Home » Archived » Test and Performance Tools Platform (TPTP) » more on: AGR does not recognize confirmation dialog
more on: AGR does not recognize confirmation dialog [message #52746] Thu, 02 February 2006 18:41 Go to next message
Apologies, I forgot to mention this in the original post:
I edited widgetReg.xml in the org.eclipse.tptp.test.auto.gui_4.1.0/auto-gui
directory and added the following entry:
<class name="org.eclipse.swt.widgets.MessageBox" matchThreshold="1.0">
<method name="getData" weight="1.0" />
<class>
Then re-started Eclipse, but the recorded macro still did not recognize the
confirmation dialog (which is of type org.eclipse.swt.widgets.MessageBox).
Not sure if this matters, but for completeness sake (in case it matters who
parents the MessageBox instance): The MessageBox instance is launched by an
instance of org.eclipse.jface.wizard.WizardDialog.
Any and all help/input would be highly appreciated.
Thanks much!
- Stephan
Re: more on: AGR does not recognize confirmation dialog [message #52800 is a reply to message #52746] Fri, 03 February 2006 14:19 Go to previous message
See response to the original post.
"Stephan Lips" <stephan.lips@gmail.com> wrote in message
news:dru5c1$tu2$1@utils.eclipse.org...
> <class>
the
who
an
> Thanks much!
> - Stephan
Previous Topic:AGR does not recognize confirmation dialog
Next Topic:Eclipse TPTP Strengthens Integration with BIRT and WTP
Current Time: Wed Nov 19 13:59:49 EST 2025
Powered by FUDForum. Page generated in 0.03583 seconds
