Home » Archived » Test and Performance Tools Platform (TPTP) » Eclipse TPTP Strengthens Integration with BIRT and WTP
Eclipse TPTP Strengthens Integration with BIRT and WTP [message #52827] Fri, 03 February 2006 14:48
The Eclipse Test & Performance Tools Platform (TPTP) Project delivers
improved integration with BIRT and WTP in its latest release, TPTP
4.1.0.1, a maintenance release of 4.1.
The integration with BIRT 2.0
(http://www.eclipse.org/org/press-release/20060123birt20.php) extends
TPTP's test, profiling and monitoring data reporting capabilities with new
BIRT-based reports for web applications performance and JUnit test
results. By taking advantage of BIRT reporting and charting features,
these reports have improved presentation layouts and data visualization.
TPTP is looking for contribution of BIRT-based report templates at
http://www.eclipse.org/tptp/home/project_info/releaseinfo/4. 2/feedback_birt.html.
With the community’s support, future TPTP releases will continue to grow
a comprehensive set of such reports.
The integration with WTP 1.0
( http://www.eclipse.org/org/press-release/20051219wtp10releas e.php)
simplifies web application profiling using TPTP. WTP users can use a
pre-configured shortcut to launch an application being profiled by the
TPTP profiling tools. The user can also use the integration to import
then analyze and correlate server log files.
You can take a quick tour of the new features in TPTP 4.1.0.1 at
http://www.eclipse.org/tptp/home/downloads/quicktour/v41/qui ck_tour.html.
Two other maintenance releases of TPTP 3.3 and TPTP 4.0, i.e. TPTP 3.3.0.2
and TPTP 4.0.1.1, respectively, are also available to support existing
TPTP adopters. All three releases can be downloaded at
http://www.eclipse.org/tptp/home/downloads/downloads.php.
Previous Topic:more on: AGR does not recognize confirmation dialog
Next Topic:Classpath problem while profiling plug-in
Current Time: Fri Nov 07 17:51:06 EST 2025
Powered by FUDForum. Page generated in 0.03111 seconds
