Home » Eclipse Projects » GEF » TextTransfer Drag and Drop Question in Logic Editor Example
TextTransfer Drag and Drop Question in Logic Editor Example [message #52736] Wed, 08 January 2003 10:49 Go to next message
Originally posted by: truenoto.yahoo.com
In the logic Editor Example, only Label accepts Text Drop.
But when I look at the code of the DropTarget listener is add to the
GraphicalViewer, not to the label. Then why I can only drop Text to Label
only? Where it the code which restricts the I can only drop to Label?
What should I do if I want other figures to accept Text Drop Event?
What should I do so that I can drag text to the Main Graphic Panel, and the
editor will create a NEW label with the Text I drop?
Thank you for any help.
Re: TextTransfer Drag and Drop Question in Logic Editor Example [message #52764 is a reply to message #52736] Tue, 07 January 2003 11:34 Go to previous messageGo to next message
"Takumi Fujiwara" <truenoto@yahoo.com> wrote in message
news:avhha6$q7k$1@rogue.oti.com...
the
As far as I understood, you can only drop on Editparts which provide
EditPolicies that are able to accept the request the DropTargetListener
transports.
In this case, the request is of class NativeDropRequest (in Package
logickdesigner.edit).
The only EditPolicy which can use that request is LogicLabelEditPolicy,
which will create a DropTextCommand. All other EditPolicies in LogicExample
can't use a NativeDropRequest - their getCommand(Request)-Method will return
null. That means you can't drop the text.
To enable other Editparts for dropping, you would have to handle the
NativeDropRequest (or what ever request you use) in one of their
EditPolicies.
Manfred Goetz.
Re: TextTransfer Drag and Drop Question in Logic Editor Example [message #52816 is a reply to message #52764] Wed, 08 January 2003 13:08 Go to previous messageGo to next message
Originally posted by: hudsonr.us.eye-bee-em.com
Exactly!
"Manfred Goetz" <xgoetz@de.ibm.com> wrote in message
news:avhj8f$rto$1@rogue.oti.com...
Label
> the
> transports.
LogicExample
return
> EditPolicies.
> Manfred Goetz.
Re: TextTransfer Drag and Drop Question in Logic Editor Example [message #53134 is a reply to message #52764] Thu, 09 January 2003 11:27 Go to previous messageGo to next message
Originally posted by: sy_cheung2.yahoo.com
Manfred,
I would like to modify the Logic Editor Example to achieve this as a
learning exercise:
When user drag a Task in the Task View, and drop it to the Logic Editor, it
will create an Label in the Logic Editor at the place when it is dropped.
Based on your suggestion, I modify the getCommand() of
LogicContainerEditPolicy to add a case for NativeDropRequestID. But I try it
(select a task with Ctrl) and drag it over to the Logic Edit Panel, it still
just shows a STOP icon, and when I move it over a Label, it changes to a
DROP icon. Could you please tell me what did I miss?
Thank you for your help.
public Command getCommand(Request request) {
if (AutoLayoutAction.AUTOLAYOUT.equals(request.getType())) {
// original implementation of LogicContainerEditPolicy
} else if (NativeDropRequest.ID.equals(request.getType())) {
return getDropTextCommand((NativeDropRequest)request);
return super.getCommand(request);
Label
> the
> transports.
LogicExample
return
> EditPolicies.
> Manfred Goetz.
Re: TextTransfer Drag and Drop Question in Logic Editor Example [message #53209 is a reply to message #53134] Thu, 09 January 2003 11:48 Go to previous message
Don't forget that your EditPart (the logic container) will not get
*TARGETED* unless it returns itself for getTargetEditPart().
Therefore, your LogicConatinerEditPolicy should return its getHost() for
these requests.
"Sam Cheung" <sy_cheung2@yahoo.com> wrote in message
news:avk720$hcv$1@rogue.oti.com...
> Manfred,
> learning exercise:
it
it
still
> Label
and
> > the
> > transports.
> LogicExample
> return
> > EditPolicies.
> > Manfred Goetz.
Previous Topic:Printing Example
Next Topic:PrintFigureOperation doesn't print whole figure.
Current Time: Thu Nov 06 18:53:50 EST 2025
Powered by FUDForum. Page generated in 0.03984 seconds
