Re: How to view multiple markers? [message #53287 is a reply to message #53237] |
Mon, 06 June 2005 11:01  |
Sian January wrote:
> In Eclipse try 'Window' > 'Preferences' > 'Java' > 'Editor', select the
> Hovers tab then check 'Enable annotation roll-over...'. That may be
> what you are looking for.
Yes, that's exactly what I'm looking. Thanks much Sian!
-barry
Re: How to view multiple markers? [message #588533 is a reply to message #52536] |
Fri, 03 June 2005 04:21  |
Hi Barry,
If you right click on the marker you will see one or more sub-menus
related to the type of the marker (e.g. if it is an advice marker you
will see 'Advised By'.) This menu will contain all the pieces of advice
that advise that line (or equivalent, depending on the relationship).
Sian
Barry Kaplan wrote:
> When there is a gutter annotation indicating multiple markers, how does
> one actually get to see the markers?
> thanks
> -barry
Re: How to view multiple markers? [message #588562 is a reply to message #52696] |
Fri, 03 June 2005 12:22  |
Sian January wrote:
> Hi Barry,
Ah! At the bottom. I see now. This marker overlay is a bit messy. Often I can't tell if I have a breakpoint marker at a line because other markers are occluding it. It would be so nice if a hover tooltip would popup all the marker info.
thanks!
-barry
Re: How to view multiple markers? [message #588703 is a reply to message #52829] |
Mon, 06 June 2005 05:19  |
Barry Kaplan wrote:
> Sian January wrote:
>> Hi Barry,
>> advice that advise that line (or equivalent, depending on the
>> relationship).
> thanks!
> -barry
Sian
Re: How to view multiple markers? [message #588716 is a reply to message #53237] |
-barry
FUDForum. Page generated in 0.07763 seconds
