Home » Language IDEs » C / C++ IDE (CDT) » Problem using eclipse via X-win32
Problem using eclipse via X-win32 [message #52738] Thu, 28 November 2002 12:46 Go to next message
Originally posted by: vladg.tx.technion.ac.il
When I try to run enclipse from Windows on Linux via the X-Win32 emulator
I got the next error:
Does anybody know what is the problem?
java.lang.ArrayIndexOutOfBoundsException: 32
at org.eclipse.swt.graphics.ImageData.blit(ImageData.java(Compi led
Code))
at org.eclipse.swt.graphics.Image.putImage(Image.java:1200)
at org.eclipse.swt.graphics.Image.init(Image.java:988)
at org.eclipse.swt.graphics.Image.<init>(Image.java(Compiled Code))
org.eclipse.jface.action.ActionContributionItem$ImageCache.g etGrayImage(ActionContributionItem.java:105)
org.eclipse.jface.action.ActionContributionItem.updateImages (ActionContributionItem.java:602)
org.eclipse.jface.action.ActionContributionItem.update(Actio nContributionItem.java:468)
org.eclipse.jface.action.ActionContributionItem.fill(ActionC ontributionItem.java:287)
org.eclipse.jface.action.ToolBarManager.update(ToolBarManage r.java:230)
org.eclipse.ui.internal.WorkbenchWindow.addPerspectiveShortc ut(WorkbenchWindow.java:295)
org.eclipse.ui.internal.WorkbenchPage.onActivate(WorkbenchPa ge.java:1519)
org.eclipse.ui.internal.WorkbenchWindow$7.run(WorkbenchWindo w.java:1235)
org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:66)
org.eclipse.ui.internal.WorkbenchWindow.setActivePage(Workbe nchWindow.java:1222)
org.eclipse.ui.internal.WorkbenchWindow.busyOpenPage(Workben chWindow.java:345)
org.eclipse.ui.internal.WorkbenchWindow$6.run(WorkbenchWindo w.java:932)
org.eclipse.ui.internal.WorkbenchWindow.openPage(WorkbenchWi ndow.java:929)
org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbe nch.java:745)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:581)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1232)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:775)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:462)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:61)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:40)
at java.lang.reflect.Method.invoke(Method.java:335)
at org.eclipse.core.launcher.Main.basicRun(Main.java:247)
at org.eclipse.core.launcher.Main.run(Main.java:703)
Re: Problem using eclipse via X-win32 [message #52850 is a reply to message #52738] Sat, 30 November 2002 20:48 Go to previous message
"Vladimir Getselevich" <vladg@tx.technion.ac.il> wrote in message
news:as5kp6$cid$1@rogue.oti.com...
<snip>
I do not know for sure but ...
The Eclipse SWT uses native widgets when available. As a result, it is very
dependent on the windowing system being used.
If you are running Eclipse & CDT for win32, on a Linux box the results will
be very dependent on how the emulator interprets the native calls to the
widgets.
I have a strong feeling that using the emulator will not work to your
satisfaction, if at all.
You might want to check with the eclipse.tools newsgroup, since the
compatibility of the SWT with variaous platforms is their area of expertise.
Good luck and let us know what you find out.
-Judy
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.423 / Virus Database: 238 - Release Date: 11/25/02
Previous Topic:C++ parser configuration
Next Topic:Questions about the direction of the CDT project
Current Time: Mon Jul 21 20:05:31 EDT 2025
Powered by FUDForum. Page generated in 0.04861 seconds
