| dateTime parameters don't work ?? [message #52598] |
Wed, 29 June 2005 10:52  |
I've made a report design that take 2 dateTime parameters to generate data
in a certain time range (given at runtime). Hence, my main dataset has
also 2 dateTime parameters that would be injected in the request SELECT
.... WHERE dateCreation BETWEEN ? and ?
That doesn't work and generate a class cast exception.
I've seen in this newsgroup people having the same issue, so i tried to
set parameters type to the default (for both dataset and report
parameters) and set parameters at run time with plain string :
params.put("dateBegin", "2005-06-17 10:43:05");
params.put("dateEnd", "2005-06-27 10:43:05");
The report is generated with no errors but the data is not reduced to the
give time range...
How can i use dateTime parameters?? I desesperate need a workaround or
something,
Thanks for your help
| Re: dateTime parameters don't work ?? [message #54091 is a reply to message #52598] |
Wed, 06 July 2005 03:38  |
Originally posted by: none.none.none
Alex, were you able to resolve this issue? I am currently having the same
problem with report parameters (dataset parameters seem to be okay).
"Alex" <a.tual@fylab.fr> wrote in message
news:85275a40d12cd799e9d04314368fabb0$1@www.eclipse.org...
> reduced to the give time range...
> something,
FUDForum. Page generated in 0.03902 seconds
