Home » Eclipse Projects » Plugin Development Environment (PDE) » Reading Bundle-SymbolicName and Bundle-Version from custom build.xml?
Reading Bundle-SymbolicName and Bundle-Version from custom build.xml? [message #52646] Mon, 30 March 2009 18:47 Go to next message
Apparently the only way I can get PDE's Export to stop silently deleting
my build.xml file (nasty, nasty PDE!) is to put custom = true in my
build.properties file and merge the necessary PDE build targets into my
own Ant build.
Back in 2006, there didn't appear to be an easy way to access the
necessary parameters (Bundle-SymbolicName and Bundle-Version) according
to this report
http://dev.eclipse.org/newslists/news.eclipse.platform.rcp/m sg10949.html
Has the situation improved today? Is there a way to get this
information from the manifest or some other source which is accessible
to Ant?
Tom
Re: Reading Bundle-SymbolicName and Bundle-Version from custom build.xml? [message #52728 is a reply to message #52646] Mon, 30 March 2009 20:33 Go to previous messageGo to next message
> own Ant build.
> to this report
> to Ant?
We at least prompt in 3.5 now if we're going to override your build.xml...
Is there a reason you have to have a build.xml in your project? can't it
be my-build.xml?
Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465
http://twitter.com/eclipsesource | http://twitter.com/caniszczyk
Re: Reading Bundle-SymbolicName and Bundle-Version from custom build.xml? [message #52755 is a reply to message #52728] Mon, 30 March 2009 23:24 Go to previous messageGo to next message
>> according to this report
>> to Ant?
> be my-build.xml?
Thanks for the quick reply Chris. I take it that that's a "No" in
answer to the original question(s).
In answer to your questions, the main reasons that it's called build.xml
are: a) that's what Ant uses and b) that's what the development team
chose in Fall 2000 when they switched to using Ant for their builds.
As far as renaming things goes, let me turn the question around. Is
there any particular reason that a temporary file which is going to
exist for all of 5 minutes has be given a name that conflicts with every
Ant-based build in the known universe? If a name like
your-special-eclipse-pde-temporary-build.xml was used, there'd be fewer
conflicts. Better yet, check to make sure the chosen name isn't already
in use.
I'm trying to promote Eclipse plugins to a project which has been around
for a decade, so I really don't want to be insisting that they have to
change things just to get started. I'd like to emphasize the benefits,
not the costs.
If I figure out a good way to parse the manifest or some other solution,
I'll post an update.
Tom
Re: Reading Bundle-SymbolicName and Bundle-Version from custom build.xml? [message #52781 is a reply to message #52755] Tue, 31 March 2009 09:42 Go to previous messageGo to next message
It was before my time, but it was probably named 'build.xml' for the
same reason you named yours build.xml, (it is an ant script that builds
the project).
Note that the warning is only in the UI for export, headless build can't
prompt for warnings since that defeat the whole purpose of an automated
headless build.
For the version, PDE/Build will modify the custom build.xml and replace
the value on a property named "version.suffix", the value will be the
full version of the bundle with the qualifier replaced.
There is no property for the symbolic-name. Don't you know this? It
isn't something that changes.
-Andrew
>>> accessible to Ant?
>> it be my-build.xml?
If a name like
> in use.
> not the costs.
> Tom
Re: Reading Bundle-SymbolicName and Bundle-Version from custom build.xml? [message #52807 is a reply to message #52781] Tue, 31 March 2009 10:06 Go to previous messageGo to next message
> the project).
> headless build.
Andrew, is there a way we can change the build.xml that gets generated
to be pde-build.xml or something?
Re: Reading Bundle-SymbolicName and Bundle-Version from custom build.xml? [message #53043 is a reply to message #52807] Wed, 01 April 2009 11:22 Go to previous message
See my comment here: https://bugs.eclipse.org/bugs/show_bug.cgi?id=120840#c8
Changing the default name of the script should be considered a major
breaking API change. The alternative is then to allow a bundle to
provide an alternate name. With some restrictions on features, this
should be possible, however it is not a small change and affects all the
generated scripts.
There is no time for something like this in 3.5. This would need to be
accounted for in the initial planning at the beginning of a release cycle.
-Andrew
>> builds the project).
>> can't prompt for warnings since that defeat the whole purpose of an
>> automated headless build.
>> replace the value on a property named "version.suffix", the value will
>> be the full version of the bundle with the qualifier replaced.
> Cheers,
Re: Reading Bundle-SymbolicName and Bundle-Version from custom build.xml? [message #594267 is a reply to message #52646] Mon, 30 March 2009 20:33 Go to previous message
> own Ant build.
> to this report
> to Ant?
be my-build.xml?
Re: Reading Bundle-SymbolicName and Bundle-Version from custom build.xml? [message #594277 is a reply to message #52728] Mon, 30 March 2009 23:24 Go to previous message
>> to Ant?
> be my-build.xml?
in use.
not the costs.
Tom
Re: Reading Bundle-SymbolicName and Bundle-Version from custom build.xml? [message #594286 is a reply to message #52755] Tue, 31 March 2009 09:42 Go to previous message
the project).
headless build.
-Andrew
>>> accessible to Ant?
>> it be my-build.xml?
If a name like
> in use.
> not the costs.
> Tom
Re: Reading Bundle-SymbolicName and Bundle-Version from custom build.xml? [message #594296 is a reply to message #52781] Tue, 31 March 2009 10:06 Go to previous message
> the project).
> headless build.
Re: Reading Bundle-SymbolicName and Bundle-Version from custom build.xml? [message #594413 is a reply to message #52807] Wed, 01 April 2009 11:22 Go to previous message
generated scripts.
-Andrew
> Cheers,
Previous Topic:Building "umbrella" features that include multiple pre-built child features
Next Topic:Get the path of the current document
Current Time: Sat Jul 12 14:21:58 EDT 2025
Powered by FUDForum. Page generated in 0.04788 seconds
