Home » Eclipse Projects » Nebula » Grid - Inline Editing
| Grid - Inline Editing [message #52659] |
Sun, 11 May 2008 07:52  |
Originally posted by: mail.ppfeifer.net
Hello.
I'm using the GridTableViewer with inline editing support and moveable
columns. Inline editing works as it's supposed to, but when I move some
gridcolumns the inline editing tab order is still the same, as it was
after creation. Lets say I have got 4 columns (col1, col2, col3, col4)
and I move col3 to the second postion (col1, col3, col2, col4). Then
inline editing is still moving from col1 to col2 to col3 to col4. Is
there a way to tell the inline editing, to take the new column order
into account?
Thanks in adavance.
Peter
| Re: Grid - Inline Editing [message #52687 is a reply to message #52659] |
Sun, 11 May 2008 11:08   |
I don't think this is possible with JFace 3.3 codebase (reordering was
not included in the 3.3 codestream). We (JFace) fixed this in 3.4 and if
Grid behaves like SWT-Table (which it should else I'd consider this a
Grid-bug) this should work out of the box with JFace from 3.4M7 (which
is in a fairly complete state because we are working towards 3.4RC1).
Tom
Peter Pfeifer schrieb:
> Hello.
> into account?
> Thanks in adavance.
> Peter
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
| Re: Grid - Inline Editing [message #52712 is a reply to message #52687] |
Sun, 11 May 2008 12:22   |
Hello Tom.
Thanks for your answer. This means, if I change to Eclipse >= 3.4M7 this
should work out of the box?
There is one more thing I emcountered. When I do inline editing in a
GridTableViewer with eg. 60 lines where only 10 are displayed at once in
the GridTableViewer, the table does not scroll down to the line which is
currently edited. If you scroll down by using the vertical scrollbar
inline editing is still possible. Is it possible to scroll automatically
to the position of the line, if this line isn't shown?
Thanks Peter
> Tom
>> Hello.
>> some gridcolumns the inline editing tab order is still the same, as it
>> was after creation. Lets say I have got 4 columns (col1, col2, col3,
>> col4) and I move col3 to the second postion (col1, col3, col2, col4).
>> Then inline editing is still moving from col1 to col2 to col3 to col4.
>> Is there a way to tell the inline editing, to take the new column
>> order into account?
>> Thanks in adavance.
>> Peter
| Re: Grid - Inline Editing [message #52872 is a reply to message #52845] |
Mon, 12 May 2008 10:16   |
--------------020202070508030301070905
> Hello Tom.
> Thank you very much. I added your changes and now both work like a
> charm. But that leads me to another question :-) I don't know if I
> should start a new thread, but first I'll try my luck within this one.
> I want to use the grid/gridtableviewer for quick data entry. Therefore I
> have a special requirement. When the active cell is the really last one
> in the grid and the user presses the tab-key a new record/row should be
> added to the grid. It's more or less the same as in MS Word/OO when the
> user is editing the last cell of a table and pressing the tab-key
> automatically adds one new row.
> Is this also possible to be done with the grid/gridtableviewer?
That's not an easy task but doable with some hacks. Because we are past
API-Freeze in JFace 3.4 it is to late to introduce such a feature at
JFace level and I don't think GridViewer should introduce an API itself.
Having said this you can solve "quite simply" your own and staying with
the current API but enhancing it (See the files attached). This is only
one solution you could also use Reflection for example.
Tom
name="GridViewerEditor.java"
Content-Disposition: inline;
filename="GridViewerEditor.java"
* Copyright (c) 2007 IBM Corporation and others.
