Home » Archived » M2M (model-to-model transformation) » Help with TaggedValues
Help with TaggedValues [message #52775] |
Tue, 17 July 2007 14:39  |
Originally posted by: mpitanga.gmail.com
I need created a new TaggedValue using many values in dataValue attribute.
I have a following rule:
lazy rule newTaggedValue {
from element : UML!Element, name: String, value: Sequence(String)
to t : UML!TaggedValue (
modelElement <- element,
name <- name,
type <- thisModule.getTagDefinition(name),
dataValue <- value->asBag()
and a call for this rule is:
rule Model_PSM {
from
s : UML!Model (thisModule.inElements->includes(s))
to
t : UML!Model mapsTo s(
name <- s.name,
ownedElement <- s.ownedElement
do {
if thisModule.taggedValueExists(thisModule.umlOperation, 'base') then
true
else
thisModule.newTaggedValue(thisModule.umlOperation,'base',
Sequence{'call(* Cliente+.*(..))',
'get(private String ClientePF.cpf)',
'set(private String ClientePF.cpf)'})
endif;
Well,
when I perform this rule to generate the XMI, the result is the following:
<UML:ModelElement.taggedValue>
<UML:TaggedValue xmi.id = 'a291' name = 'base' isSpecification = 'false'>
<UML:TaggedValue.dataValue>set(private String
ClientePF.cpf)</UML:TaggedValue.dataValue>
<UML:TaggedValue.dataValue>get(private String
<UML:TaggedValue.dataValue>||</UML:TaggedValue.dataValue>
<UML:TaggedValue.dataValue>call(*
Cliente+.*(..))</UML:TaggedValue.dataValue>
<UML:TaggedValue.type>
<UML:TagDefinition xmi.idref = 'a280'/>
</UML:TaggedValue.type>
</UML:TaggedValue>
</UML:ModelElement.taggedValue>
But I need XMI to be like this, that is, the TaggedValue.dataValue has to
contain all of the elements of Sequence and in the same order.
</UML:TaggedValue>
Some idea to solve this problem?
Thanks in advance,
Marcelo
[ATL] Re: Help with TaggedValues [message #52802 is a reply to message #52775] |
Tue, 17 July 2007 14:41   |
name <- name,
rule Model_PSM {
from
to
name <- s.name,
do {
true
else
endif;
Well,
</UML:TaggedValue>
</UML:TaggedValue>
Thanks in advance,
Marcelo
Re: [ATL] Re: Help with TaggedValues [message #52932 is a reply to message #52802] |
Wed, 18 July 2007 02:07   |
Marcelo Alves schreef:
> name <- name,
*snip*
> Well,
> </UML:TaggedValue>
> to contain all of the elements of Sequence and in the same order.
> </UML:TaggedValue>
> Thanks in advance,
> Marcelo
Have you tried not doing "value->asBag()" in your newTaggedValue rule?
"value" should already be a sorted Sequence, while Bags are unsorted.
Another side effect I see, is that the duplicate '||' string was
filtered out. This should not happen with a Bag, and may be an ATL bug.
Dennis
Re: [ATL] Re: Help with TaggedValues [message #53259 is a reply to message #52932] |
Wed, 18 July 2007 15:13  |
Hi Dennis,
Thank you for your replay.
I solved this problem by modifying the metamodel UMLDI.
In the definition of the multiplicity
(<Model:StructuralFeature.multiplicity>) I replaced the value of the
second <XMI.field> from true to false.
<Model:Class xmi.id = 'a684' name = 'TaggedValue' annotation = '' isRoot =
'false'
isLeaf = 'false' isAbstract = 'false' visibility = 'public_vis'
isSingleton = 'false'>
<Model:Namespace.contents>
<Model:Attribute xmi.id = 'a840' name = 'dataValue' annotation
= '' scope = 'instance_level'
visibility = 'public_vis' isChangeable = 'true' isDerived =
'false'>
<XMI.field>0</XMI.field>
<XMI.field>-1</XMI.field>
<XMI.field>false</XMI.field>
<XMI.field>false</XMI.field> <--- replace true by false
</Model:StructuralFeature.multiplicity>
<Model:TypedElement.type>
<Model:AliasType xmi.idref = 'a573'/>
</Model:TypedElement.type>
</Model:Attribute>
Marcelo
Current Time: Tue Jul 22 00:52:02 EDT 2025
Powered by FUDForum. Page generated in 0.04097 seconds
