Home » Newcomers » Newcomers » Automatically add project to workspace
Automatically add project to workspace [message #52768] Sat, 16 April 2005 11:16 Go to next message
Originally posted by: Andreas.Fester.agile.com
I am trying to migrate our proprietary build system to Eclipse.
We have a structure where one source tree contains many packages which
result in different jar files.
Creating appropriate sub directories within the workspace directory
for each project with the proper .classpath and .project files seems
easy, because they are XML and can easily be created from our proprietary
build description.
But: How can the projects then be added to the workspace? The only way
I found was to import each of the different projects manually. Because
our source is divided into many small sub projects (about 70), this
does not really make sense :-( It seems that Eclipse stores information
about the projects which are part of a workspace in some binary files.
So, is there any way to automatically import a large number of projects
into a workspace?
Thanks & best Regards,
Andreas
Re: Automatically add project to workspace [message #52953 is a reply to message #52768] Sat, 16 April 2005 20:54 Go to previous messageGo to next message
Originally posted by: marie.u.washington.edu
Play around with drag & drop. Dragging files from the gui file manager
of your choice into the graphical file tree in Eclipse does a
surprisingly good job of automating many tasks. Try it with one of the
files/folders involved just to test, then if it works you can select all
of the projects involved and drag and drop in one motion. I'm not
positive this will work, but you can give it a try.
Marie
Andreas Fester wrote:
> build description.
> into a workspace?
> Andreas
Re: Automatically add project to workspace [message #53078 is a reply to message #52953] Sun, 17 April 2005 07:19 Go to previous messageGo to next message
Hi Marie,
thanks for your input; I tried it, but unfortunately the KDE Filemanager
on Linux does not seem to cooperate with the Eclipse file tree :-(
But: I just tried Eclipse 3.1M6, and found that it has a much better
Projects Import user interface which allows to select more than one
project to import at the same time! So this seems to be a reasonable
solution.
Of course the best solution would be if the workspace could be
created automatically, and the projects be added automatically;
so if anyone still has other ideas of how to achieve this I am
still interested ...
Best Regards,
Andreas
Re: Automatically add project to workspace [message #60311 is a reply to message #53078] Sun, 01 May 2005 18:13 Go to previous message
If you use maven, you can create an eclipse project for the files in a
maven project by using the eclipse plugin, and simply typing:
maven eclipse
benedict
> Hi Marie,
> solution.
> Best Regards,
> Andreas
Previous Topic:AMD64 errors
Next Topic:Trouble starting Eclipse on Linux
Current Time: Sat Jul 26 03:06:41 EDT 2025
Powered by FUDForum. Page generated in 0.09441 seconds
