| NUllPointerException after updating to 1.0 [message #52600] |
Wed, 17 October 2007 09:50  |
Hey there.
I just updated from M6 to RAP 1.0. After the update (following the steps
on the RAP homepage), I get the following exception with a formerly
runing project:
17.10.2007 13:34:20 org.mortbay.jetty.servlet.ServletHandler handle
SCHWERWIEGEND: /rap/:
org.eclipse.rwt.internal.lifecycle.HtmlResponseWriter.closeE lementIfStarted(HtmlResponseWriter.java:689)
org.eclipse.rwt.internal.lifecycle.HtmlResponseWriter.startE lement(HtmlResponseWriter.java:489)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleServiceHandle rSync.sendMultipleClientsPerSessionPage(RWTLifeCycleServiceH andlerSync.java:163)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleServiceHandle rSync.serviceInternal(RWTLifeCycleServiceHandlerSync.java:75 )
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleServiceHandle rSync.access$0(RWTLifeCycleServiceHandlerSync.java:48)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleServiceHandle rSync$1.service(RWTLifeCycleServiceHandlerSync.java:43)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleBlockControl$ ServiceHandlerProcessor.run(RWTLifeCycleBlockControl.java:68 )
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleThreadPool$Po olRunnable.run(RWTLifeCycleThreadPool.java:38)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleThreadPool$Po olWorker.run(RWTLifeCycleThreadPool.java:66)
Any hints? The website only shows up an internal server error (500)
Greez
Alex
| Re: NUllPointerException after updating to 1.0 [message #60513 is a reply to message #60497] |
Mon, 19 November 2007 11:40  |
try to reproduce the bug with current CVS. Afaik this should be fixed now.
Greets
Benny
Christian wrote:
> i confirm this problem under firefox; i try to replicate the bug: this
> Nullpointerexception occurs when rap app is in a "standby" mode (in this
> period i use other firefox tabs or other applications) and after some
> minutes i came back to the rap app.
> Christian
> Frank Appel ha scritto:
>> we've noticed this behaviour also, and yes it is a bug (I created a bugzilla
>> entry: #207056). But unfortunately there seems to be some difference in
>> behaviour between FireFox and IE, so we are not sure whether we have already
>> collected all available possibilties to reproduce the problem. So it would
>> indeed helpful if you could add any information you've already gathered to
>> the bug entry.
>> Ciao
>> Frank
>> "Alexander Forschner" <alexander.forschner@uni-ulm.de> schrieb im
>> Newsbeitrag news:ff7g65$mmu$1@build.eclipse.org...
>>> schrieb:
>>>> We have the same problem. It can be reproduced as follows:
>>>> 1. Start RAP application
>>>> 2. Stop server
>>>> 3. Client notices that the server is unavailable and asks if the query
>>>> should be submitted again (Browser-Popup-Box)
>>>> 4. Start server again
>>>> 5. Press "retry" in browser
>>>> --> Exception in server as Alex wrote. HTTP 500 in browser
>>> Thanks for that hint. I cannot reproduce the error in this way, if I wait
>>> for the browser to tell me the server is unavailable. If I restart the
>>> server and then reload the page in the browser, this error occurs.
>>> The error occurs most of the times, sometimes, I get the "session expired"
>>> error.
>>> Is this enough information for a bug report?
>>> Greez
>>> Alex
FUDForum. Page generated in 0.04958 seconds