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Eclipse Public License v1.0
* which accompanies this distribution, and is available at
* http://www.eclipse.org/legal/epl-v10.html
* Contributors:
* rmcamara@us.ibm.com - initial API and implementation
* Tom Schindl <tom.schindl@bestsolution.at> - various significant contributions
* bug fix in: 191216
package org.eclipse.nebula.snippets.gridviewer;
import org.eclipse.jface.viewers.ColumnViewer;
import org.eclipse.jface.viewers.ColumnViewerEditor;
import org.eclipse.jface.viewers.ColumnViewerEditorActivationEvent;
import org.eclipse.jface.viewers.ColumnViewerEditorActivationStrate gy;
import org.eclipse.jface.viewers.StructuredSelection;
import org.eclipse.jface.viewers.ViewerCell;
import org.eclipse.jface.viewers.ViewerRow;
import org.eclipse.jface.viewers.CellEditor.LayoutData;
import org.eclipse.nebula.jface.gridviewer.GridTableViewer;
import org.eclipse.nebula.jface.gridviewer.GridTreeViewer;
import org.eclipse.nebula.widgets.grid.Grid;
import org.eclipse.nebula.widgets.grid.GridEditor;
import org.eclipse.nebula.widgets.grid.GridItem;
import org.eclipse.swt.events.TraverseEvent;
import org.eclipse.swt.graphics.Point;
import org.eclipse.swt.widgets.Control;
import org.eclipse.swt.widgets.Item;
public class GridViewerEditor extends ColumnViewerEditor {
/** Editor support for tables. */
private GridEditor gridEditor;
private TabbingEndHandler handler;
* This handler is called when tabbing to the next/previous element didn't succeeded
public abstract static class TabbingEndHandler {
public abstract void handle(ViewerCell cell, TraverseEvent event);
GridViewerEditor(ColumnViewer viewer,
ColumnViewerEditorActivationStrategy editorActivationStrategy,
int feature) {
super(viewer, editorActivationStrategy, feature);
this.gridEditor = new GridEditor((Grid) viewer.getControl());
protected StructuredSelection createSelection(Object element) {
return new StructuredSelection(element);
protected void setEditor(Control w, Item item, int fColumnNumber) {
gridEditor.setEditor(w, (GridItem) item, fColumnNumber);
protected void setLayoutData(LayoutData layoutData) {
gridEditor.grabHorizontal = layoutData.grabHorizontal;
gridEditor.horizontalAlignment = layoutData.horizontalAlignment;
gridEditor.minimumWidth = layoutData.minimumWidth;
public void setTabbingEndHandler(TabbingEndHandler handler) {
this.handler = handler;
protected void processTraverseEvent(int columnIndex, ViewerRow row,
TraverseEvent event) {
if( handler != null ) {
ViewerCell previous = getFocusCell();
super.processTraverseEvent(columnIndex, row, event);
ViewerCell next = getFocusCell();
if( previous != null && previous.equals(next) ) {
handler.handle(next, event);
} else {
public ViewerCell getFocusCell() {
Grid grid = (Grid) getViewer().getControl();
if (grid.getCellSelectionEnabled()) {
Point p = grid.getFocusCell();
if (p.x >= 0 && p.y >= 0) {
GridItem item = grid.getItem(p.y);
if (item != null) {
ViewerRow row = getViewerRowFromItem(item);
return row.getCell(p.x);
return null;
private ViewerRow getViewerRowFromItem(GridItem item) {
if (getViewer() instanceof GridTableViewer) {
return ((MyGridTableViewer) getViewer()).getViewerRowFromItem(item);
} else {
return ((MyGridTreeViewer) getViewer()).getViewerRowFromItem(item);
protected void updateFocusCell(ViewerCell focusCell,
ColumnViewerEditorActivationEvent event) {
if (event.eventType == ColumnViewerEditorActivationEvent.PROGRAMMATIC
|| event.eventType == ColumnViewerEditorActivationEvent.TRAVERSAL) {
Grid grid = ((Grid) getViewer().getControl());
grid.deselectAllCells();
grid.setFocusColumn(grid.getColumn(focusCell.getColumnIndex( )));
grid.setFocusItem((GridItem) focusCell.getItem());
grid.setCellSelection(new Point(focusCell.getColumnIndex(), grid
.indexOf((GridItem) focusCell.getItem())));
grid.showSelection();
public static void create(MyGridTableViewer viewer,
int feature) {
viewer.setColumnViewerEditor(new GridViewerEditor(viewer,
editorActivationStrategy, feature));
public static void create(MyGridTreeViewer viewer,
int feature) {
name="MyGridTableViewer.java"
filename="MyGridTableViewer.java"
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Widget;
public class MyGridTableViewer extends GridTableViewer {
public MyGridTableViewer(Grid grid) {
super(grid);
// TODO Auto-generated constructor stub
public MyGridTableViewer(Composite parent, int style) {
super(parent, style);
public MyGridTableViewer(Composite parent) {
super(parent);
protected ViewerRow getViewerRowFromItem(Widget item) {
// TODO Auto-generated method stub
return super.getViewerRowFromItem(item);
name="MyGridTreeViewer.java"
filename="MyGridTreeViewer.java"
public class MyGridTreeViewer extends GridTreeViewer {
public MyGridTreeViewer(Grid grid) {
super(grid);
public MyGridTreeViewer(Composite parent, int style) {
public MyGridTreeViewer(Composite parent) {
super(parent);
--------------020202070508030301070905--
| Re: Grid - Inline Editing [message #53073 is a reply to message #53050] |
Wed, 14 May 2008 06:54  |
Hello Tom.
I tried it with your snippets and it worked. I'll have a look at my
code, seems that I'm missing something.
Peter
> If you have one (a completely runnable) this would make it easier to
> track it down (if I can because I'm not so educated when it comes to
> Grid's internals but I'll certainly take a look).
> Tom
>> Unfortunately I'm sure :-) The grid just doesn't scroll to the left,
>> when using Shift+Tab.
