Home » Eclipse Projects » Mylyn » Connector Documentation
Connector Documentation [message #52686] Sat, 12 July 2008 12:07 Go to next message
Originally posted by: peter.machineworx.org
I have a big problem finding any documentation on how I construct a
connector to work with our proprietary task database.
http://wiki.eclipse.org/index.php/Mylyn/Integrator_Reference #Creating_connector_projects
That link seems to be outdated, referring to
(org.eclipse.mylyn.provisional.tasklist), which I can not locate.
Any help would be appreciated!
Best regards
/Peter Björklund
Re: Connector Documentation [message #52879 is a reply to message #52686] Wed, 16 July 2008 20:15 Go to previous messageGo to next message
bump
Peter Bjšrklund wrote:
> Best regards
> /Peter Björklund
bump
Re: Connector Documentation [message #54347 is a reply to message #52686] Wed, 23 July 2008 01:27 Go to previous messageGo to next message
Is there any plan or bug related to getting the extension points and
API's documented?
> Best regards
> /Peter Björklund
Re: Connector Documentation [message #54615 is a reply to message #54347] Sun, 27 July 2008 11:27 Go to previous messageGo to next message
Yes, please let me know. I would very much like to add support for mylyn.
Thank you,
/Peter
> API's documented?
>> Best regards
>> /Peter Björklund
Re: Connector Documentation [message #57729 is a reply to message #52686] Fri, 12 September 2008 12:23 Go to previous messageGo to next message
database as in jdbc://mytype/myhost/mydb?
Look at http://wiki.eclipse.org/Mylyn/Incubator/Generic_SQL_Connecto r
Works already with Mylyn 2.3, configure the SQL for your DB in ibatis
files and bingo.
I'm working on the port to 3.0
Maarten
Re: Connector Documentation [message #58156 is a reply to message #57729] Mon, 22 September 2008 14:29 Go to previous message
> files and bingo.
> Maarten
Post to 3.0.x is in progress, check page for update site.
Maarten
Re: Connector Documentation [message #591251 is a reply to message #52686] Wed, 16 July 2008 20:15 Go to previous message
bump
> Best regards
> /Peter Björklund
bump
Re: Connector Documentation [message #591809 is a reply to message #52686] Wed, 23 July 2008 01:27 Go to previous message
API's documented?
> Best regards
> /Peter Björklund
Re: Connector Documentation [message #591922 is a reply to message #54347] Sun, 27 July 2008 11:27 Go to previous message
Thank you,
/Peter
> API's documented?
>> Best regards
>> /Peter Björklund
Re: Connector Documentation [message #593221 is a reply to message #52686] Fri, 12 September 2008 12:23 Go to previous message
files and bingo.
Maarten
Re: Connector Documentation [message #593374 is a reply to message #57729] Mon, 22 September 2008 14:29 Go to previous message
> files and bingo.
> Maarten
Maarten
Previous Topic:Is there a plan of the internationalization?
Next Topic:editor tabs re-ordered when switching tasks
Current Time: Sat Jul 26 08:36:38 EDT 2025
Powered by FUDForum. Page generated in 0.06701 seconds
