Home » Archived » Test and Performance Tools Platform (TPTP) » AGR does not recognize confirmation dialog
AGR does not recognize confirmation dialog [message #52691] Thu, 02 February 2006 17:42 Go to next message
Greetings,
we use using AGR/TPTP 4.1 in Eclipse 3.1. A scenario I am automating
involves a simple confirmation dialog that is invoked by the plugin under
test as follows
MessageBox replicate = new MessageBox(getShell(), SWT.YES | SWT.NO);
replicate.setMessage(REP_MSG_1);
replicate.setText(REP_MSG_2);
return replicate.open() == SWT.YES;
When recording the scenario, AGR fails to recognize the replicate
dialog/record any interaction with it, subsequent test execution fails with
the message 'Timeout occured [...] This is likely caused by the presence of
an unexpected dialog'.
Is the SWT MessageBox a 'native' dialog as described in the AGR manual,
section 1.2 'Known Limitations and Workarounds', and/or is there any
workaround? I would like to think that simple yes/no confirmation dialogs
such as the one I am looking at are a pretty common occurence and there is a
way to make AGR work with it.
Thanks much for any insight!
- Stephan
Re: AGR does not recognize confirmation dialog [message #52774 is a reply to message #52691] Fri, 03 February 2006 14:19 Go to previous message
Hi Stephan,
Yes, you're right. The MessageBox is a native dialog, but MessageDialog
isn't.
You can use a message dialog as follows:
MessageDialog md = new MessageDialog
(HelloWorldPlugin.getDefault().getWorkbench().getActiveWorkb enchWindow().get
Shell(), "Title", null, "Message", MessageDialog.NONE, new String[]{"Yes",
"No"}, 0);
return md.open() == 0;
Unfortunately I can't think of any other workarounds that you can use
without the need to change your code.
Thanks.
"Stephan Lips" <stephan.lips@gmail.com> wrote in message
news:dru1sg$e92$1@utils.eclipse.org...
> Greetings,
> test as follows
with
of
a
> - Stephan
Previous Topic:Missing execution statistics??
Next Topic:more on: AGR does not recognize confirmation dialog
Current Time: Wed Nov 05 08:12:16 EST 2025
Powered by FUDForum. Page generated in 0.03435 seconds