>> Should I provide you some code snippets?
>> Peter
>>> Are you sure for me it worked in my small tests yesterday and because
>>> I'm using the Grid-API I don't know what's wrong :-(.
>>> Tom
>>>> Hello Tom.
>>>> Thank you very much, your patch works. Now I can handle "the last
>>>> cell in the table".
>>>> But there is another issue I encountered, when traversing through
>>>> the grid with horizontal scrollbar visible, due to to some columns
>>>> aren't visible because of the width of table. While forward
>>>> traversing works how it's supposed to (the grid scrolls to currently
>>>> active cell) backward traversing (Shift+Tab) doesn't scroll to the
>>>> active cell.
>>>> Thnks.
>>>> Peter
>>>>> Yes. I think it could make sense at least we should think about how
>>>>> this could be solved at the JFace level.
>>>>> My code is not tested at all so there's the possibility that I
>>>>> missed something.
>>>>> Tom
>>>>>> Thank you very much. I'll give this a try tomorrow and let you
>>>>>> know. Besides that, would this be a valuable feature/enhancement
>>>>>> for future JFace releases?
>>>>>> Peter
>>>>>>>> Hello Tom.
>>>>>>>> a charm. But that leads me to another question :-) I don't know
>>>>>>>> if I should start a new thread, but first I'll try my luck
>>>>>>>> within this one.
>>>>>>>> Therefore I have a special requirement. When the active cell is
>>>>>>>> the really last one in the grid and the user presses the tab-key
>>>>>>>> a new record/row should be added to the grid. It's more or less
>>>>>>>> the same as in MS Word/OO when the user is editing the last cell
>>>>>>>> of a table and pressing the tab-key automatically adds one new row.
>>>>>>> are past API-Freeze in JFace 3.4 it is to late to introduce such
>>>>>>> a feature at JFace level and I don't think GridViewer should
>>>>>>> staying with the current API but enhancing it (See the files
>>>>>>> attached). This is only one solution you could also use
>>>>>>> Tom
| Re: Grid - Inline Editing [message #589719 is a reply to message #52659] |
Tom
> Hello.
> into account?
> Thanks in adavance.
> Peter
| Re: Grid - Inline Editing [message #589733 is a reply to message #52687] |
Hello Tom.
Thanks Peter
> Tom
>> Hello.
>> order into account?
>> Thanks in adavance.
>> Peter
| Re: Grid - Inline Editing [message #589742 is a reply to message #52712] |
Sun, 11 May 2008 14:44  |
> Hello Tom.
Yes.
This is also a fix in 3.4 stream. The bugfixes you are interested in are:
- https://bugs.eclipse.org/bugs/show_bug.cgi?id=201910
- https://bugs.eclipse.org/bugs/show_bug.cgi?id=195908
Tom
| Re: Grid - Inline Editing [message #589752 is a reply to message #52739] |
Mon, 12 May 2008 06:31  |
Hello Tom.
Many thanks, It seems that it's a bug of the Grid beacause I downloaded
Exlipse 3.4M7 and tried what you suggested. But still it has the same
behaviour. Neither the inline editing nor the scrolling works as
supposed to. I've never filed a bug before. How does the procedure look
like, or is there already a bug entry in bugzilla?
Regards, Peter
>> Hello Tom.
>> this should work out of the box?
> Yes.
>> in the GridTableViewer, the table does not scroll down to the line
>> which is currently edited. If you scroll down by using the vertical
>> scrollbar inline editing is still possible. Is it possible to scroll
>> automatically to the position of the line, if this line isn't shown?
> Tom
| Re: Grid - Inline Editing [message #589772 is a reply to message #52766] |
Mon, 12 May 2008 08:40  |
You are right.
Reordered Columns:
Nebula Grid didn't implement the additional methods we added in 3.4. I
filed a bug and added a patch which makes this work [1].
Scrolling Cell into View:
This is a bug in GridViewerEditor easily fixable as [2] shows.
Tom
[1]https://bugs.eclipse.org/bugs/show_bug.cgi?id=231530
[2]https://bugs.eclipse.org/bugs/show_bug.cgi?id=231532
> Hello Tom.
> Regards, Peter
>>> Hello Tom.
>> Yes.
>> Tom
| Re: Grid - Inline Editing [message #589783 is a reply to message #52819] |
Mon, 12 May 2008 09:17  |
Hello Tom.
Peter
> You are right.
> Reordered Columns:
> Tom
>> Hello Tom.
>> downloaded Exlipse 3.4M7 and tried what you suggested. But still it
>> has the same behaviour. Neither the inline editing nor the scrolling
>> works as supposed to. I've never filed a bug before. How does the
>> procedure look like, or is there already a bug entry in bugzilla?
>> Regards, Peter
>>>> Hello Tom.
