplying the commit comment from the
task. My question is, is there a way to automatically update the task with
the change set revision information. I can manually add the revision
information to the task as a comment, but since Mylin can send task
information to svn, I'm wondering if it can also send svn information back
to the task.
Dave
Re: How to update bugzilla with changeset revision information? [message #53018 is a reply to message #52935] Thu, 17 July 2008 12:12 Go to previous messageGo to next message
Originally posted by: mauro.molinari.cardinis.com
Dave Belliveau ha scritto:
> Hi All,
> 3.04, and subclipse/subversion (and yes, I'm amazed). I have
> successfully made code changes within the context of a Bugzilla task and
> committed those changes as a change set, with Mylin supplying the commit
> comment from the task. My question is, is there a way to automatically
> update the task with the change set revision information. I can manually
> add the revision information to the task as a comment, but since Mylin
> can send task information to svn, I'm wondering if it can also send svn
> information back to the task.
> Dave
If I understood it correctly, you should be interested in the following
enhancement requests:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=198004
https://bugs.eclipse.org/bugs/show_bug.cgi?id=197924
If this is the case, please vote on them! I'm also so much interested! :-P
Mauro.
Re: How to update bugzilla with changeset revision information? [message #53090 is a reply to message #52935] Thu, 17 July 2008 15:03 Go to previous messageGo to next message
> and committed those changes as a change set, with Mylin supplying the
> commit comment from the task. My question is, is there a way to
> automatically update the task with the change set revision information.
> I can manually add the revision information to the task as a comment,
> but since Mylin can send task information to svn, I'm wondering if it
> can also send svn information back to the task.
The right way to do this is with a Subversion server repository hook.
There is no reason for a solution to depend on using Eclipse and Mylyn.
A lot of issue tracker provide these hook scripts, and I am sure there
are some for Bugzilla floating around.
There is also a project called SCMBUG that basically provides these
hook scripts and a framework for supporting multiple issue trackers.
I'd look at it first.
http://freshmeat.net/projects/scmbug/
Here is a recent blog post I found:
http://blog.loftninjas.org/?p=174
There are a lot of hits in Google too.
Mark
Re: How to update bugzilla with changeset revision information? [message #53168 is a reply to message #53090] Thu, 17 July 2008 17:14 Go to previous messageGo to next message
Thanks Mark. I was aware of scmbug but had not looked into it yet, hoping
that this support was in Mylin. But you're right ... we would want this
capability whether an svn committer is using Eclipse/Mylin or not. I'll
take a look at scmbug.
Dave
Re: How to update bugzilla with changeset revision information? [message #53299 is a reply to message #53090] Fri, 18 July 2008 02:57 Go to previous message
However, if Mylyn supported this, it would be possible to make VERY
interesting things with Eclipse then... moreover, this could be used
independently of the task repository you're using.
Mauro.
Re: How to update bugzilla with changeset revision information? [message #591307 is a reply to message #52935] Thu, 17 July 2008 12:12 Go to previous message
> Hi All,
> Dave
Mauro.
Re: How to update bugzilla with changeset revision information? [message #591329 is a reply to message #52935] Thu, 17 July 2008 15:03 Go to previous message
Mark
Re: How to update bugzilla with changeset revision information? [message #591364 is a reply to message #53090] Thu, 17 July 2008 17:14 Go to previous message
Dave
Re: How to update bugzilla with changeset revision information? [message #591417 is a reply to message #53090] Fri, 18 July 2008 02:57 Go to previous message
Mauro.
Previous Topic:editor tabs re-ordered when switching tasks
Next Topic:Trac connector for Trac 0.11
Current Time: Sun Nov 09 05:42:10 EST 2025
Powered by FUDForum. Page generated in 0.05549 seconds
