HowTo reference definitions in multiple schemas [message #52699] |
Thu, 09 September 2004 17:25  |
I'm trying to parse a the schema's contained in a WSDL file. Everything
works fine when the <wsdl:types> has only one schema defined. I'm working
with wsdl files that have more than 1 schema defined in the <wsdl:types>
element.
For example, I have the following two schemas (see below) defined in the
wsdl. TestSchema1 defines a base type and TestSchema2 tries to extend the
definition.
I've tried the following code and have not be able to get the base
definition to resolve as the XSDParticle definition keeps on showing up as
null. I've tries a variation of this code and seem to be stumped. I
can't seem to find anything in the newsgroup. Have I really missed the
boat and misunderstood?
Any help or direction would be greatly appreciated :-)
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "xsd",
new XSDResourceFactoryImpl());
_resourceSet = new ResourceSetImpl();
XSDSchema xsdSchema1 = XSDSchemaImpl.createSchema(rschemaRootElement1);
Resource rs1 =
_resourceSet.createResource(URI.createURI(root.getLocalName( )+ ".xsd"));
rs.getContents().add(xsdSchema1);
XSDSchema xsdSchema2 = XSDSchemaImpl.createSchema(rschemaRootElement2);
Resource rs2 =
rs.getContents().add(xsdSchema2);
<xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema"
targetNamespace="http://Exception.www.ibm.com">
<xsd:complexType name="SomethingWrong">
<xsd:annotation>
<xsd:documentation>The base type for all bc online web services
exceptions</xsd:documentation>
</xsd:annotation>
<xsd:sequence>
<xsd:element name="LocalizedMessage" type="xsd:string"/>
<xsd:element name="Message" type="xsd:string"/>
<xsd:element name="StackTrace" type="xsd:string"/>
<xsd:element name="return-code" type="xsd:int"/>
</xsd:sequence>
</xsd:complexType>
</xsd:schema>
and
targetNamespace="http://www.ibm.com"
xmlns:excp="http://Exception.www.ibm.com"
xmlns:impl="http://www.ibm.com">
<xsd:element name="GlobalSimpleType" type="xsd:string"></xsd:element>
<xsd:complexType name="WrongThing1">
<xsd:annotation>
<xsd:documentation>Contains Logoff error information</xsd:documentation>
</xsd:annotation>
<xsd:complexContent>
<xsd:extension base="excp:SomethingWrong" />
</xsd:complexContent>
</xsd:complexType>
<xsd:complexType name="WrongThing2">
<xsd:extension base="excp:SomethingWrong">
<xsd:sequence>
<xsd:element name="format-error" type="xsd:int"/>
</xsd:sequence>
</xsd:extension>
</xsd:complexType>
</xsd:schema>
Re:Figured it out :-) [message #52780 is a reply to message #52753] |
Fri, 10 September 2004 15:12  |
I figured out what I needed to do. After the resource has been created
and the schema content has been loaded, I set the resource URI to the
target namespace of the schema I just loaded. This seems to allow the
next schema to find the first definition and resolve definitions from it.
The code sort of looks like this:
ResourceSet = _resourceSet = new ResourceSetImpl();
Resource rs1 = _resourceSet.createResource(URI.createURI("*.xsd"));
rs1.getContents().add(xsdSchema1);
rs1.setURI(URI.createURI(xsdSchema1.getTargetNamespace());
xsdSchema1.validate();
Resource rs2 = _resourceSet.createResource(URI.createURI("*.xsd"));
rs2.getContents().add(xsdSchema2);
rs2.setURI(URI.createURI(xsdSchema2.getTargetNamespace());
xsdSchema2.validate();
Tim wrote:
> Thanks Ed.
> I just tried it this morning by adding an import to the second schema. And
> it still didn't find the reference to the first schema. I have also tried
> using the validate method hoping that would resolve the references
> Until about fifteen minutes ago, I didn't know that I could parse a WSDL
> directly. If I was only interested in the schemas contained in the WSDL I
> could be happy with that solution. But I also want to use the rest of the
> content of the WSDL file to create a generic test tool for testing our web
> services. I was using WSDL4J to parse the WSDL file, from which I have
> access to the root Element of each schema definition. So I would like to
> avoid parsing the file twice.
> What I thought I could do was then create one resource set and then add
> each schema to it in the order it was defined in the WSDL. I guess the
> part I'm missing is how to name the first schema (via its uri) so that the
> second schema will resolve references to the first schema in the same
> resourceSet.
> Again, thanks for any insights you may have.
> Ed Merks wrote:
> > Tim,
> > You don't seem to have any import statements. You need an import for
> > each namespace that you reference. Did you know that an XSDResourceImpl
> > can directly handle a .wsdl file? You just need to register a factory
> > for "wsdl" the same way as for "xsd". It will find all the schema nodes
> > and create XSDSchemas for them (and will resolve any cross schema imports).
> > >element.
> > >definition.
> > >Resource rs1 =
> > >Resource rs2 =
> > > <xsd:annotation>
> > > </xsd:annotation>
> > > <xsd:sequence>
> > > </xsd:sequence>
> > > </xsd:complexType>
> > ></xsd:schema>
> > >and
> > ><?xml version="1.0" encoding="UTF-8"?>
> > > <xsd:annotation>
> > > </xsd:annotation>
> > > </xsd:complexType>
> > > <xsd:sequence>
> > > </xsd:sequence>
> > > </xsd:extension>
> > > </xsd:complexType>
> > ></xsd:schema>
Re: HowTo reference definitions in multiple schemas [message #591507 is a reply to message #52699] |
Fri, 10 September 2004 11:02  |
Tim,
>element.
>definition.
>Resource rs1 =
>Resource rs2 =
> <xsd:annotation>
> </xsd:annotation>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
></xsd:schema>
>and
> <xsd:annotation>
> </xsd:annotation>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:extension>
> </xsd:complexType>
></xsd:schema>
Re: HowTo reference definitions in multiple schemas [message #591515 is a reply to message #52726] |
Fri, 10 September 2004 12:37  |
Thanks Ed.
resourceSet.
Ed Merks wrote:
> Tim,
> >element.
> >definition.
> >Resource rs1 =
> >Resource rs2 =
> > <xsd:annotation>
> > </xsd:annotation>
> > <xsd:sequence>
> > </xsd:sequence>
> > </xsd:complexType>
> ></xsd:schema>
> >and
> > <xsd:annotation>
> > </xsd:annotation>
> > </xsd:complexType>
> > <xsd:sequence>
> > </xsd:sequence>
> > </xsd:extension>
> > </xsd:complexType>
> ></xsd:schema>
Re:Figured it out :-) [message #591523 is a reply to message #52753] |
Tim wrote:
> Thanks Ed.
> resourceSet.
> Ed Merks wrote:
> > Tim,
> > >element.
> > >definition.
> > >Resource rs1 =
> > >Resource rs2 =
> > > <xsd:annotation>
> > > </xsd:annotation>
> > > <xsd:sequence>
> > > </xsd:sequence>
> > > </xsd:complexType>
> > ></xsd:schema>
> > >and
> > > <xsd:annotation>
> > > </xsd:annotation>
> > > </xsd:complexType>
> > > <xsd:sequence>
> > > </xsd:sequence>
> > > </xsd:extension>
> > > </xsd:complexType>
> > ></xsd:schema>
FUDForum. Page generated in 0.05731 seconds