>>> Yes.
>>>> once in the GridTableViewer, the table does not scroll down to the
>>>> line which is currently edited. If you scroll down by using the
>>>> vertical scrollbar inline editing is still possible. Is it possible
>>>> to scroll automatically to the position of the line, if this line
>>>> isn't shown?
>>> are:
>>> Tom
| Re: Grid - Inline Editing [message #589794 is a reply to message #52845] |
> Hello Tom.
Tom
* Contributors:
int feature) {
} else {
if (item != null) {
return null;
} else {
int feature) {
int feature) {
super(grid);
super(parent);
super(grid);
super(parent);
| Re: Grid - Inline Editing [message #589806 is a reply to message #52872] |
Mon, 12 May 2008 11:15  |
Thank you very much. I'll give this a try tomorrow and let you know.
Besides that, would this be a valuable feature/enhancement for future
JFace releases?
Peter
>> Hello Tom.
>> I have a special requirement. When the active cell is the really last
>> one in the grid and the user presses the tab-key a new record/row
>> should be added to the grid. It's more or less the same as in MS
>> Word/OO when the user is editing the last cell of a table and pressing
> Tom
| Re: Grid - Inline Editing [message #589814 is a reply to message #52899] |
Mon, 12 May 2008 11:24  |
Yes. I think it could make sense at least we should think about how this
My code is not tested at all so there's the possibility that I missed
something.
Tom
> JFace releases?
> Peter
>>> Hello Tom.
>>> Therefore I have a special requirement. When the active cell is the
>>> really last one in the grid and the user presses the tab-key a new
>>> record/row should be added to the grid. It's more or less the same as
>>> in MS Word/OO when the user is editing the last cell of a table and
>> past API-Freeze in JFace 3.4 it is to late to introduce such a feature
>> at JFace level and I don't think GridViewer should introduce an API
>> itself.
>> with the current API but enhancing it (See the files attached). This
>> is only one solution you could also use Reflection for example.
>> Tom
| Re: Grid - Inline Editing [message #589834 is a reply to message #52926] |
Tue, 13 May 2008 02:22  |
Hello Tom.
Thank you very much, your patch works. Now I can handle "the last cell
in the table".
But there is another issue I encountered, when traversing through the
grid with horizontal scrollbar visible, due to to some columns aren't
visible because of the width of table. While forward traversing works
how it's supposed to (the grid scrolls to currently active cell)
backward traversing (Shift+Tab) doesn't scroll to the active cell.
Thnks.
Peter
> something.
> Tom
>> JFace releases?
>> Peter
>>>> Hello Tom.
>>>> as in MS Word/OO when the user is editing the last cell of a table
>>> feature at JFace level and I don't think GridViewer should introduce
>>> an API itself.
>>> Tom
| Re: Grid - Inline Editing [message #589841 is a reply to message #52972] |
Tue, 13 May 2008 02:31  |
Tom
> Hello Tom.
> in the table".
> Thnks.
> Peter
>> something.
>> Tom
>>> JFace releases?
>>> Peter
>>>>> Hello Tom.
>>>> an API itself.
>>>> Tom
| Re: Grid - Inline Editing [message #589851 is a reply to message #52997] |
Tue, 13 May 2008 02:42  |
Peter
> Tom
>> Hello Tom.
>> in the table".
>> Thnks.
>> Peter
>>> something.
>>> Tom
>>>> Peter
>>>>>> Hello Tom.
>>>>>> one.
>>>>>> the really last one in the grid and the user presses the tab-key a
>>>>>> new record/row should be added to the grid. It's more or less the
>>>>>> same as in MS Word/OO when the user is editing the last cell of a
>>>>> This is only one solution you could also use Reflection for example.
>>>>> Tom
| Re: Grid - Inline Editing [message #589856 is a reply to message #53023] |
Tue, 13 May 2008 02:48  |
Tom
> Peter
>> Tom
>>> Hello Tom.
>>> cell in the table".
>>> Thnks.
>>> Peter
>>>> missed something.
>>>> Tom
>>>>> Peter
>>>>>>> Hello Tom.
>>>>>>> if I should start a new thread, but first I'll try my luck within
>>>>>>> this one.
>>>>>> Tom
| Re: Grid - Inline Editing [message #589864 is a reply to message #53050] |
Hello Tom.
Peter
> Tom
>> Peter
>>> Tom
>>>> Hello Tom.
>>>> cell in the table".
>>>> active cell.
>>>> Thnks.
>>>> Peter
>>>>> missed something.
>>>>> Tom
>>>>>> Peter
>>>>>>>> Hello Tom.
>>>>>>>> within this one.
>>>>>>> Tom
Current Time: Fri Nov 07 06:56:41 EST 2025
Powered by FUDForum. Page generated in 0.27284 seconds
