Home » Eclipse Projects » GEF » Drag and Drop in Logic Editor Example
| Drag and Drop in Logic Editor Example [message #52541] |
Tue, 07 January 2003 02:01  |
Originally posted by: truenoto.yahoo.com
From a previous posting, it said I can drag a Task in the Task View and drop
it to a Label in the Logic Editor. I try it, but when I try to drop it to a
Label, I just get a "Stop" icon, the drag-and-drop does not seem to work for
me.
Could someone please tell me if I miss anything?
Thank you.
| Re: Drag and Drop in Logic Editor Example [message #52650 is a reply to message #52624] |
Tue, 07 January 2003 12:13   |
Originally posted by: hudsonr.us.eye-bee-em.com
"Takumi Fujiwara" <truenoto@yahoo.com> wrote in message
news:avevs5$907$1@rogue.oti.com...
> How can I remove the restriction of holding the CTRL key for drag and
drop?
Yes, the DragSource can override the drop type and force it to be a Copy.
This is necessary for the TaskView, but it is not necessary for dragging
from Wordpad. In reality, I think the bug is in the TaskView, it should not
support a MOVE operation since you cannot move a task via TextTransfer.
> And can I drag a Java file in the Package Explorer to the GEF graph
editor?
> What kind of Drag and Drop listener do i need to implement?
I don't know. You'd have to look at which DragSources are added to that
Viewer, and then add a GEF TransferDropTargetListener that supports the same
SWT Transfer. Post this question to main newsgroup.
> Thank you.
> "Randy Hudson" <hudsonr@us.eye-bee-em.com> wrote in message
> news:aveqn7$4h0$1@rogue.oti.com...
> > I think I remember that some drag sources required that you hold the
CTRL
> > key.
> > "Eric Bordeau" <ebordeau@us.ibm.com> wrote in message
> > news:aveo9p$2bq$1@rogue.oti.com...
> > > You used to be able to drag from the task view and drop the text onto
a
> > > label in the logic example. I just tried it and it didn't work for me
> > > either. But I could drag text from Wordpad and drop it on the label,
so
> > > maybe the task list no longer supports text transfers.
> > > Eric
> and
> > drop
it
> > to a
> work
> > for
> > > > me.
> > > > Thank you.
| Re: Drag and Drop in Logic Editor Example [message #52842 is a reply to message #52650] |
Wed, 08 January 2003 13:48   |
Originally posted by: sy_cheung2.yahoo.com
I find out that the Package Explorer has 3 drag adapters:
SelectionTransferDragAdapter,
ResourceTransferDragAdapter,
FileTransferDragAdapter
What I would like to do is:
when user drag an element in the Package Explorer, and drop it to the Logic
Editor, it will create an Label in the Logic Editor.
Randy Hudson mentions I need to add a GEF TransferDropTargetListener, in
this case I think I need to add a Selection TransferDropTargetListener.
But what do I need to do in this SelectionTransferDropTargetListener? When
I look at the code for the TextTransferDropTargetListener, it does not
change the text in the label. Where in the code it changes the text of the
label in case of a Drop Event.
Thanks for any help.
news:avf17q$9v2$1@rogue.oti.com...
> drop?
not
> editor?
same
> > Thank you.
> CTRL
> > > key.
onto
> a
me
label,
> so
> > > > Eric
View
> > and
> > > drop
drop
> it
> > > to a
to
> > work
> > > for
> > > > > me.
> > > > > Thank you.
| Re: Drag and Drop in Logic Editor Example [message #52896 is a reply to message #52842] |
Wed, 08 January 2003 14:01  |
Please read Manfred Goetz's response to my another post titled
"TextTransfer Drag and Drop Question in Logic Editor"
"Sam Cheung" <sy_cheung2@yahoo.com> wrote in message
news:avhr00$1o8$1@rogue.oti.com...
Logic
When
> > drop?
Copy.
> not
> > editor?
> same
> > > Thank you.
> > CTRL
> > > > key.
> onto
> > a
for
> me
> label,
> > so
> > > > > Eric
> View
> > > and
> > > > drop
> drop
> > it
> > > > to a
> to
> > > work
> > > > for
> > > > > > me.
> > > > > > Thank you.
Current Time: Sat Nov 08 22:24:07 EST 2025
Powered by FUDForum. Page generated in 0.05243 seconds
