Home » Archived » M2M (model-to-model transformation) » problem with Map data type
problem with Map data type [message #52748] Tue, 17 July 2007 14:24 Go to next message
Originally posted by: adilanwar10.yahoo.fr
Hi all,
i need to check if two class have the same list of attributes, i
write this code but it didn't work .
the map is still empty !!
helper context UML!Class def : match(p : UML!Class) : Boolean =
self.isAbstract = p.isAbstract and
self.ownedAttribute->size()= p.ownedAttribute->size() and
self.ownedAttribute->iterate(i ; attr : UML!Property = self.ownedAttribute |
if not thisModule.AttrMap.getKeys().isEmpty()
then
thisModule.AttrMap.containsKey(i.name)and
thisModule.AttrMap.get(i).name = i.type.name
else false
endif) ;
helper def : AttrMap : Map(String, UML!DataType) = Map{};
rule setAttrMap(c : UML!Class) {
do{
for (a in c.ownedAttribute){
thisModule.AttrMap <-
thisModule.AttrMap->including(a.name,a.type);
Adil
Re: problem with Map data type [message #53003 is a reply to message #52748] Wed, 18 July 2007 09:37 Go to previous messageGo to next message
I do not see where you call setAttrMap.
Frédéric Jouault
Adil Anwar wrote:
> Hi all,
> then
> else false
> endif) ;
> do{
> Best regards,
> Adil
Re: [ATL] problem with Map data type [message #53028 is a reply to message #53003] Wed, 18 July 2007 09:39 Go to previous messageGo to next message
Hello again,
Please, remember to prefix the subject of your ATL-related posts with
[ATL], as I did in this message.
See the M2M wiki page for more information on this scheme:
http://wiki.eclipse.org/M2M
Frédéric Jouault
Frédéric Jouault wrote:
> Hello,
> Frédéric Jouault
> Adil Anwar wrote:
>> Hi all,
>> attributes, i write this code but it didn't work .
>> then
>> else false
>> endif) ;
>> do{
>> Best regards,
>> Adil
Re: [ATL]problem with Map data type [message #53130 is a reply to message #53003] Wed, 18 July 2007 10:44 Go to previous messageGo to next message
hello,
thanks for your respone, well i call setAttrMap in this rule
rule ClassConformityRule extends ModelElementMatchingRule{
from e1 : UML!Class, e2 : UML!Class
(thisModule.setAttrMap(e2)and e1.match(e2))
to r : MMC!ConformityRelationship
i want to fill the Map before checking the guard condition with the helper
match, is that possible in ATL ??
Adil
"Fr
Re: [ATL]problem with Map data type [message #53233 is a reply to message #53130] Wed, 18 July 2007 12:44 Go to previous messageGo to next message
You call an imperative rule from declarative code. This cannot work.
Don't you get an execution error?
Anyway, as usual, I would advise to use only declarative construct, like:
helper context UML!Class def: AttrMap : Map(String, UML!DataType) =
e.ownedAttribute->iterate(e; acc : Map(String, UML!Class) = Map{} |
acc->including(e.name, e.type)
Frédéric Jouault
Adil Anwar wrote:
> hello,
> Adil
> "Frédéric Jouault" <frederic.jouault@univ-nantes.fr> a écrit dans le message
> de news: f7l53c$ik$1@build.eclipse.org...
>> Hello,
>> Regards,
>> Frédéric Jouault
>> Adil Anwar wrote:
>>> Hi all,
>>> then
>>> else false
>>> endif) ;
>>> do{
>>> Best regards,
>>> Adil
Re: [ATL]problem with Map data type [message #53569 is a reply to message #53233] Thu, 19 July 2007 11:38 Go to previous message
thanks for your help,
I'm not get an execution error when i used the imperative role. I think that
ATL engine evaluate the result of the setAttrMap in True,
but now i use the declarative construct as you suggest,
the problem was in the instruction : thisModule.AttrMap.get(i).name , the
value in key i was OclUndefined.
Adil
"Fr
Previous Topic:Re: [ATL] Charging models dynamically in an ATL transformation
Next Topic:[atl]: list of publications about ATL
Current Time: Sat Jul 26 09:55:38 EDT 2025
Powered by FUDForum. Page generated in 0.04146 seconds
